Tsx momentum plc: many many 170ADM85010 all input LED shorted and on problem, any help to repairing process?
A light horizontal line has appeared on my Samsung UN55C6500 TV. Is there a fix for this?
Horizontal lines on LCD TV,
not usually repairable
plasma may have a corroded or dirty connection on ribbon cable left side of TV looking from the rear
Apr 25, 2017 | Samsung Televison & Video
Vizio 55 inch TV "Vizio E550I-B2" is Darker on the left viewing side, replaced the Power Supply board. And the Screen is still dark on the left side. Any suggestions?
It is a common problem for this TV, it uses a Sharp LED display panel. The problem is the data buffer IC inside the panel ether shorted, or burned open.
Vizio offers a extended exchange warranty if you have the original sale slip.
For more information, you may contact Vizio directly.
Apr 24, 2017 | Vizio Televison & Video
Hello Is there anyone who can help. My problem
It's allways best to check your User Manual for any LED signs, go to your providers website, input your device, and download if any manuals for it. there you will find what the trouble is.
i presume that the bulb on your projector has gone bad. hope this helps!
Aug 18, 2017 | Sanyo PLC XU50 Multimedia Projector
Function of programmable logic circuit
A programmable logic controller or programmable controller is a digital computer used for automation of electromechanical processes, such as control of machinery on factory assembly lines, amusement rides, or lighting fixtures. plc are used in many industries and machines. Unlike general-purpose computers, the plc is designed for multiple inputs and output arrangements, extended temperature ranges, immunity to electrical noise, and resistance to vibration and impact.
Mar 16, 2011 | Computers & Internet
Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
May 13, 2010 | Hisense TL1700 17 in. LCD Television
I have cp30 readymix concrete plant fully automatic run by siemens plc. Plant manufacturing data transfer from plant plc to office via simatic s7 200 cpu 226 plc. There was a short circuit at plant and...
Just give a 24V supply to the PLC by a power supply then check the input lights & output lights .....
if they are glowing then your PLC is okay
if output lights are not glowing then ur program is not working.....
dnt panic ur drive can be repaired cheaply....
Apr 28, 2009 | Siemens Simatic S5 HMI Monitor
2006 TSX lost radio when battery died - how to recode?
Sorry the only way to get the code is thru the dealer
you must provide proof of ownership.
Mar 30, 2009 | 2006 Acura TSX
Connecting my pc to a sanyo plc sw30 projector
never mind the usb, u need to only connect the video output ( yellow rcs connector ) to the vido input of the projector & it will work fine!!!
Dec 29, 2008 | Sanyo PLC-SW30 Multimedia Projector
Sanyo PLC-XU47 seems to power cycle
Welcome to resolve the problem if you please say what are the solution to me the same problem
Jun 07, 2008 | Sanyo PLC XU35 Multimedia Projector
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
