Question about Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi
Fuel pump problems
Why is it that the fuel pump alone cost more than the fuel pump assembly?
  • 344 Answers
Because the fuel pump is built with better quality materal from a different company, the assemblly was probibly built with cheaper material
Posted on Jan 05, 2010
I have a 2000 Chevy Blazer 4.3 4 wheel drive. It stalled and would not start again. The garage said the fuel pump and fuel regulator first , hen they replaced that they now say its the spider assembly on...
No.
The spider is one injector that supplies six small lines going to the cylinders instead of having one injector for each cylinder.
I would ask for a partial refund for parts and/or labor on the fuel pump job if that did not fix the problem. They should apply some or most of that cost to the cost of replacing the injector assembly if they diagnosed the problem as being the pump first.
Feb 20, 2014 | Cars & Trucks
How do you replace the fuel relay on a 2006 lincoln navigator
Its inside the fuel pump assembly. Unfourtunetly, you cannot buy it alone. You have to replace the entire fuel pump assembly (unless you can find the assembly at a junk yard and then take out the relay.
Oct 24, 2011 | 2006 Lincoln Navigator
The fuel gage of my 98 volvo v70 is not working, sometimes it work
In order to fix the fuel gauge problem, you will have to change the fuel sending unit. If the car has more than 100,000 miles I would recommend to change the whole fuel pump assembly, which would cost from $60-100 in the part alone which consists of the fuel sending unit, etc. This will definitely help your fuel gauge problem for sure.
Jun 23, 2011 | Volvo V70 Cars & Trucks
What are the most common problems with this vehicle.
According to msn.autos
http://autos.msn.com/research/vip/Reliability.aspx?year=2001&make=Nissan&model=Xterra&trimid=92964
Occasional problems on this vehicle are plugging of the Exhaust Gas Recirculation (EGR) Valve Passages (2.4L engine only) and failure of the Fuel Pump Sending Unit Assembly Connector Terminals. Plugged EGR Valve Passages may cause the engine to misfire and may also cause the Check Engine Light to illuminate. Failure of the Fuel Pump Sending Unit Assembly Connector Terminals can cause loss of power to the fuel pump leading to a crank and no start or an engine stall while driving. A periodic problem on this vehicle is failure of Distributor Assembly (3.3L only). The cost to repair the EGR Valve Passages is estimated at $10.00 for parts and $130.00 for labor. The cost to replace the Fuel Pump Sending Unit Assembly is estimated at $206.41 for parts and $195.00 for labor. The cost to replace the Distributor Assembly is estimated at $370.00 for parts and $39.00 for labor .All prices are estimates based on $65.00 per flat rate hour and do not include diagnostic time or any applicable sales tax.
Mar 09, 2011 | 2001 Nissan Xterra
How to change fuel filter 2007 Santa Fe Limited
The fuel filter on your vehicle is an integral part of the fuel pump/sender assembly located inside the fuel tank. It is serviced only as a complete assembly and cannot be replaced alone.
Dec 19, 2010 | 2007 Hyundai Santa Fe Limited
1987 chevy silerado truck is the fuel pump in the gas tank or where?
yes. you'll need to disconnect the fill tube that runs from where you put the gas in to the tank. Then undo the bolts that hold the metal straps that hold the tank up in place. lower the tank and disconnect the metal fuel lines from the assembly on top of the tank itself. turn the assembly cover counter-clockwise by tapping on the circular flange with a screwdriver and hammer. remove and replace the entire assembly. sometimes you can buy just the metal or plastic cyliner pump. if so you can save an awful lot of money. the entire assembly which includes the strainer and fuel gauge mechanism can cost $200-$300 , but the pump alone could be as cheap as $40. if you go the later route, take care with the fuel gauge mechanism. it is delicate...
Sep 22, 2010 | 1987 Chevrolet Suburban
My 2003 kia sedona is shaking and shuts down fuel guage broken
SOUND LIKE FUEL PUMP GOING BAD.YOUR FUEL LEVEL SENDING UNIT IS ALSO GOING BAD ITS PART OF THE FUEL PUMP ASSEMBLY.FIRST HAVE CAR SCANNED TO SEE WHAT TROUBLE CODES IS.REPLACE FUEL FILTER AND FUEL PUMP RELAY FIRST THEY ARE CHEAPER ROUTE THEY COULD BE THE PROBLEM.BUT FUEL PUMP COST BETWEEN $300.00 TO $700.00 THAT WHY CHECK FILTER AND RELAY AND HAVE IT SCAN BEFORE BUYING ANY HIGH PRICE PARTS.IF FUEL PUMP GOOD I BELIEVE YOU CAN BUY FUEL SENDING UNIT SEPERATE DONT HAVE TO BUY WHOLE PUMP ASSEMBLY BUT CHECK AROUND SOME AUTO PARTS PLACES WILL MAKE YOU BUY THE WHOLE FUEL PUMP ASSEMBLY JUST TO FIX THE FUEL LEVEL SENDING UNIT.
May 20, 2010 | 2003 Kia Sedona
Why wonty car get fuel in the carborator
91 Sevelle is operated using an electric fuel pump that is located inside of the fuel tank. Either the pump needs to be replaced, or, you have other problems and the computer is telling the fuel pump not to turn on.
I would suggest that you test the voltage going to the pump as well as the pressure on the lines using a fuel pump tester made for a Fuel Injected Vehicle.
If you attempt to spray a small amount of carb cleaner or WD40 into the throttle body and it tries to start when you crank it, you need a new fuel pump. You can spray a small amount of gasoline into the throttle body, reinstall the intake hose & try to start, sometimes the car will run until the fumes are gone. Use caution to prevent fires due to fuel getting onto areas other than inside the iintake/throttle body. Vent until fumes are gone if you accidently spill fuel to prevent possible fire caused by backfiring.
The fuel tank has to be removed to remove the fuel pump assembly, pumps are available as OEM or aftermarket pumps alone, or complete pump assembly. It is easier for those inexperienced to replace the entire assembly.
Good luck.
May 15, 2010 | 1991 Cadillac Seville
What is the cost of replacing the fuel pump on a 2000 chevy blazer?
Doing it yourself, the pump assembly which is in the gas tank, will cost anywhere from $120- $170. If you have to replace the straps on your tank the price on those vary
Nov 02, 2009 | 2000 Chevrolet Blazer
Nissan 2004 Altima fuel filter location and replacement ?
filter is inside of the fuel tank and its a part of the fuel pump assembly. you need to remove the bottom section of the rear seat via 2 clips at the bottom of th eseat.you need a special tool to remove the lock ring on the top of the fuel tank. you wil also need a new o-ring to close itback up. the whole pump assembly has to come out and disassembled to replace flter. good luck.
May 11, 2009 | 2003 Nissan Altima
Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi Logo
76 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
