Question about i-mate K-jam Smartphone
Wi-Fi Connectivity I have wi-fi enabled laptop, kjam and wi-fi router thru which i get inet connection. i can successfully use my internet on kjam, laptop and desktop but i can't make it networked or say connected thru either wi-fi or bluetooth for file sharing and other sharing work, even desktop and laptop is not getting connected for file sharing. my ADSL line, thru D502T is connected to DI-524 Wi-Fi router and thru that DI-524 router, thru cable my desktop is connected. All machine and my kjam can share internet and working fine. but it is not allowing me to share my kjam's GSM network which is packet enabled data service from my service provider. My phone works with that fine but my laptop (vista home basic) is not getting connected with bluetooth or wi-fi to either desktop or laptop. how to connect my phone to laptop ? even windows mobile device center on vista tells me that not connected but in device manager, it is stating connected. Any solution ?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 146 Answers
Login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 15, 2008
SOURCE:
I connected the phone to my wifi. But it wont go to any websites or mail etc.
Hi Shiela
Try the following as sometimes it's a simple setting missed..
Solution-1
On your phone under Settings>> WiFi >> Hold the Name of Your Network >> Now Click on Forgot Network.
Now reboot the phone & modem/router and try to connect the Wi-Fi again.
Solution-2
Pull out the phone battery while it is working & re-install after 30 second. Phone will reboot again now try to connect to network and check internet connectivity.
Solution-3
You can browse to Settings>> WiFi >> then press left menu key & Click on Advanced. Now check that Wi-Fi timer is not off. If Wi-Fi Timer is on then turn it off.
Now disable Wi-Fi & again enable it. Now check the connectivity on Android.
Solution -4 (Important)
Update your phone, Modem& Wi-Fi Router time and date to match the internet provider time and date. This is very important because 2 out of 10 cases are because of this issue.
Solution-5
Check the Internet connectivity after disabling the antivirus & mobile data.
May 01, 2016 | Cell Phones
Tip
Blu-ray player wi-fi ready vs. wi-fi built-in
Blu-ray players are getting more internet capable and any player made 2010 or later is probably going to have wi-fi or wireless internet connectivity. However not all players are the same. Some Blu-ray players are wi-fi ready while others are wi-fi built-in. What's the difference? Wi-Fi ready players need an extra part called a dongle or adapter stick to make them work with your wireless router and not just any adapter, typically only the one the player's manufacturer offers. Usually this will cost you an extra $80. But Wi-Fi built-in players already have the adapter in them and are ready to go without adding a part. Be sure to check if the player is Wi-Fi built-in, as this is what you want for wireless connectivity.
on Mar 31, 2011 | Audio Players & Recorders
Tell me how i resolve dns failed connection
ou can try these options. Please follow step by step instructions on your phone.
A. Reset Wi-Fi:
  1. Delete all the configured wireless connections.Settings-> Connectivity -> Wi-Fi -> Select Network
  2. Click on Forget
  3. Do this for all your connections
  4. Now Enable Wi-Fi again. And connect to router.
B. Using Static IP Address:
  1. Settings-> Connectivity -> Wi-Fi -> Select Network
  2. Make sure to disconnect the network if connected.
  3. Now open the network,
  4. Select Static IP
  5. Now you can assign IP Address
  6. Here are default ips (It may vary according to your router)
    IP : 192.168.0.2 or 192.168.1.2
    Subnet Mask : 255.255.255.0
    Default Gateway : 192.168.0.1 or 192.168.1.1
    DNS: any two of these =>
    • 4.2.2.5
    • 4.2.2.1
    • 208.67.222.222
    • 208.67.220.220
    • 8.8.8.8
    • 8.8.4.4
For screenshots visit http://www.samsungbadaapps.com/tips/dns-failed-error-on-wi-fi
Aug 12, 2014 | Samsung Wave 525 Cell Phone
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
How can get my wifi connections to my computer
things needed internet connection wi-fi router. wi-fi enabled laptop.
steps switch on router enable wi fi on your laptop check for availbale networks connect to the network. if asks key contact service provider
Jan 03, 2011 | Fujitsu Computers & Internet
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
How can i ins tall my rangemax dual band wireless-n router wndr3300 to my laptop to setup wifi in my house
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | Computers & Internet
Have a linksys router and adapter not sure how to install, my daughter wants to use her laptop but cant get the internet
http://1921.168.0.1
Thanks.
Aug 29, 2009 | Linksys Wireless-G WRT54GS Router...
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
i-mate K-jam Smartphone Logo
570 people viewed this question
Top i-mate Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
