Question about Acer Aspire One D260 Netbook
Double tap working
Mouse double click not working
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 153 Answers
Do you have a 'synaptics based' touch pad?
try;
- re-calibrate your mouse properties in control panel
- reinstall the touch-pad driver
Posted on Nov 25, 2013
3 Suggested Answers
SOURCE: i have just bought an acer laptop 5742 series and
hey
just go to control panel slect the mouse settings and resest the setting of ur mouse
if it doesnot works then go to device manger nd slect the mouse pointer then slect it kindly update ur driver through interenet and then after all installation then restart ur system\\
still not solve tell me where u got stucked
Posted on Jun 14, 2011
Testimonial: "thanx for that, all sorted now :-) x"
akee_akee
  • 96 Answers
SOURCE: I have an Acer Aspire One D260 and am having some
On your bottom right corner,seek akee_akee.gif or akee_akee.jpg >>>right click on it >>> setting >>> on TOUCH sections >>> TAPS >>> CHECKBOX the taps to click and taps and drags >>>apply >>> ok.
Note : if cant find any those icons >>> go to control panel >>> Pointing device >>> Mouse
Cheers
Posted on Aug 22, 2011
Please help me to find driver, I have installed windows 8.1 in my INSPIRON N4050 and Bluetooth Driver is not installed , i have searched for Bluetooth driver for 8.1 but i couldn't find it , while in...
To manually install a driver
You must be signed in as an administrator to follow these steps.
  1. Swipe in from the right edge of the screen, and then tap Search.
    (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, and then clickSearch.)
  2. Enter Device Manager in the search box, and tap or click Device Manager.
  3. In the list of hardware categories, double-tap or double-click the category your device is in and then double-tap or double-click the device you want. For example, to see your video card, tap or click Display adapters, and then double-tap or double-click the video card name.
  4. Tap or click the Driver tab, tap or click Update Driver, and then follow the instructions. 1f9463c2-c968-47bf-9b4d-939c5d1af477_70.jpg You might be asked for an admin password or to confirm your choice.
Jun 04, 2014 | Dell Inspiron Computers & Internet
Hp laptop synaptics touchpad light comes on and shuts off pointer
Had this problem before, very annoying! On mine the idea was double tap to disable the track pad and then double tap again to activate it... In reality tapping rapidly in the area around the LED until the LED shut off seemed to work.
In short; double tap the LED to reactivate the track pad. If that doesn't work tap several times in quick succession until the LED turns off.
Dec 18, 2012 | HP Computers & Internet
I have an Acer Aspire One D260 and am having some trouble with the mousepad. I can move using the touchpad but cannot click anything by tapping or double tapping. Also the left mouse click is not working...
Cheers
Aug 22, 2011 | Acer Aspire One D260 Netbook
I have just bought an acer laptop 5742 series and my son has been fiddling and am now unable to use the touchpad mouse to double tap to click, i am having to use the button underneath the touchpad. do you...
hey
Jun 14, 2011 | Acer Computers & Internet
My hp 4520s probook's mouse pad got locked accidentally, and it's not unlocking by double tapping on the light button on the mouse pad. please help me with this asap.
First, try double tapping the light again. You may have just mis-tapped.
Next try restarting the laptop. Certain laptops re-enable the track pad on restart so long as a USB mouse isn't connected.
If that fails, navigate to the Mouse Settings on your PC and re-enable it there. If you have a USB mouse you can use that. If not, you can use the keyboard. Windows Key will launch the Start Menu, arrow keys can highlight options, Enter will click on them, Control+Tab and Control+Shift+Tab will switch tabs (in a window that has tabs).
In Windows XP and 7 (and probably Vista), Mouse Settings is located at Control Panel > Mouse > Settings.
Mar 21, 2011 | HEWLETT-PACKARD ProBook 4520s
Mouse won't respond to a double tap
Hi, if you can select anything by one click and only the double click is the problem you should check into your mouse properties, go to control panal\hardware\mouse, in there you can adjust the duration between the two clicks to activate the double click function, you can adjust then check in the box beside the adjustment slider to the best setup that works for you then apply the settings... Good Luck
Jan 30, 2011 | Toshiba Computers & Internet
Double tapping feature on my touhpad seems to have got disabled. Pl advise how I can enable it
Go to start, control panel and look for the mouse. Double click on the mouse and a window with several tabs will open to change the settings on the mouse, including single and double click,
I hope this information was helpful.
Brian
Dec 24, 2010 | Computers & Internet
Gateway laptop running Vista suddenly developed an issue with the mouse pad.... double click doesn't respond. However the touch pad works to move the mouse
I have just had this problem with an Acer laptop running on Vista Home. When I double clicked on the actual pad itself rather than the bottons, it wasn't recognising it at all. Wouldn't scroll down or select a folder etc, just if I double clicked on the actual pad. Everything else worked OK.
I tried the solutions above but they didn't work.
Turns out it's the 'Tapping' function that needs to be enabled. Go to Start > Contol Panel > Hardware > Mouse > Device Settings > Then it says devices: and lists what pad hardware you have (mine is Synaptics Touchpad V7.2.
Under the box are 3 buttons Enable, Disable and Settings, presuming yours is enabled go to Settings > Tapping > Enable Tapping. Hey Presto! :-)
Aug 21, 2009 | Computers & Internet
Pointer will not "tap"
This can be set to tap for you as it is a simple setting in the mouse control panel.
Go to your start menu and open Control panel, select classic view in the top left corner if there are less than 20 icons(pictures) in the menu. Now double click on the mouse icon. Click on the advanced tab. then select your synaptec device in the list and click the properties button below.
There are several options on the menu, one will say "Tap to Click"
Check the box beside it and then click OK on this window and the mouse window.
Close the control panel by tapping the pad and you're on your way.
I hope this helps Fixya,
Chris
May 17, 2009 | HP TouchSmart tx2z
How do I disable double-click on an HP Pavilion dv4 touchpad?
Hi there Dublin. I recently bought a HP laptop myself, and I believe I can help your situation, or at least I hope I can. Here's what you do: Access your Control Panel>Click Mouse>Click Device Settings>Click Settings> Click Tapping> Click Disable Tapping. That should do the trick. You are not disabling your touch-pad, just the double-clicking that is associated with it. Drove me nuts for about a day, 'til I figured it out..Hope it worked for your notebook.
Apr 06, 2009 | HP Pavilion dv4000 Notebook
Acer Aspire One D260 Netbook Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
