How to connect sr6008 to view/play files from laptop via the lan
cnavarro
  • 2460 Answers
SOURCE: D-link DI-524 wireless - lan network connection
Yep. Vista sucks :-)
In the vista machine, you have to turn on a whole bunch of options. Right click Network, hilghlight properties and left click and it opens up Network and Sharing Center. Down at the bottom, you have a list of options. Start by turning on the options you need: File Sharing, Public File sharing, Printer Sharing etc. I'm pretty sure it's already done in the XP machine, but if not, check there too.
It should start to show network files between machines.
Carl
Posted on Oct 19, 2008
2Gigs
  • 141 Answers
SOURCE: WGR614 v6 will not connect through LAN????
Did you call NETGEAR already? Maybe your WEP was changed. If you can't fix this try http://technicalsupport.blog.friendster.com
Posted on Feb 16, 2009
m0bum
  • 94 Answers
SOURCE: lan connection between two desktops
if you mean in-game, go to multiplayer, then select Local Area Network (UDP)
Posted on Jun 19, 2009
  • 96 Answers
SOURCE: Unable to access my Laptop on My Network from my
To enable file sharing you need to follow the below steps
I moved this to networking for better exposure. I'll give you some basic tips, but it's generally pretty simple.
Turn off any firewalls for debugging. If the firewall is the problem, you'll have to configure it to allow access to "trusted zone" addresses. Note that some firewalls must be completely uninstalled to stop them from affecting your networking.
PING each computer by IP address, and if successful, PING by name. You can obtain the IP address of a computer by opening a command prompt (DOS window) and typing IPCONFIG. This should work for any Windows version.
All computers should be in the same workgroup for computer browsing to function properly. File & Print Sharing has to be enabled on any computer you wish to share files or printers from. You also need to actually share the resource in question from My Computer, right click on the drive/printer/folder, and select sharing.
If you encounter difficulties accessing computers that are visible in Network Neighborhood, make sure the computer being accessed has an account with the same name/password as the system connecting to it uses to login.
While the default NetBIOS setting is correct for normal network configurations, it's possible for it to be altered, and it costs nothing to make sure it's correct. NETBIOS over TCP/IP must be enabled for normal network browsing.
Let me know if this will help
Posted on Nov 27, 2009
  • 4 Answers
SOURCE: I can't connect to Edmini via LAN nor USB.
Just contact www.lacie.com great support. there answer for my drive was to upgrade the drive version and to reboot the drive. Maybe the last thing is enough. For me it worked.
If necessary update driver http://www.lacie.com/nl/support/drivers/driver.htm?id=10156
Follow the procedure below to reset the Network Space to factory defaults:
  1. Move the power switch to the OFF position. Wait for the drive to shut down.
  2. Turn ON the drive.
  3. Within about 3 seconds, flip the switch OFF and On several times.
  4. Immediately turn it ON
If the light flashes quickly, the unit is resetting itself. Attempt to connect to the drive again after about 1 minute using the default username and password (by default, they are both admin.)
Posted on Feb 04, 2010
How to connect a desktop and a laptop through lan
you will need to have a lan cable and also the need to create a lan network both computers
Jun 24, 2012 | Sony VAIO VGN-S460P Notebook
Hi I'm trying to play AVI files on my compac 6720s but it will not allow me to view them, how can I resolve this?
You stated an issue about playing/viewing AVI files on your computer?
I would suggest to go ahead and download an AVI file converter(w/c you can search via google or download via Filehippo.com)or get an AVI viewer/Player
(e.g. VLC etc./can also be searched/downloaded via gooogle.com or FileHippo.com)
Hope This Helps.
Thanks,
FixerDelta
Sep 15, 2011 | Compaq Computers & Internet
I want to start inter net from my laptop what to do
Hello Punitrava, Hi, you can connect to the internet several ways, here are the common ones. 1. Via a free WIFI hotspot, find a WIFI area like in malls or coffee shops and enable you WIFI connection on your laptop. after enable the laptop detects the wireless connection and simply connect. 2. Via a USB modem, inquire about this on your wireless telephone company. 3. Via the Local Area Network like computer shops, insert any available LAN cable on your LAN connection, you need to consult the LAN administrator. 5. Via a DSL connection, just plug in the LAN cable from a DSL to your laptop. you need a DSL/internet account from your telephone company.
Jan 08, 2011 | Compaq Tablets & eReaders
Have new laptop windows7, & old laptop windows XP, want to transfer photos & files from old to new laptops via iomega250gb. portable hard drive.when it is connected to either one a green light...
Why need IOEGA250GB ?, Please get a cross cable (LAN CABLE) and connect both laptop via RJ45 . Then do file transfer between systems. I think this is very easy steps.
Feb 26, 2010 | Computers & Internet
Hi trying to connect my dell laptop to pc
to connect a laptop to you PC you will need a broadband router(with min of 2 LAN slots) and connect both using the LAN network cables thru the router.
Then on both PC and laptop you need to create the local area network.
Start/Control Panel/Network Setup Wiz/next/next/No let me chose another...../next/other/2nd option This Computer connects...../Computer name...Give a name/next/MSHOME/next/1st option Turn On file and print..../next/Yes/Next/wait for a few min..../Last option...Just Finished the ....../Next/Re-start/
Do this on both PC and laptop
Now open My Computer icon/Clikc the up arrow button near the top the menu bar/
this will show you the My Network icon/click it and view all computers on the network
You need to do the above process on both the PC and laptop
once you can view the PC's shared folder in you laptop and Laptop's shared folder in you PC you are DONE.
just copy any files from your PC/Laptop to the shared folders on you laptop/PC and exchange files on both.
all the best
Dec 07, 2009 | Dell Inspiron 1501 Notebook
Can't see other computers in network
first,check properties of LAN of all computer...then check the FILE/PRINTER SHARING
second,OFF all windows firewall..
now,open your windows explorer to view other computers... jaz type in the address bar \\<computer name of ip address> of other computer you want to view
Oct 28, 2009 | Belkin Computers & Internet
DI-524 router printer sharing
All you have to do is that you will have to setup your Hp to share or to be seen by other machine on the network by going to the network properties then setting the network, file and folder on your hp to be seen and shared by other machine.
Sep 21, 2009 | D-Link AirPlus DI-524 Wireless Router
Carl
Oct 19, 2008 | D-Link AirPlus DI-524 Wireless Router
Videos wont play
Was the direct lan still through the Belkin router? Plug straight in to your cable, dsl, satellite modem and see how the video is. Next try pcpitstop.com and run a full test. Might just need to wipe temporary internet files or whatever that full test says. N/M their defrag if you have at least 1/2 of your harddrive empty..they always say that.
Aug 30, 2008 | Computers & Internet
Xba files
try getting daemon tools or other converting programs. today there are many programs you can use to view these types of files also if you just want to see it, then try getting vlc lan media player it plays just about anything.
Jan 20, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
David Payne
David Payne
