Sonya Portable Compact Laundry Dryer 110V 13lbs
2 Suggested Answers
Need user manual for Sonya compact dryer
Hi, could not find a users manual for sonya SYD-60E dryer so that I could order a thermal fuse, as the dryer would not run, however, I found a blog that suggested that Avanti, Sonja and Panda were made by the same manufacturer, I found a phone number for Avanti, ordered the thermal fuse for the only model that Avanti sells, which cost $10.00, and in about 10 business days the part arrived, we installed it in our Sonya dryer and our dryer works beautifully! Hope this helps
May 24, 2016 | Dryers
The belt will not stay on the pulley can someone help me
I put a thin spacer behind the tension pulley , just enough to correct the alignment.
Jan 19, 2016 | sonya Portable Compact Laundry Dryer...
How to thread the belt on the idle wheel and pulley without it coming off
Sheryl
should be doable as long as it does not have welded belt retainers,
if it has removable bolts or guards which help keep belt from falling off, remove these first. good luck
press the helpful button
the link below shows how to do it, but is not your model, hope it helps Dryer Not Spinning Whirlpool Kenmore Electric Dryer Repair Part 341241
Jan 18, 2016 | sonya Portable Compact Small Laundry Dryer...
Element not working
If this is a 220v it could be breaker or element if 110v might be element
Aug 30, 2014 | Sears Kenmore 3.4 cu. ft. Electric Compact...
Samsung printer 110v plug to 220v
You would have damaged the power supply section but in many cases the front end contains a surge protector with a variator which will short and blow the fuse. So check fuse replace and check for short in the input circuit of the power supply, if the Switch mode is damaged then you need to replace the unit with a 220 volt type or if only the 110 type is available then use a step down transformer to down the mains to 110V with about 0.5Amps
Oct 03, 2013 | Samsung WE356A5W Washer/Dryer Laundry...
Dryer Maytag LDE 9316 ACE -what is the capacity of that model dryer? Thank you!
Capacity is a key consideration when shopping for a dryer. The more you are able to dry in a single load, the less time and money you will spend doing your laundry. Most importantly, look for a dryer with approximately twice the cubic foot capacity of your washer.
Typical dryer capacity ranges from approximately 3.4 cubic feet (for a compact model) to over 7 cubic feet for an extra large capacitor
In addition to saving time by drying on fewer loads, and money on lower energy costs, a large capacity dryer often means spending less time once the laundry is dry. There is typically less wrinkling when clothes have more room to move around inside the drum.
Whirlpool brand offers dryers with a range of capacity and flexibility.
Dec 16, 2010 | Dryers
Not dry laundry
No I understand that .. Is your dryer 220V electrical source? If so it sounds like you have an electrical problem with the voltage supply to the dryer itself. I for some reason the dryer is only getting 110V that will allow the drum and dryer to function but the heating element will not .. You may need to talk to an electrician if you are capable of doing that yourself
Mar 27, 2009 | Speed Queen AES17AWF Electric Dryer
WA71N2 plugged to 220V should be 110V
The Fuse for these model is 110V - 250V, so definitely the machine will still light up for a moment then black out. So if you accidentally plugged it to 220V (if it is 110V) you have to change the whole PCB. Electric current are distributed by PCB which only handles 110V.
I suggest when you change the PCB try to change also the Fuse to 110V only so that next time if by accident it was plugged to 220V you just have to change the Fuse not the PCB.
I
Jul 09, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Samsung WA71N2, plugged to 220V should be 110V only
chang the board! servise center will charge probably 400sr
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
