Question about Kenmore 3.2 cu. ft. Top Load Washer
Washing machine water flows out of bottom as it fills and while it washes
I have an old kenmore washer that when it is filling it starts to leek water out of the bottom of it
    Problem Solver:
  • 11 Answers
The odds are that this means a crack or tear in your rubber boot that seals the bottom of the tank.  This is generally not a DIY repair and the cost of the replacement part can be way more than buying a similar (working) older unit at a garage sale.
It is also possible that some drain hose (or supply hose after the water valve) is dripping and you could find this out by removing the back sheetmetal panel and start filling... watch for where the drip comes from.  If it is one of the hoses, this would be much easier to try to fix.  With the back open you will be able to see all the  possible culprits :)
As a caution, with the back panel removed, the wiring is exposed and could be dangerous if you dont take the necessary precautions.
One other test you could do with out opening the back would be to slip a piece of cardboard under the washer after it has been sitting for a while and stopped leaking. Let it sit for a few minutes to ensure there is no leak (slide it out to confirm no leak).  then pour in about a gallon of water carefully into the tank  and see if the leak starts up again.  If so, this pretty well indicates the boot is leaking and you need to 'give your washer the boot'  :)
If it is not leaking , then pour in some more and if still not leaking,  think about opening up the back and finding where the leak is.
Hope this helps!
Posted on Oct 10, 2007
  • paul witort Oct 10, 2007
    The 'cardboard under the washer' idea may help isolate the problem if the leak only happens at  a particular point in the cycle.... eg. I had a 25 yr old kenmore that had a crack in the rubber boot, but it only leaked when the rubber was flexed...ie when the washer was in the agitation phase; it passed the 'pour a gallon in' test.
    Lastly, with a big enough piece of cardboard you can find the location of the leak (approximately) without taking the back sheetmetal off.  A leak from the rubber boot on the tank will show in about a 15-18" circle around the center of the washer; a drip from a hose will hopefully show more towards the back of  the washer.  Not a perfect test, but it could help..
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Jun 25, 2017 | Kenmore 24032\24036 Top Load Washer
Why wont the washer start filling ?
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 25, 2010 | Kenmore 23822 Top Load Washer
Kenmore 110 Washer fill hoses flowing the wrong way...
Both hoses must be connected to a valve or capped off.
Jun 08, 2009 | Kenmore Washing Machines
Kenmore/Sears 417.43142200 bleach dispenser not dispensing
Before you do anything, make sure that the plastic part in the bleach dispenser container is pushed in. Fill with bleach to the "max" line, written on the plastic part. Start the wash cycle and make sure that water goes into the bleach dispenser. Once water flows into the dispenser, the bleach/water mixture rises and should automatically dispense into the washer. We had this same problem. We removed the dispenser unit and took it to the sink. We then filled it with water and it started coming out from the bottom automatically. So sort of suction is caused from the amount of water and it starts to flow. Basically, you aren't adding enough bleach into the dispenser if the water flows into it as the wash cycle runs.
Mar 22, 2009 | Kenmore 43142 Front Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite washing machine will not fill as fast as usual.
You will need to get behind the washer, turn the water off, disconnect the hose from the washer, look for a screen inside the water valve, hopefully there is one that you can clean if necessary. I always put the hose over in the washer and turn the water on to check the flow.
If the screens on both hot and cold are clear, water flow is good on both hot and cold, connect the water back to the washer. If the flow is still slow then the problem is inside the valve. The valve will have to be replaced.
Dec 17, 2008 | Washing Machines
Over flowing washer
If the water valve not getting 120 volts and its start filling that means its bad water valve if its getting 120 volts bad timer
Nov 03, 2008 | Kenmore Elite 45986 Front Load Washer
Model# 110 20902990 kenmore washing machine over flows
hi thanks for the question you could have a water valve problem how do you shut the water off by unplugging power cord or shutting off water supply if its unplugging the power cord you have a problem with water control switch or lint is caught in small plastic tube that goes to the water level switch check that could be no parts needed thanks the appliance doc
Sep 27, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Open Questions:
See all Kenmore 3.2 cu. ft. Top Load Washer Questions
Kenmore 3.2 cu. ft. Top Load Washer Logo
93 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
