Question about Electric Lawn Mower
My lawn mower sometimes only hums when trying to start it. I will then turn it on it's side and turn the blade by hand a little bit. at firts it feels stiff but then feel like loosening. Then I can tu
This mower is about three months old. There is no smoke or smell or anything like that. once it starts it's running perfectly and also cuts perfectly. Just every time have to turn the blade by hand a little bit before starting it. Why could this be?
    Top Expert:
  • Electric Master
  • 41,918 Answers
The motor is failing.
Posted on Nov 25, 2013
4 Suggested Answers
jj505
  • 195 Answers
SOURCE: my lawn mower doesn't start -
You must check for a short in motor.
Posted on May 07, 2009
SOURCE: BLack and decker electric lawn mower blaDE IS loose and not turn
If it's like mine (MM 875), it has a plastic "clutch" that has little edges on it that broke off when I was chopping sticks with the mower ;-) Went to the local B&D place and got a new one for less than $3.
But now I'm worrying about the nut holding the blade on -- if I try to get it good and tight, the plastic "clutch" spins around off-kilter... Funny how I never even looked at the blade after I bought the mower used, but never worried about the blade being loose and flying off.
Posted on Sep 29, 2009
HansPP
  • 2510 Answers
SOURCE: my mowers blades are not turning but the hum of
It sounds like bearings are seized and need to be replaced. Too much attempted use will burn out the field windings and a rewind or new motor will be needed - both costly.
Posted on Jan 14, 2011
Why is my electric Black and Decker lawn mower still vibrating and loud after I replaced the blade insulator and fan?
disconnect all power and turn the mower on the side
turn the cutter blade /base by hand and watch the centre bolt or shaft
if it moves in a bit of a circle then it indicates that the motor shaft may be bent, causing the vibration at speed
Aug 03, 2015 | Electric Garden
How do you check to see if Drive pulley bearings are bad
take belt off, grab blade at end and watch center bolt move more than a little bit or swing by itself when turned loose. Try turn blade with hand to feel bearing roughest is another way
Jul 13, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn mower ran out of oil and stopped running put new oil in and still not running is there something to do after putting oil in to make it run
If you can turn blade by hand first removing spark plug you then can try squirting 30w oil into plug hole and turn blade by hand. replace plug and try to start. Depending on whether you gouged the cylinder it may start.
Jul 06, 2014 | Poulan Pro 22inch 625 Series Briggs ...
Lawnmower blade wont turn
Probably bent the shaft. Disconnect the spark plug to prevent accidental starting and lay the lawn mower on its side. Slowly turn the blade with your hand and watch the center of the shaft. If it wobbles at all it is bent. $150 to $200 job. Probably time for a new mower.
Mar 09, 2014 | Poulan Pro PR550N22SH 22Inch Briggs ...
My electric lawnmower sometimes does not start, just humms. Then I TURN IT OVER, AND TURN THE BLADE A LITTLE BIT. the blade feels hard at first but soon feels loose. then it wil start as normal
The lawnmowers electric motor has a bad spot on the armature. You need to replace the electrical brushes that contact the motor. If you are lucky you may just need to clean them and reinsert them in to brush holders.
Nov 25, 2013 | Electric Lawn Mower
The pull start cord will only move about 3-4 inches and then it stops and then cord stops, Troy built- Briggs/Statton 21 inch self-propel lawnmower.
The mower's drive shaft may need to be lubricated. If you turn the mower over and try to move the blade by hand (with the mower off, of course) does it move, or is it hard to move? If it's hard to move or it won't move at all, lubricate the shaft by squirting some WD-40, 3-In-1, or other lubricating oil onto the drive shaft where it meets the chassis of the mower. Squirt enough oil to cover the circumference of the drive shaft, then try to spin the blade again. It should at least spin a little bit now. Squirt some more oil and spin the blade again, until the blade spins easily. Then turn the mower back over and try to pull the start cord -- it should pull normally now.
Jun 05, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I changed the blade, and now it won't start!
Did you replace the blade with a heavier blade, or an identical one? If the pull cord won't pull, it's usually either the blade or the blade shaft causing the problem. Try oiling the shaft and making sure nothing is obstructing the blade from turning.
If you have a pair of heavy gloves, try turning the blade by hand and see if it moves. Squirt some oil onto the shaft where it meets the mower and try turning it again.
May 25, 2010 | Craftsman 22 in Precision Cut Lawn Mower...
Will not turn over. Installed new battery. Still
Hmm.. Could be that the motor is a bit stuck on the top of the compression stroke..
With everything turned off - turn the motor over a few time by hand - by turning the blade..
Then try starting it..
OR starter could be a bit stuck - try this.. While the key is turned like you are trying to start it - give the starter a little smack with a small hammer..
Hope this helps !!
Please rate me good ;o)
Jul 11, 2009 | Toro Lawn Mower With Toro Power Tools
Lawn mower died. Pull rope locked up
remove the spark plug and try to pull the rope. Sometimes the coil can get loose and wedge against the flywheel. if that's not the problem then pour a little oile in the spark plug hole, let it set a bit, if it still won't turn over then you have an internal engine problems. Not very common but it can happen
May 09, 2009 | Garden
Electric Lawn Mower Logo
370 people viewed this question
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
