Question about LG WM2101HW 4.0 cu.ft. Washer
Reverse door - LG WM2101HW 4.0 cu.ft. Washer
How do you reverse the door
If its a side by side like the one showing on your post, I doubt you can unless there is a spot showing for under the door, and the water and electrical lines are long enough to switch.
Mar 28, 2016 | Refrigerators
Why is my garage door suddenly reversing when going down?
Deb, that reversal is a child safety device - if the bottom edge of the door detects contact with any object, it'll immediately reverse so it doesn't kill a child. Or a cat, dog, whatever.
The opener mechanism should have a stop switch that prevents the door from closing hard against the floor - that stop switch needs to be adjusted so that the door will stop JUST before hard contact. That'll take care of it "bouncing" off the floor & reversing. As to it reversing before it touches the floor... examine both guide rails closely to see if there's any obstruction that the door's bottom edge may be contacting to trigger the child protection reversal switch.
Aug 04, 2014 | Sears Craftsman LiftMaster Chamberlain...
Reverse door
Good morning friend, I appreciate your post!
I see you are trying to reverse the door for your Frigidaire top mount refrigerator, FFHT2117PS. I have successfully located your manual and it provides step by step instructions on how to reverse your doors. Hope this helps. -Matt
Frigidaire Manual Search Results
Jul 23, 2014 | Frigidaire FFHT2117PS 21 Cu. Ft. Top...
How do you reverse the front door on a Kenmore HE4t washer?
The Kenmore HE4T washer does not have a reversible door. The matching dryer would have a reversible door.
Some newer washers do have a reversible door but it is still a very small number of washer that allow you to reverse the door.
You can not reverse the door on an HE4T washer.
Aug 21, 2011 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Can the Duet doors be reversed?
The dryer door can be with the purchase of a door reversal kit but the washer door cannot be reversed.
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Can the door be reversed? ie open from left to right-----hinge on right side If so do you have instructions on how to do it?
Due to the shape of the washer door, and how it seats against the control panel, the door cannot be reversed on the Duet washer. There are no cut outs along the door opening to accommodate the door hinge screws and the door latch on opposite sides. The Duet DRYER, on the other hand, CAN be reversed. This may be an alternative configuration for you. Let me know if you want to know how to reverse the dryer door.
Jun 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Reversing door
you can not change the way the door opens
Feb 11, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Reversing the Door
nope only the dryer doors are reversable..last washer to have reverable door that i know of was old neptune
Sep 07, 2008 | Kenmore Elite 45986 Front Load Washer
Washing machine doors
Electrolux has a reversible door for both front load washer and dryer. Just found that out at HHGregg because we need to put our washer to the right of the dryer, and none of the other makes will allow the washer door swing to be switched.
Apr 11, 2008 | Kenmore Elite 45986 Front Load Washer
Reverse Door
You can't reverse the washer door, only the dryer door.
They don't make the washers reversible because the door latch and wiring harness would have to be relocated to the other side. It just isn't practical from a manufacturing standpoint.
Sorry, Mike
Nov 04, 2007 | Kenmore 43142 Front Load Washer
LG WM2101HW 4.0 cu.ft. Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
