Canon ir 7095 make tif default
Heating unit indicating JAM at sensor PS6 but NO JAM
  • 168 Answers
SOURCE: Default Scan Resolution on Canon iR C3220
imm assumiing your using the send feature to scan to sett it up different ways in this order add functions communication settings this should bring up a screen with left and right colomns.. the left one should have a tx setting touch that and scroll till you find custom send settimgs
Posted on Dec 18, 2008
  • 58 Answers
SOURCE: canon IR 7095
if you can not use the finisher and the machine says Functions limited
press additional function
press common settings and then scroll to find limited functions mode if its on press the off button press ok and turn off the machine and then back on
Posted on Aug 07, 2009
  • 1297 Answers
SOURCE: Where is the left paper jam Sensor in the Minolta
Open the front door,remove the fusing unit(1 screw,2 connectors,ground plate wire in the back side),remove the exit lever(in this components is the exit paper actuator black colour in the right side).Change the actuator(it is damaged),and OK.
Posted on Dec 02, 2010
spinal
  • 287 Answers
SOURCE: I need to set a Canon IR 3025 so that the Scan
Hi fiona,
I am glad to help you.Press the "ADDITIONAL FUNCTIONS" button located to the right of the display. Select "communication settings". Now press "TX SETTINGS".Now press "common settings".Now press "Edit standard send settings". You will now see a screen that allows you to set the DPI value and file format.You will have drop down menus for each that allow you to change these settings. Once you have selected your preferred settings press the "OK" button located at the lower right. I have "FIXEDYA". :-) Rememeber, you can change these settings of a case per case basis on the main send srceen. Be well and smile when you get a chance.Please let "fixya" know I have helped. Thanx
Posted on Jan 24, 2011
abdulkarimap
  • 149 Answers
SOURCE: default Id & Password ir 3300 canon
I suggest you read the manual book canon IR3300.
Manual book, you can download here
Canon imageRUNNER 2200_2800_3300 Reference Guide
For additional materials, the solution to the problem IR3300 ID & password, you can read here
I hope this information helps
Posted on Nov 18, 2011
The canon IR 7095 image-runner that i need help with it has an error code E000578-8001
That error Indicates there is a malfunction in the finisher Unit . I am not sure if the problem is any of the delivery trays of a stapler error
May 17, 2017 | Canon Office Equipment & Supplies
Canon ir 7095 copier ADF too much paper taking in one time.
Check the paper thickness. It can be a problem. try with another paper.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 14, 2016 | Canon imageRunner 7095
IR 7095. Como puedo reparar marca el error E00020?
Lo que indica es que a pesar que tiene toner la tolva sigue indicando que no hay toner. Posible obstrucci?n en el paso del toner o sensor de toner de la tolva defectuoso
Jun 19, 2015 | Canon Office Equipment & Supplies
Canon ir c2550 error code e000025-0001
Dear
The error code indicates the toner is not supplying for (Y). The hopper motor is locked. The probable cause the sensor is not detect within 5sec. when motor is on at hopper assy. Check. the sensor,clean-replace,check the jam of motor gears,check the harness up to DC con board, check the DC con board.
Thanks.
Jan 14, 2015 | Canon Office Equipment & Supplies
Paper jam indication but inside no paper
Double check for a small piece, and clean and hit reset, and or unplug unit and see if it clears and starts back normal
Jan 12, 2015 | Canon Ir 2022 Copier [new]
ERROR CODE IN IR 7095 EOOO2- 0001
this error refer there is a problem in the fixing unit, check thermistor and clear that error from service mode
Apr 13, 2014 | Canon IR2870 COPIER FOR 220 VOLTS ONLY
Hello , i have cannon IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
Open your developer unit and check sensor , refix it an close unit see........your problm solved
Apr 22, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Canon IR 7095, error code E000005-010
Hello to all
I have a client server ir Pass has forgotten his password and I reset.
how reinitialiser server S2 canon ir Pass?
Thank you for the help.
Dec 27, 2012 | Canon Imagepass S2 Fiery For Ir...
Canon iRC 3380i error code E00025-002...help please?
Service Bulletin
Issued by Canon Europa N.V. Copier Color
HARDWARE
Revised:
Addition of the Affected Machines
Hopper Assembly
Subject:
Measures against E025 error due to toner leak
Detail:
<Symptom>
The toner leaking from the toner cartridge flows onto the inside toner sensor (PS3/PS4/PS5/PS6), causing erroneous
detection and E025 error (Error in the toner motor).
Model:
iRC2380i
iRC2880
iRC2880i
iRC3080
iRC3080i
iRC3380
iRC3380i
iRC3580
iRC3580i
Ref No.:
iRC3380-023 Rev. 2
(F2-T01-NO1-10097-03)
Date:
January, 2009
cartridge, the toner in the supply route between the toner cartridge and the
hopper may leak between the gap between the toner cartridge case and the holder of the machine.
<Factory Measures>
The gap between the toner cartridge case and the holder of the machine is covered with the plastic sheet and the shape
of the front unit cable guide on the toner sensor is changed to prevent the toner from flowing onto the toner sensor.
P-1 Position where the toner cartridge is installed
nside and replace the front unit cable guide into its new type.
Points to Note About Service Work:
When the front unit cable guide is replaced, implement periodic cleaning (every year) for the area around the photo
sensor (PS3/PS4/PS5/PS6).
For the affected machines or later, implement periodic cleaning (every two years) for the area around the photo
sensor (PS3/PS4/PS5/PS6) and the area of toner leak [1].
Service Parts:
Supply of the new part(s) will follow a normal supply pattern.
P-2 GUIDE, UNIT CABLE, FRONT
[2] Change Point
Parts Number Description Q'ty Interchange
ability Fig No.
Old FC6-9380-000 GUIDE, UNIT CABLE,
FRONT 1->0 N
620
New FC6-9380-010 GUIDE, UNIT CABLE,
FRONT 0->
and later IR C3580 230V EUR : CZS00218 and later
IR C3580I 230V EUR : CZT04670 and later IR C3580 230V : CZU00011 and later
IR C3580I 230V : CZY00752 and later IR C3580I 230V AU : CZZ00857 and later
IR C3080 UL 120V : DBE01554 and later IR C3080I UL 120V : DBF02861 and later
IR C3080 230V EUR : DBM00294 and later IR C3080I 230V EUR : DBN10330 and later
IR C3080 230V : DBT00011 and later IR C3080I 230V : DBU00714 and later
IR C3080I 230V AU : DBV01085 and later IR C2550 UL 120V : DCA03694 and later
IR C2380I 230V EUR : DCF16473 and later IR C2550I 230V : DCK00864 and later
IR C2550I 230V AU : DCL01033 and later
Jun 15, 2010 | Canon C3380i Color Copier
I have a canon ir2200 that is saying paper jam on front left. I can find no paper jam anywhere and have checked to see that the dials on the paper trays are set correctly. Also I have turned copier on and...
I am Sunil choudhary resident in Junnardeo dist. Chhindwara, My machine canon ir 2200 b&w machine -Miner problem paper jam-some move paper & right side jam paper & jam indicator show
Jan 11, 2010 | Canon imageRUNNER 2200
jasbo
jasbo
