Question about Coffee Makers & Espresso Machines
Merol brewing unit - Coffee Makers & Espresso Machines
2 Suggested Answers
SOURCE: merol coffee machine "me 710"
I bought a Merol ME710 coffee machine havn't used it yet cause it keeps saying ventilate and the touch screen goes no further please help ,I'm going crazy
Posted on Jul 19, 2011
Brew Unit Blocked
open the door and see small screw in the middle of the brew unit. Take it off with small screwdrive and pull out the brew unit.Then put the small thing (something like a pipe) to the brew unit with the small screw. Then without brew unit in the machine press the switch inside the machine where stayin the brew unit and the switch witch is stayin the top of door .Switch on the machine and wait while self test is making,then put the brew unit in the machine and that it.Enjoy!
If you have any question -ask me.
Nov 25, 2013 | Saeco Royal Professional Espresso Machine
Sometimes the pucks do not fall into removable container. How do I fix this?
Make sure the swinging arm at the top of the brew unit moves easily. Check nothing on the brew unit is damaged. Servicing the brew unit might help.
Brew Unit
The transmission can wear out prematurely due to the brew unit becoming stiff. The piston in the brew unit should move smoothly and fairly easily. Keep the brew unit in good service by occasionally removing the piston to clean and re-grease the two big red o-rings using a food-safe grease. To pop the piston out the top, gently remove the plastic u-clip from the base of the shaft underneath, paying attention to which way up it goes for reassembly.
Jan 22, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
Brew unit blocked message The brew unit removed and switches jumped, motor turns message still blocked brew unit . what could it be and ways to tests.
I had the same issue. Very difficult to fix. You must remove brew unit and reset the machine while apart. You must trick the machine to think brew unit is installed and door closed. Look at door and brew unit and use screwdriver or butter knife to engage machine and run through cycle to reset.
Jul 09, 2011 | Starbucks Saeco Italia Digital Barista...
Merol coffee machine "me 710"
Feb 18, 2011 | Coffee Makers & Espresso Machines
Syncrony Compact Digital unit- Used well for 5 yrs without incident. Currently, after bean grinding and tamping stages, a strange, non metallic rumbling/grinding sound occurs just before the...
First clean the screen and tube on the brew unit, then lube the guides/gear grooves on the brew unit, also lube the o-ring(big red one). Then that should take care of it. You can also try backwashing/degreasing the brew unit if the machine has a preground chute.
Feb 07, 2010 | Gaggia Syncrony Compact Digital Espresso...
Insert Brew Unit
hi
If the brew unit (the dark gray thing inside that has "push" on it) is not locked in, you get this message.
Push in the center of the brew unit towards the back and see if you hear a click? If you don't, remove the brew unit and look in the back. Behind the brew unit there is a recess. Inside the recess is a verticle slot. There should be an arm the moves from top right to bottom left. If you don't see this arm, thats your problem. It will have to be serviced to replace the arm. Its caused by inserting the brew unit with the funnel down (not locked up). Remember to push the "Push" lever before inserting your brew unit.
Jan 01, 2010 | Saeco Incanto Classic Espresso Machine
Cleanded brew unit as instructed - brew unit miss error
check small switch behind brew unit in machine maybe your brew unit dont touch switch.
Aug 30, 2009 | Saeco Royal Digital Plus Coffee...
Gaggia Titanium Brew Unit Blocked
Check the shower screen on the brew unit.
Aug 04, 2009 | Saeco Incanto Classic Espresso Machine
Brew unit wont go back in in seaco incanto
There is a flag on the back side of the brew unit. Below the flag are 2 plastic bars that the flag slides in. Push in between the 2 bars and see if the flag will drop. If it does holding the brew unit with your right hand, take your left hand and place it on the bottom left side of the brew unit, then with 2 fingers reach up inside the bottom and grab the bar in the center and squeeze the bar to the left. This will bring the cylinder back into position and align the 2 triangles on the front of the brew unit. Once they are aligned push the lever to the right to lock up the brew unit. Leave the brew unit out, but everything else in place, then turn the machine on. Once
the machine is settled open the door, remove the drip tray and then insert the brew unit, drip tray and close the door.
Apr 26, 2009 | Saeco Incanto Classic Espresso Machine
Brew unit
Make sure you have brewing unit in start positions, if you have a press on your brewing unit make sure to press it to you hear a tick, then you can fit it in the machine.
Mar 02, 2008 | Saeco 762111651808 Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
