Question about Teac AD-600 3-Disc CD Changer
Cd doors won't open - Teac AD-600 3-Disc CD Changer
    Genius:
  • 1,175 Answers
Hi...Make sure its unplugged and take the top case off. Check for items that arent supposed to be there like a CD floating around inside.
Or a cookie.
I'm not sure if this unit uses a belt for the drawer but check on that whilst youre in there
Posted on May 08, 2009
I have a Dell Inspiron 1525 with a cd in disk drive. The door will open but disk won't come out. What do I need to do to remove it?
The CD is loose in the drive. You need to remove the CD drive from the computer and then remove the metal case off the drive then you can remove the CD. Put the metal case back on the drive and install the CD drive back into the computer.
Mar 21, 2013 | Dell Inspiron 1525 Laptop
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
The cd door won't open on the tower
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Feb 16, 2013 | ZT Group Cisnet PC Desktop
Cd wont open
Take a large paper clip and open it.....there is a small hole below the tray usually on the right side. Push the end of the clip to manually open the drive.
Cd door won't open
Sometimes a belt breaks or comes off you need to check inside to see if this has happened.
Dec 28, 2012 | Audio Players & Recorders
The door won't stay open when putting in a cd on my Technics SL-PG350
JUust get a different CD- Player ,It will cost you less then to have it repaired, WHere i live i can get a good used one for $10 to $30 at the most, End they are not hot,
Nov 25, 2012 | Technics SL-PG350 CD Player
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
CD changer won't open. Mechanical Error on display
There is a small hole just above the door on most CD changers. Unwind a small paper clip and GENTLY push it into the hole. This should release the door, and let you look inside. Don't force it because you could damage it more than it is already.
Jun 15, 2012 | Yamaha GX-700 Shelf System
Cd won't open
On the face of the CD drawer there should be a small hole the size of a paper clip. Push a paper clip end into the hole, this should release the door and it will pop open.
May 08, 2012 | Everex IMPACT GC2500 PC Desktop
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Teac AD-600 3-Disc CD Changer Logo
228 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
