What is the meaning of error EA in my top load electrolux ewt604s
Error EA
catriver
  • 878 Answers
SOURCE: F2 error code
Chia, this is not a good one, F2 is a keypad failure or interface mismatch. You can try a couple of things. 1. unplug the washer for a minute and see if the code returns. 2. Remove the consol to access the control board, three screws on the backside and the consol lifts up. On the right side you will see the main board. On the right side of the board, center harness will be the interface ribbon cable. Reseat it a couple of times. If this doesn't work, I believe you will have to replace the touchpad. Catriver.
Posted on Jan 13, 2008
SOURCE: Error code E10 on the
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
Posted on Jul 22, 2008
torres No9
  • 27 Answers
SOURCE: Hi, I have an Electrolux EWF1087 which is flashing
HELLO GARY E50 error is to do with the motor, it can be the motor power supply triac has got a short circuit or there could be no signal from the motor tachometric generator, which will uaually mean a pcb fault, or wiring to motor or even the motor. hope this helps
Posted on Jun 25, 2010
  • 1416 Answers
SOURCE: What does the error message e20 mean on a front
hello,
what this sign means or indicate is an error code indicating that there is an over flow of water in the sensor / lens reader circle.
what you are to do to fix up this problem is to unscrew then washer then clean up all form of water or any form of liquid substance around the wire connected to the panel on the screen carefully do this assignment with care and avoid disconnection on other wire connection then couple it back has it was then problem of the e20 (error)is solve.
please note this,
PUT OFF ALL FORM OF POWER SUPPLY CONNECTED TO THE WASHER BEFORE DOING THIS ASSIGNMENT.
Thank you and thanks for using fixya.
Posted on Jul 09, 2010
SOURCE: ELECTROLUX EWIA12F3MS ERRORS
An E3 Error Code means the meter is sensing that blood has already been applied to
the test strip (or the strip has already been used).
What to do: Please make sure you see the flashing blood drop on the display before
adding the blood sample. Ensure that you are using a clean, new strip each time you
perform a test.
Posted on Jul 31, 2012
Hi Electrolux cooker 607601 error code 4 f on the top oven when using the grill what does that error code mean. Kind regards
It is good practice to specify model of appliance
(like EOG9330XN).
Probably means temperature range of oven sensor exceeded
(for more than 5 seconds).
Dado
Jan 10, 2015 | Electrolux Ovens
E4 always appears on the display of my electrolux ewt604s, what is the quickest solution to fix the problem?
http://www.electrolux.co.nz/Support/Manuals/?modeld=ewt604s
No easy answer.Electrolux does not recognise your model number or list error e4. I can only wish you good luck. and a few links that may help. Phone numbers and address at web address above.
If it won't open, copy and paste to your browser bar.
Electrolux Dishwasher Parts Accessories
electrolux dishwasher troubleshooting YouTube
Sep 13, 2014 | Dishwashers
Electrolux ewt604s top load washer
how to install magic hose to faucet. it leaks like hell
Dec 24, 2012 | Electrolux Washing Machines
Electrolux EWT854S
Bagaimana cara memperbaiki mesin cuci elextrolux EWT854S yg kode kerusakan nya EA
Aug 24, 2012 | Electrolux AWT1012 Top Load Washer
I have an error code "EF" for my Electrolux
Generally, EF error is showed with an additional number on your display... EF 1, EF 2, EF 3, EF 5, EF8, or EBF.
Each error code will depict a different cause and solution. Out of these solutions, the most common is the control board and possibly the UIB (User Interface Board), or too higher mains voltage coming into the house, causing damage in this UIB device.
Test and check voltage, if this isnt solve it, relace UIB device.
Hope this helps.
Mar 05, 2012 | Electrolux EW1200i Front Load Washer /...
Hi, I have an Electrolux EWF1087 which is flashing an E50 error message. Can you tell me what that error message means? Thanks Gary.
Jun 05, 2010 | Electrolux EW1200i Front Load Washer /...
Error codes for Electrolux front load washer EWF 1087
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
May 21, 2010 | Electrolux EW1000i Front Load Washer
Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Mar 07, 2008 | Electrolux EW1200i Front Load Washer /...
Washing Machines Logo
249 people viewed this question
Top Washing Machines Experts
