Question about HP Wireless Optical Mouse
How to turn this dang this off? it keeps eating up batteries?
  • ldicarlo May 09, 2009
    Yep, I have been looking for a solution as well. Not even HP knew what I was talking about.
Sorry, I thought this was a "free" site. I solved the problem, I threw the worthless pice of **** in the trash can!!!!
Posted on May 08, 2009
I have a 2002 mitsubushi montero sport. The brake/battery light won't go off. I replaced the battery yesterday and car starts and stays running but lights seem a little dim and the dang brake/battery...
CHECK ALTERNATOR DRIVE BELT COULD BE LOOSE NEED ADJUSTING OR GLAZED NEED REPLACING. IF ALL IS GOOD, CHECK ALTERNATOR VOLTAGE OUT PUT AT BATTERY SHOULD BE 13.5 - 14.5 VOLTS. IF NOT ALTERNATOR FAULTY BUT CHECK ALTERNATOR BATTERY FEED AND VOLTAGE REGULATOR WIRES FOR LOOSE CONNECTION OR DAMAGED FRAYED WIRES. CHECK ALTERNATOR FUSE.CHECK THOSE THINGS BEFORE BUYING NEW ALTERNATOR.FIRST TURN OFF RADIO BEFORE DISCONNECTING BATTERY CABLE TO KEEP FROM LOCKING OUT RADIO.
Aug 05, 2011 | 2002 Mitsubishi Montero Sport
Battery problem
Try upgrading the firmware on it. It depends mostly on what you are using on the device. If you do a lot of data-centric things like constant emailing, surfing the web, YouTube, etc. then you are going to use more battery. Applications running in the background also eat up battery life to keep active. Bluetooth uses more battery compared to using the phone itself. Lots of texting eats up battery life as well, both incoming and outgoing. Wi-Fi eats up battery like there is no tomorrow on just about any device. The TouchFlo 3D interface also uses more battery due to the graphics acceleration. You can turn off the TouchFlo interface to save battery power and go back to the regular Today screen. The device was tested for battery life with TouchFlo enabled however so that's more of an icing on the cake type of change for more power.
You may also want to try deep cycling the battery to see if that helps. Run the battery completely dead so it won't turn on the device anymore. The let it charge for 10-12 hours without the device on. That should cycle the battery and recalibrate the meter.
There are many diffferent reasons you could have lower battery life, it's always different for different people. HTC managed to keep the Touch Pro's battery life around the same as the Mogul even with the graphics acceleration and everything running. So simply turning off TouchFlo will probably increase total battery life by a bit.
you could upgrade to a higher MAH battery too.
(gsm version if you unlocked to use a sim chip)
here
(cdma if it has no sim chip)
here
Jan 10, 2011 | HTC Touch Cell Phone (Unlocked) - Soft...
My tv it turn off by it self and keeps blinking and wint turn on
Bad Capacitors in the Power Supply cause this, Dang China Made Capacitors keep me busy.............. Larry
Oct 08, 2010 | Olevia 237T 37 in. LCD TV
The batteries run out and the camera shuts off... NEW batteries... Why is this camera EATING batteries??
Check your settings to see if you have a lot of alert sounds turned on. If every shutter move, power up, power-down, emptying the trash etc has a sound alerting you to what you are doing, it could eat up batteries faster. Turn all that sound stuff off. Its annoying to hear a sound FX shutter click anyway.
Jul 23, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Dogz 5 feeding problem
it pushing the bowl away i sugest unstaling it then re installing it
Jun 11, 2009 | Video Game Consoles & Games
Eats battery in seconds-gets hot.
try hooking it up to the computer to get them off. If not You will probably have to loose the songs. That happened to Me. I had to get another player. Hope that helps.
May 24, 2009 | GPX MW3337G
How to easly change the starter
On most all front wheel drives the starter is located at the front side of engine where the transmission and engine connect just above the oil pan. There are three bolts two from engine side and one from transmission side. You may say more that dang while making change but it isn't a big complicated thing to do. Make sure to disconnect battery,< Positive and then Negative " always do this way>, and keep supply wires to starter together and install correctly. On the bolt setup don't quote me as they vary and this is common way for them.
Apr 25, 2009 | 1994 Mercury Tracer
HP Wireless Optical Mouse Logo
108 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
