My bcm adapter will not load and I can't access internet
Claims do not have internet access when it shows in notifications, will not load at origin.
Test your device at a hotspot. Setup internet access in setting.
If with free cab't get access, your wifi adapter is not working and if device is in watrranty, should be repaired
Jun 04, 2015 | Tablets & eReaders
How do you access the internet
You need a working internet connection and a browser in order to browse the internet.
Mainly there are two ways of accessing internet
1. through a wifi adapter(wireless)
2.Ethernet adapter(wired)
May 27, 2015 | Internet Computers & Internet
DOWN LOAD DRIVE
1. Use a computer that has internet access and go to http://support.linksys.com/en-us/support/adapters/WMP11.
2. Click Dowloads Tab and download that driver that you need.
Feb 28, 2013 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
I am connected to the internet but my netbook internet explorer will not load up any websites
Please check that your network adapter is really connected to an Internet source (i.e. cablemodem, router, access point), then according to the used network adapter (i.e. Ethernet, Wireless), look into its state, it will show you if you have a local (limitted) connection only or a Internet connection, if happen the first and you have anothers PC having Internet in the same network, it means that your network adapter is misconfigured or failing.
Feb 25, 2011 | Sylvania Digital Gadgets GNET28001BO...
I can connect to the access point but it will not let me connect to the internet.
Do you own the access point?
If so, after connecting/authenticating to it, start Internet Explorer, and access the web-server "inside" the access point. Click to select the 'WAN' settings, and confirm that the access point is getting an IP-address from the Internet.
Jun 15, 2010 | Linksys WPC54G Wireless-G Notebook Adapter...
Presario c700 ISATAP adaptor no internet?
you need to connect directly with an ethernet cable. then go to the compaq/hp website and go to product support and drivers subcategory and look up isatap adapter driver
Mar 02, 2010 | Compaq Presario 700 470024-192 Notebook
I can not get win explorer to load a page it is ibm think pad a21m running win 2000. i can't get it to load a page
Are you sure you're connected to the internet? Is your LAN working? Go to control panel, system, hardware, device manager and find your network adapter(s). Click on it and see if it is working. Do you have a wireless? Do the same thing. Access to a USB wireless you could try? Install it, connect to the internet and see what happens. Sonetimes the LAN adapter in the computer will go bad.
Dec 07, 2009 | IBM ThinkPad A21m 2628 Notebook
Is it possible to use a gaming adapter with a pc
yes. you can use the gaming adapter on your PC as a wireless adapater and connect wirelessly to the wireless router to gain internet access.
Jul 16, 2009 | Linksys Wireless-G Game Adapter [ WGA54G ]...
Can't configure router so my adapter can access my network
Use the XP to config Router.
Your 98 and your router are on different SUBNET check it.
Connect XP computer to Router using lan cable
Be sure to be on same subnet
Configure your Router
SEt same subnet for every PC connected to router.
Then connect to router using Wlan.
Feb 04, 2009 | Dynex Enhanced-G Wireless Broadband Router
Wireless network ok but cannot connect to internet from wireless adapter. Was working but now i cannot access the set up disc. No internet or modem lights on router ?
direct CONECT TO INTERNET AN DOWNLOAD DRIVERS AFTER UNINSTALLING OLD DRIVERS. REBOOT AND SYSTEM WILL SEE ADAPTER AND LOAD DRIVERS FOR SETUP.UNPLUG ADAPTER UNTIL DRIVERS ARE LOADED RICHARDM69
Dec 01, 2008 | Belkin Computers & Internet
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
