Question about Konica Minolta Office Equipment & Supplies
Di470 error code C1450 - Konica Minolta Office Equipment & Supplies
Error Code c0045
Bop. Error Code c0045. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.officeimagingsystems.com/id169.html
Konica Minolta Di450 Error Codes
http://www.biz.konicaminolta.com/download/users-guide/c554e_c454e_c364e_c284e_c224e/en/contents/id16-_101076518.html
Aug 25, 2016 | Konica Minolta Minolta Di450 Di470 Di550...
Erace the c-of24 on di450
The code refers to a sensor that looks at the drum - it might be dirty or something else is going on check this Fixya-link: Minolta DI450 error code C0F24
Jan 17, 2015 | Konica Minolta Minolta Di450 Di470 Di550...
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
May 03, 2014 | Konica Minolta Office Equipment & Supplies
Minolta DI450 error code C-0920
1st paper draw lift motor is jammed or burn out or the control board is bad. Check for paper behind the draw, also remove any paper from left side of draw.
Dec 26, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
(C-0500) error code konica di 470
There is a trouble rest button inside the front door above the fuser unit. There is a small panel with one screw in it, remove the cover and you will see a PCB with two black switch's on it. One is the trouble rest button, have the copier ON and press the trouble rest button and close the door and you are done... If it will not rest, check what you did and make sure it is put back correctly.
May 06, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
Kodak easyshare c1450 lens stuck open lens obstructed
You need to remove the batteries and remove the memory card. Then reinstall the batteries. Finally, press and hold the "ok" button, the power on the camera. This is a factory reset trick. It fixes approximately 40% of all error messages on the KODAK EASY SHARE CAMERAS. But of course, no one is gonna be kind enough to help somebody out, they just want to take your money!
May 19, 2012 | Kodak Genuine Easyshare C1450 Lens And Ccd...
Minolta Di470 Error code C-0F24
COF24 is an AIDC or Automatic Image Density Control failure code. It means that the machine can not properly detect the developer to toner mixture or ratio in the process/developer unit. This can be caused by an AIDC sensor failure, Developer Drive problem or for some reason the machine is not getting toner as it should. Has the machine been running low on toner?
Before calling for service I would try resetting the code by opening then closing the front door(s). Do this a few times and see if the code will go away. If not then you will need a service person to diagnose and repair which part is defective.
Good Luck and Thank You for using Fixya.
Apr 22, 2010 | Office Equipment & Supplies
179 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
