Question about Dell Inspiron One 2305 Desktop Computer (AMD Athlon II X2 GB3GB) (DDPCEZ1P)
DISPLAY IS PIXELATED AND COLORS MAY BE DISTORTED
Colour setting keeps reverting from 32 bits to 8 bits
Turn the laptop on and hold down the "Fn" key on the laptop's keyboard.
Tap the arrow key that has a picture of an open sun to make the laptop screen brighter.
The laptop will automatically save the adjustments after you release the "Fn" key.
Tap the arrow key that has a picture of a filled-in sun to make the laptop screen darker.
Screen Resolution
Click the "Start" menu. Click "Settings" and "Control Panel."
Choose "Display" and "Settings" in Windows 98, ME or XP. In Windows Vista, click "Appearance" and "Adjust Screen Resolution."
Click on the resolution bar and slide it to the right to lower the screen's resolution and to the left to raise the screen's resolution.
The optimum screen resolution usually depends on the size of the laptop screen.
The recommended resolution for a 15-inch screen is 1024 x 768, 17- to 19-inch screen is 1280 x 1024, and 20-inch screens is 1600 x 1200.
However, you can adjust the resolution to your personal preference.
Click ""Apply to see how the resolution looks on the laptop's monitor.
Click "OK" to save the resolution settings.
Color Setting
Click "Colors." Choose 32-bit for a high color-pixel ratio that will make the colors brighter and bring out image details.
Choose 24-bit for a medium color-pixel ratio if the screen is too bright or if images are somewhat distorted.
Some older laptops have a 16-bit color setting, but this setting is no longer recommended as it will distort images and text.
Always Click "Apply" to see how the color setting looks on the laptop's monitor.
Click "OK" to save the color settings
hope this helps
Oct 14, 2012 | Computers & Internet
Strange missing pixels/ discoloration for SNES
Hi the prob is the snes system itself its getting worn out
Apr 08, 2012 | Nintendo Super NES Console
Visio Strange Color/Pixel Problem As of now, every time i turn my 32" Visio HDTV (VX32LHDTV10A) on, certain areas and colors are going crazy and it has progressively gotten worse over the past...
The tv main Tuner signal board it is the causes and the problems.The board it is dying and shorting out.U have some mechanicals skills,like take things aparts and putting it back togetther again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv main Tuner signal board for the replacement.
Jul 14, 2011 | Vizio L32 32 in. LCD HDTV
The picture is distorted by both vertical and horizontal lines (different colors; pixelated)
A distorted picture display soon after the Plasma TV is powered on has two indications. First, a picture display of pixels when the TV is powered on is usual prior to signals of video movies are acquired from broadcasting station. The movie from braodcasting station should display without noticeable objects of distractions. For example, the movie displeyed on the TV without obstructions is indication that the problem is from the display set. Alternately, movies with poor capability to display on the set is indication that the media from which motion pictures are acquire from is malfucntioning. For example, a TV connected to cable network or disk network or satellite broadcasted signals with receptive compromises are diagnosable from two areas. First, a clarification from the network station that has setup connectivity of devices. Perhaps a device in the setup is malfucntioning. Second, attempting the adjust the phsical connections that are attached to the TV is capable of resoving the problem. Refer to the user guide for what is default expectation on powering on. Thereafter consul technical experts if required. Good luck
Jan 08, 2011 | Philips 42PF9630A 42 in. Plasma Television
My Samsung T4665F has a start up problem. Initially Relays click then eventually it starts up but with colored pixels over the whole screen. Then I have to switch off/on one more time and the pixels go...
This tv 100% have power supply board problems and might also have the T-CON decoders board problems too.The power supply board,that the board,where the power a/c cord plug into it.The T-CON decoders board,that the board sit wright in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.Replaced the power supply board,should get ur tv power up right away and work,no more series of clickings noises.But,if the tv still have alots colored pixels lines on the screen.The T-CON decoders board it also dead.Replaced the T-CON decoders board too.
Oct 29, 2010 | Samsung LN-T4665F 46 in. LCD Television
Samsung DLP model#HLP4663w.green hue on the screen,what is the solution to my problem.
Hi,It sounds like it could be the color wheel or DMD.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. The DMD is another possibility.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q One simple test is to display menu and if it's affected then most like will be an issue w the DMD board.Found the complete set with color wheel and DMD included here: http://www.discount-merchant.com/SAMSUNG-30407272050-Light-Engine-w-Color-Wheel-p/1139314.htm Have a blessed one!
Apr 05, 2010 | Televison & Video
Lamp light on front of tv stays on, it is amber in color
Hi,do you mean tv is showing an amber picture? If you do,it could be an issue with the color wheel or dmd board.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.This is how the DMD works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 02, 2010 | Mitsubishi WD-52525 52" Rear Projection...
The colors seem to be overlapping the red is further off than the other two
Hi, you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.The other thing that it could be is the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Mar 24, 2010 | Samsung HLN5065W 50" Rear Projection...
Used to be white lettering now top green bottom pink 60 inch rear projection 5 years old
Hi,do you hear buzzing ,whirling,or high pitch sounds?If you do it could be an issue with the color wheel.The Samsung BP96-00674A color wheels spin anywhere from 6,000 to 15,000 revolutions per minute (RPM’s)--It is one of the few consumable parts in your Samsung TV. The average life expectancy from our data logging shows the Samsung color wheels are fairly reliable with a MEAN average of 5-8 years But it could also be the Dmd board this is how it works: http://electronics.howstuffworks.com/dlp1.htm Baisclly the DMD board creates the images and colors through its chip that has 2 million pixels,when that chips goes out you'll see either lines ,pixelation and dicoloration.One simple way to see if it is the Dmd its to display menu if it's also appears distorted that will be what it is.
Sep 30, 2009 | Televison & Video
Dell Inspiron One 2305 Desktop Computer (AMD Athlon II X2 GB3GB) (DDPCEZ1P) Logo
62 people viewed this question
Alun Cox
