Question about Kenmore 63942 Dryer
Kenmore Dryer does not heat.
Kenmore dryer (model #66902), does not heat. Powers on, drum spins, but no heat. I have a list of things that it may (or may not be) but I can not get into the unit. Where are the fuses? Heating element?My Kenmore Gas Dryer model # 110.72822100 heats up for 5-10 minutes when started and then the heat turns off and the dryer keeps on working with cold air. Any suggestion will be much appreciated.I have replaced the thermal fuse but it did not help
  • 15,935 Answers
CLICK HERE for a list of blowout diagrams and part ordering info for your Dryer.
There is no heating element - this is a GAS dryer.
Gas dryers use a burner system to create heat. This system has a number of parts that are known to fail over time. Some you can test, some you must simply rely on symptomology to form your decision to replace or not to replace.
The parts prone to failure in your burner assembly are:
  • Igniter
  • Coils
  • Flame sensor
A burner operates in a fairly simple way. Once the motor is turning, centrifugal force closes the Motor Switch allowing the electricity to reach the Flame Sensor. The Flame Sensor allows the electricity to reach the Igniter, allowing it to heat up to a temperature high enough to ignite natural gas.
Once the Igniter is hot enough the Flame Sensor breaks the Igniter circuit which allows the electricity to run through the Coils that open the gas valve. Gas then flows out past the Igniter and catches fire and the heat is drawn into the airflow within the dryer.
Observation is key to troubleshooting a gas dryer. Does your dryer get hot at the beginning of the run but finish out cold? Does it never heat at all? Do you hear a chattering sound at times?
If your dryer is hot at the beginning of the run but finishes cold then it is likely you have bad coils. As coils age, they lose the ability to hold the gas valves open.
Sometimes this will cause the valves to open and shut rapidly, resulting in a chattering sound. Unfortunately, you can't test the coils to verify the failure so replacing them is a decision based on the above observations.
If the dryer never heats, then there are more items to check and test. The first item is the Igniter. There is a molex (clear plastic) connector attaching the Igniter to the burner circuit, Disconnect this and place your probes onto the two contacts on the Igniter side of the connector. The meter should read under 100 Ohms of resistance. Any reading above this value means that the Igniter needs replacing. You will find directions for replacing an Igniter here. Your igniter seems to be working fine since you DO have heat for a few minutes.
If the Igniter passes your test then you need to test continuity on the flame sensor, You should have continuity between the two contacts. If not, then you need to replace the flame sensor. To test it - touch the probes of your DMM to either contact of the device and note the reading on the meter. If the meter reads 'Infinite Resistance' and it uses a dial, then move the dial up to the highest setting and test the device again. If it still reads the same, then the device has failed the test.
If all of the above pass their tests, you need to make certain that there isn't a build up of dryer lint around the burner. Sometimes, lint will impede the gas flow preventing the unit from igniting.
If none of these things help, then it is time to call in a professional.
I have supplied you with the diagrams, and troubleshooting - if you feel the repair is within your abilities, please use the "Continue with this expert" option, and I can give you more useful information to get this repair done.
Thanks for using FixYa!!
Posted on May 08, 2009
  • blueextc3221
    blueextc3221 May 08, 2009
    You will want to concentrate on the burner assembly diagram HERE
    The Coils (also referred to as solenoids) are # 13 &14
3 Suggested Answers
djz83
  • 88 Answers
SOURCE: Kenmore dryer does not heat up. Mod#110 60912990
First I would make sure that you have 240volts coming into the dryer. Then I would check the thermal cut-off in is a fuse on the housing of the element. that should be it but if not look for the heater relay.
Posted on Jan 13, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Dryer does not heat.
DEAD DRYER
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 07, 2009
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Dryer does not heat correctly code F31
The thermostat which is a round 2 wire control on the blower box on the back of the dryer controls the heat on all dryers. always shut off power when checking any electrical appliance. Clothes dryers are wired with 2 voltages, The 240 volt supply is for the heating element only, while the 120 volt supply gives power to the timer and motor that spins the drum and powers any lights and switches. If the heating element is coming on, try replacing the thermostat. As always unplug the dryer first.
Dec 05, 2013 | Kenmore Dryers
Heat works on dryer but won't spin... the drum
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 28, 2011 | Kenmore Dryers
Dryer does not heat, drum does rotate
check the tstats on the heat can
Apr 23, 2009 | Dryers
Dryer wont spin
Take the back off  of the drier after unplugging and the beklt goes from the motor pully all the way around outside of the the drum.You can't miss it. Most of the Kenmore drier belts are the same. WE have apliance repair parts stores locally.If you also do , go to the store with the old belt and match it up.
Dec 19, 2008 | Kenmore 63942 Dryer
Dryer won't spin on my kenmore stacked model 417.90812991
This is the 2nd time I have this problem.
IF you look thry the drum to the back you should see 3 screw heads. Mine has one screw still in the hole and 2 empty holes.
This requires the drum to be removed (like take the drier apart). Behind the drum is Asmbly-shaft (ball hitch) (item 32 in the parts list). This what the 3 screws screw into.
I spent 2 days trying to put the screws in without removing the drum not possible (no way to hold the drum in place)
The first time I had to replace the drum because it wore the rim through.
I have to get 3 new screws and some thread locker.
I recommend that you check the screws every month, Use a long phillips screw drive
Nov 02, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Kenmore 63942 Dryer Logo
138 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
