Question about Olympus DS-2400
Getting message Due to the missing file, reading/ writing, access authorization cannot be performed.
2 Suggested Answers
tech4allmen
  • 666 Answers
SOURCE: I have the DS-2400.
Try importing the file again (not copying and pasting, but importing), and then looking in the "Finished folder." When I cannot see a folder this is where I have always found them--I have never figured out why this happens and the company I get my files from cannot figure it out either, but that is where they have been found. If you find your file there, you need to right click on the actual voice file and it will turn "blue," select "move the folder" to A,B,C,D, or E. Sometimes once you select the folder you want the voice file to go to it will just go right there, other times there will be a second step in the process where it asks you to click, finished, unfinished, pending, or cancel job. You need to check "unfinished" before the job will transfer to the folder you have selected.
I hope the above helps, as it has been the only solution I have found.
Posted on Aug 12, 2011
My windows XP has an error message when started. It says "MISSING NTLDR, PRESS CTRL, ALT, DEL TO RESTART" I tried restart with boot disk but nothing. Please help!?
How to Fix NTLDR Errors
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
    Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
  5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
  6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
  7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
  8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
    Try replacing the IDE cable cable if you suspect it might be faulty.
  9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
  10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
  11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will
Jan 22, 2014 | Belkin Basic Wireless Router
How to fix a NTLDR is missing error
Fixes for NTLDR Errors
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
  12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
Apr 06, 2012 | HP Pavilion 513n (P9850A#ABA) PC Desktop
I keep getting an error code when trying to install my software on my computer Error 1305.Error reading from the file C:\Program Files(x86)Punch! Home and Land Premium 16\Tutorials\tool7513\tool7513.mp4....
you have a missing mp4 file! this is a video file. just do a search on your computer for all "*.mp4" files with this same name and when found copy/paste into the location in your missing file message.
Aug 22, 2011 | Computers & Internet
Dropped my verbatim smartdisk portable hard drive. I'm able to open the disk but when I open the file, it's all gone. what do i do?
What you have listed isn't a hard drive, It's a flash drive and it is practically indestructible by a common drop, If you can plug the drive in and access it then the drive is working correctly. If it does not say something like " Insert disk in drive E: " when you try and open it once again chances are the drive is working fine. The last time you connected it previously to dropping it you might of removed the drive before it was done. Some times Windows does not write the files right away if the computer is also busy, this can cause a delayed write failure to occur when you remove the disk before it has written the file down. If you plug it in and the computer does not see it or you get the stated message I wrote above then it's broken physically. If you can still write new files and read those then chances are you missed a write window.
May 13, 2010 | Verbatim VER95327 USB Hard Drive
I've been getting pop-up windows that say I am prevented from opening or changing documents/files due to lack of authorization or permission. I am the owner of and only person using this computer. How can...
I am not sure if the documents or files that you are opening or changing are from attachments sent to you via email or not, but I can suggest that you can try this step:
Right click on one of the affected files and select Get Info.
This will open a long narrow box providing detailed information of the document.
Now look at the bottom of the window under Sharing & Permissions
Click the padlock and enter your User Admin password when the pop up window appears.
This will allow you access to changing the current permissions of this document.
Make sure you see permissions for "Read and Write" attached to your user name.
If you do, then go ahead and close this window. However, if you see only Read permissions attached to your user, then change that to Read and Write.
Once you have done this, close this Get Info window.
Try to launch that affect document to see if it opens now. If it does then this may be a permissions issue that is affecting your documents and files.
Whether you can or not, I would still recommend you still run this procedure below in order to try and fix this permissions issue.
Now run Disk Utility to repair all permissions on your Mac OS X volume.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} -RUN DISK UTILITY-
Go to Finder Menu bar
• Click Go > Utilities > Disk Utility and open up Disk Utility app.
• Click on Macintosh HD volume (or on the name you have changed this volume to.)
• Select "Repair Disk Permissions"
**Let Disk Utilities run this repair permissions until completion
Once Disk Utility is complete and there are no errors in red in the completion summary (if there are errors listed in red, re-run Disk Utility to see if those error will clear- if they don't reply back to this post right away and let me know what the exact error message is), quit Disk Utility.
• Now attempt once again to access the affected documents and files and see if you are able to access these items now.
I hope this helps.
Regards,
-Mactechtrainer
Feb 06, 2010 | Apple MacBook Pro with 17" Display
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
TROUBLESHOOTING
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
WP Win Error message "access denied"
I think either the file and/or the directory are read-only. In the File Explorer, right clicking on the file will give you the properties including a box indicating if the file is read-only. A quick possibility is to save the file to a new location (with read/write permissions).
If you are the administrator of the computer (or the owner of the folder/file) you can change the status to allow for write privileges by changing that setting in the Properties.
I hope this helps.
(if you recently upgraded your OS or transferred the files from one computer to another, the file might not be "yours" to modify. I know that you can reset the permissions and change the owner but I don't remember the specifics. If you need more information, I can find my reference books if you tell me which OS you are using.)
Jan 19, 2010 | Corel WordPerfect Office X4 Home & Student...
Files are saved to a CD for backup but will not open after they have been burned to the CD. Error message reads "You do not have sufficient permissions to the specified folder. To use QuickBooks in a...
The files are set to read only on the CD. If you would like to open them, please copy / paste the files to your PC and open them from there.
To rectify this in the future, please set the file permissions on the files before you burn them, and remoce the Read Only attribute.
Jun 24, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Windows system 32 hal.dll error after restoring e-machine
There's actually a number of reasons why these annoying little DLL errors happen, but the most common, is caused when new programs are installed over all old ones and the old ones are not completely uninstalled 100%, causing registry pile ups and of course, getting a .DLL error messages.
Another reason, is damage that's been done by malware/spyware/adware programs, attaching themselves to your PC and wrecking havoc, deleting crucial DLL files from your PC.
The hal.dll file is created during install from 5 other dlls. HAL is the Hardware Abstraction Layer and it's the interface between the system drivers and the actual hardware.
Copying hal.dll will not resolve the problem.
A lot of times the file will be reported missing due to corruption of the boot sector or of the file system
Causes of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll file or a hal.dll file that has been deleted or moved from its intended location.
Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged HDD.
Suggested remodies-
1. Restart the PC. The hal.dll error could be a fluke.
2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
6. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
7. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
8. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Important: If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
9. Replace the hard drive. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
10. Perform a new installation of Windows XP after installing the new hard drive.
I have not tried it - but HERE is a free program purporting to fix the error.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Apr 10, 2009 | E-Machines eMachines Desktop PC
Error 1304
no problem...
se HERE...
folow the instructions, and you will be ok :)
Jan 19, 2009 | Microsoft Windows XP Home Edition
597 people viewed this question
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
