Question about Sony VAIO Computers & Internet
When i hold my sony vaio on a steep incline the fan stiops working but if i put it in a normal position it stars working
Only happens when it is on a steep incline and is it normal?
    Top Expert:
  • Sony Master
  • 22,812 Answers
If it is noisy as well I would say a replacement fan is required. It should not stop working if at an incline.
Posted on Nov 25, 2013
2 Suggested Answers
ruben_barrer
  • 117 Answers
SOURCE: Screen on Sony VAIO PCG-SRX99 needs to be tightened.
you will have to take the bezel front plate of the screen off and check to see if anything there has broken from the hinges. there are usually two-three screws holding the hinge to the screens back cover and two-three holding it in place on the base of the laptop. if all those are intact you will need to replace the hinges.
good luck
ruben
Posted on Jul 12, 2009
Can anyone tell me what this is. It is on a 2006 Chevy impala. It has something to do with shifting the car. Ithink it makes the box around my gear indicator work. I.E. P R [N] D 1 2
P=park gear position (no gear selected)
R=reverse gear position
N=neutral gear position (no gear selected)
D=top gear
2=fixed highest gear (used for speed when climbing an average incline and to control speed on decent)
1=fixed lowest gear (used for climbing steep incline or descending slowly)
Note-: Never engage Reverse gear when traveling forwards and never put into Park when moving forward or backwards, also towing most autos should be done no more than 10mph, fast towing can damage the gearbox, also make sure gear is in Neutral when towing.
Apr 25, 2016 | Cars & Trucks
Fan will not turn off when car is running
The temperature sensor/switch is stuck in the closed "on" position. You need to purchase and replace that defective part.
Apr 14, 2014 | Dryers
Fan won't slow down
If you put the old drive back in and the fan runs normally the SSD is making the processor work harder. Shouldn't cause a problem if that is what happens.
Jan 23, 2014 | Sony VAIO Computers & Internet
My tractor won't go up any grade or incline.... it just gets slower and slower until it stiops.
HI
Im sure you have a hydrostatic or an automatic forward and reverse right well your ****** is on its way out when it warms up it likes to crawl in this case even if you attempt to check oil or even try draining and putting in different oil its a tough one ****** is expensive
Joe
Joe
Sep 09, 2012 | Husqvarna YTH2454 54in 25 HP Lawn Tractor
Error 7
Incline calibration is necessary when: the display shows ERR7, the drive board incline error LED ( LED5) lights or the incline has extended beyond its normal rangeThe goal of calibration is to synchronize the incline set mechanically and electronically. Mechanical calibration sets the incline motor pipe to the 0% position. This happens when the red line on the thin pipe is even with the end of the thick pipe. Electronic calibration sets the variable resistor (VR) value to the 0% position. This happens when the voltage across the VR blue and green wires is 1.20 VDC.
Readings of VR voltage (blue and green wires) should show around 1.20 VDC at the lowest position and around 3.80 VDC at the highest position. If the VR looses calibration or cannot be set to 1.20 VDC, replace the VR. If the incline motor gets voltage from the drive board but fails to operate, replace the incline motor set. If the incline fuse blows again and again, replace the incline motor set.
Jan 19, 2012 | Sportsart 6300 Treadmill
My Sony Vaio laptop makes a lot of noise mostly it seems from the fan. This is intermittent but seems to happen when I have had the laptop on for a long time. What might be causing this and is this serious...
Your processor is probably getting too hot. When it gets hot, the fan speed will increase. You will heed to have the processor heat sink checked, cleaned, and new thermal paste applied to it. You will also need to clean your cooling fans if they are dirty.
Nov 03, 2009 | Sony VAIO VGN-SZ645P2 13.3" Notebook PC...
My Sony Vaio seems to kick the cooling fan on quite a bit more than normal and even seems a bit noisy for a computer fan....is this the norm???
Fan on this model may start and stop spontaneously. This is normal. Although if VAIO is overheating this would be good idea to contact Vaio tech support.
Apr 17, 2009 | Sony VAIO VGN-CS110E/W NoteBook
VGN-SZ330P laptop stays on opening VAIO screen after two beeps
Just hold down the F1 key after the two beeps and the computer should continue to boot up as normal
Dec 19, 2008 | Sony VAIO VGN-SZ330P/B Notebook
Computers & Internet Logo
26 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
