Question about Ryobi Drills
Can I use a Lithium battery in a Ryobi HP496?
joboo1
  • 257 Answers
SOURCE: Ryobi 18V lithium battery won't charge
Hi, Thanks for getting back to me. The yellow and blinking red indicate a defective cell. Since it has lithium cells and is that new any repair to it would be a waste of your time. Ryobi tools purchased in 2008 have a 2 year warranty. I am guessing you probably got it at a home depot and you should return it under the warranty. All new Ryobi tools have a three year warranty. Good Luck! and Thanks for using fixya!
Posted on Feb 05, 2009
  • 8 Answers
SOURCE: Will the ryobi nicad charger also charge the
No, but the Lithium charger will charge the NiCads.
Posted on Apr 01, 2010
HomePlicity
  • 41 Answers
SOURCE: Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
Testimonial: "This is the best answer I received! Thanks!"
SOURCE: how do you take apart a ryobi lithium 18v one
This applies to Li-ion. NiCd is probably somewhat different.
Unscrew four security screws on the bottom of the battery. If you don't have the right bit you can grind down the center pins in the screw heads and use a T15 bit.
Unscrew the hex-head screw in the center of the protruding post at the top of the battery. It may be non-standard in size but a small metric hex key wrench works if you are gentle. The four corners of the battery cover should be loose now.
There are still two plastic clips holding the top cover to the main unit near the centers of the long dimensions. Gently push a knife blade into the crack between bottom and top to release the clip on each side.
As you lift the top cover off you should push down on the contacts near the top of the post so you don't pull on the attaching wires. Eventually the contacts should pop free and the top cover detaches.
Detach the wiring harness for the status LED from the circuit board. You can now remove the combined circuit board and battery pack from the lower case.
Six screws attach the circuit board to the battery assembly, along with several solder connections, but you probably don't need to go this far. You can now test and possibly replace individual cells.
Posted on Nov 16, 2010
  • 127 Answers
SOURCE: can you charge ryobi lithium batteries in a
NO! Never charge lithium batteries in a charger designed for nickle based batteries like the NiHi your old charger was meant for. Ryobi did design the new Lithium charger to be backwards compatible so you can charge your older 18V NiHi batteries in the Lithium 18V charger.
Also note, NEVER miss-match the voltage, for example, make sure you are not trying to charge 12V batteries in an 18V charger unless the manufacturer has specifically stated that the charger is capable of multiple voltages.
Posted on Dec 27, 2010
I have a P115 Ryobi Intelliport charger , will it charge the new lithium 18 V battery?
Ryobi P115 is an 18V battery charger. However, Ryobi Manual did not mention the current rating of P115. if the current rating of Ryobi P115 is 50% higher than your 18V Lithium Battery it will charge. but if it's less than or equal, it will not.
Nov 29, 2017 | Ryobi Drills
Is there a difference between the ryobi p103 lithium battery and the ryobi p106 lithium battery?
p103 is name of the battery. p106 is the kit with 2 p103 batteries. same thing just 2 times. the p104 however is bigger and holds more juice.
Jun 15, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
I bought 2 P103 lithium batteries and they will not take a charge from my one + (p110) charger. I was informed that these components are all interchangeable. Will the P103s work with the blue 18v ryobi...
That is true the One+ 18V Li-Ion battery packs will work in any One+ 18V Ryobi tool. However the Lithium ion batteries will not charge in the original P110 NiCd charger. You will need one of the the new series Ryobi One+ 18V "dual chemistry" chargers for that. The will charge both types of battery packs.
Feb 18, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion Charger I can't get these to work! The charger does what it should but when I have a steady green light the batteries do not power my drill, when I...
You are the thrid person in the last couple of days with this same problem and i check who was posting the problems all differant people all RYOBI 18V lithium-ion batterys and they all got them for christmas. SOMETHING is not right there is now warranty on the batterys but there is one on faulty workmenship there must be a problem with this type of battery good luck
Jan 16, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
What Ryobi batteries p103 or p104 will a battery charger that came with my p100 batteries charge? Or will the charger work with these batteries?
If you have a P100 NiCad battery, the charger for that will not charge the new Lithium Ion P103 or P104 batteries. You need a specialised Ryobi Lithium Ion battery charger like this one
Jan 11, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Can you charge ryobi lithium batteries in a regular ryobi charger?
Dec 25, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
New Ryobi 18v lithium battery goes dead after a couple of seconds. Is there any solution other than returning it?
No, just return it, for the money they should give you one that works. It is common to get a defective Ryobi 18v lithium battery. I've had 2 out of 7 purchased that wouldn't hold a charge. But when you get a good one they work awesome!
Jan 24, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Lithium batteries?
Just got a reply from Ryobi tech service and it says that "all Ryobi 18V platform power tools can accept and use the lithium batterys, but you must use the charger for the lithium to recharge them. Hope this helps. Dave
Feb 11, 2009 | Ryobi Multi-Volt Battery Charger
Drills Logo
60 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
