Question about Samsung SCX 4521F All-In-One Laser Printer
Printers repair manual
Printer initilising again and again
  • 794 Answers
You can download the repair manual for your printer at:
http://www.manualslib.com/manual/473725/Samsung-Scx4521f-B-W-Laser-All-In-One.html
Posted on Nov 25, 2013
Wc 5225 show the code 124 320
-Try to power up printer without drum cartridge,and with left door open.
-Check all the interlock switches.
-Could be defective drum cartrige.
-IOT NVM initilisation may be needed.
Apr 13, 2015 | Acer Aspire One 522-BZ465 AMD C-50...
How i solve download from pc eror deepak
Dear
Clean the main PBA with isopropyle alcohol and warm up with hot air after dry. Try to update firmware and If it was not solved replace the main PBA.
Thanks.
Feb 20, 2015 | Samsung SCX-4300 Multifunction Laser...
I can't print in my Canon Pixma IP1980... service error 5201. cancel printing and turn the printer off and then on again. if doesn't clear the error, see the printer manual for more detail. how can i fix...
service error 5201. cancel printing and turn the printer off and then on again. if doesn't clear the error, see the printer manual for more detail. how can i fix this?
Dec 08, 2010 | Canon Office Equipment & Supplies
Unable to initilise and checked the ptinter, which is al ok
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Jan 23, 2010 | Brother DCP 115C All-In-One InkJet Printer
Paper jams
hi,
follow these steps:-
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting theprinter manufacturerfor additional assistance and/or repair.
Thanks!
Aug 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
Paper jams and the light comes on
hi,
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting the printer manufacturer for additional assistance and/or repair.
Jul 13, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
How to remove a paper jam from the vivera paper tray
Jul 13, 2009 | HP Photosmart C7280 Laser Printer
Repairing tips for Hp deskjet 1125c Inkjet Printer
It may be the rollers that grab the paper and pull them into the tray, over time they start wearing down and losing their grip, kind of like a car tire. There are rejuvinator pads available that will give the rollers a little big of their grip back but I don't know how effective they are because I've never used one.
Jul 12, 2007 | HP DeskJet 1125c InkJet Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
49 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
