Question about Cell Phones
My DROID2 R2D2 is acting stuck in the up volume position. The volume square is remaining on screen and it is continually beeping like I'm pressing it. It will allow me to turn it down, but it pops back up and turns all the way up. I've pushed the button over and over, powered off, taken battery out, tried going into settings. The button doesn't appear stuck and pushes fine. Is there anything else I can try? Ready to throw it against a wall.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
The volume up button may be broken and not stuck.
While taking the unit apart and checking the contacts may prove to render it useless if you don't take it apart properly. You may want to t just started pushing buttons across the keypad, and eventually find the right key to release the volume up.
I don't know what happened, but it just seemed that my keyboard lost the orientation and the E button or one of the others was registering as the search.
When I did a factory reset, it reset the whole phone and I was fine again. But this was my last resort.
Hope this helps.
Posted on Nov 25, 2013
4 Suggested Answers
advance
  • 107 Answers
SOURCE: camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Posted on Feb 27, 2007
SOURCE: Lens stuck open
I have to agree with one of the comments previously posted. I too had a Sony DCS-S700 and the lens was stuck open. Whenever I turned the camera on, the Sony Cybershot logo appeared and dissappeared, turning the camera off. I noticed the lens was crooked, so I moved it in the center direction and the camera worked again.
Posted on Feb 04, 2009
t00nz
  • 4738 Answers
SOURCE: Canon IXUS 100IS - 'Lens error, restart camera' message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Posted on Mar 20, 2010
Forgot security password on home screen is there any way to get into tablet?
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however anything on your SD card will still remain.
At this point you will need to start fresh as if you just bought the device -- register with your email address, etc.
Nov 16, 2013 | Coby Kyros 716829701508 Tablet PC
Em543 tablet
Nov 03, 2013 | Tablets & eReaders
7" supersonic tablet is stuck on the opening android screen and will not boot. The tablet's battery power went empty during the last use and was fully charged afterward.
Oct 30, 2013 | Supersonic 7" Touch Screen MID Tablet
I got a polaroid tablet pmid 705 series forgot pattern code how do i unlock it to change it to one i will remember
Once you forget the unlock codes, you're pretty much stuck. You're going to have to do a factory reset to get back into it.
Oct 25, 2013 | Linksys CISCO-LINKSYS ULTRA...
My visual land 10 inch prestige has a white screen. How can i fix
Oct 24, 2013 | Visual Land ME-110-16GB-PRP - Prestige 10...
Screen lock
Oct 24, 2013 | Coby kyros Tablets & eReaders
My tablet keep on restarting. cannot go into the settings because it automatically restarts
Oct 24, 2013 | Nextbook Premium 7 Capacitive Touch...
On my bosch wfvc5400 dryer, i need to stop the beeping! Help!!
Welcome to FixYa.
To change the volume or disable the signal for the WFVC dryer is as follows...
Press the Menu button to scroll through options to "Signal setup". While in "Signal setup", press and hold the Select button to continuously change the signal volume. While changing the volume continuously, the display will show "Continuous" - when the maximum volume has been reached, the display will show "Max".
Hope that answers your question. Good luck and thank you for choosing FixYa today.
Please take a moment to rate the assistance you received today positively and a brief testimony is always appreciated.
Regards,
Macmarkus :)
Apr 20, 2011 | Kitchen Ranges
I need the manual for the r2d2
http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/DROID2/US-EN/_Documents/Static_Files/DROID2_UG_US_ENG_VZW_68014406001a.pdf
The R2D2 Should respond the same it is only a special edition of the Droid 2
Mar 01, 2011 | Motorola Mobility Droid 2 R2D2 (8 GB)...
Stop beeping at end of wash on bosh machine
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops. Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Aug 16, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Cell Phones Logo
11 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
