My laptop compaq cq56 is in charge but not charging it sometimes takes but it has a limit 84%
SOURCE: hey, um i plug in my compaq presario cq56-115dx
If any one of your friend have same model notebook then try with his charger if it is not working then try changing the the battery if the charger is working fine then this the time for you to change the battery.
SOURCE: i have bought a new charger for my laptop, compaq presario cq56, and it is still not charging
Other expert is right--if not charger may be a loose socket where it plugs in or even a bad battery is possible.
SOURCE: Hewlett Packard Compaq Presario CQ56 power/charge light blinking orange & will not charge
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place.
