Question about Sherwood Audio Players & Recorders
My Sherwood RX4209 will only stay on for 3 seconds then switches off and goes back into standby
4 Suggested Answers
robotek
  • 1512 Answers
SOURCE: My Sherwood RD6405 Switches on
Hi hyphen
Try a hard reset first. switch the amp off overnight and try it in the morning. If problems persist, is it covered with warranty from where you bought it? Best to go that route if it is. If not, get back to me here.
regards
Graeme
Posted on Mar 19, 2008
jomabug76
  • 1148 Answers
SOURCE: Sherwood RV-8070R, i can t switch it on
TRY BLOWING IT OUT WITH A AIR COMPRESSER
Posted on May 15, 2009
jdvillanueva
  • 2098 Answers
SOURCE: The problem I ran into
Hi amit2817,
Your unit gone to overload that caused the subsequent shutdown. To isolate the input and speakers from fault, disconnect all input cables and speaker wire from the unit then turn it on naked. If the symptom still there then this is a clear indication that the fault came from the unit itself. Most common caused of this problem is the sound output circuitry and the power supply. Most common affected parts in the output section is the output IC/transistor(mounted in the large heat sink). It will fail because of exposure to excessive heat due to frequent high volume and or because of aging. Bad solder joints is also to consider to this section and also to the power supply section. Because of heat build up, most of the joints dried resulting to poor flow of the supply and trigger the over current(overload) protection circuit. Leaky electrolytic filter capacitor is also one of the factor in this fault. It will produce an out-of-regulation to the power supply output. You must have a capacitor checker to determine its condition. Sometimes it has a bulged/dome at the top but not all.
If you don't have necessary tools and test instrument and can't troubleshoot the symptom, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 02, 2011
Why does it turn on sporadically, stay on briefly, then turn off?
Sounds like a defect to me return it for a working model.
Jun 01, 2015 | Sherwood RX-4105 2-CHANNEL...
I have Sherwood rd-6106 amplifier and when i turn him on it goes back to standby after few seconds. can anyone help?
bad fuse, something is sending it to sand by to keep from ruining the rest of it, have it looked at by a pro technician
Feb 02, 2015 | Sherwood Audio Players & Recorders
RD-6506 sherwood back to standby mode after 3 second when attemting to operate the system, any help please.thanks and God bless
Hi,Need more info. Was the unit working then failed? tell me anything you noticed, this sounds like a fault in the audio output or power supply stages,I have had other receivers do this for variou reasons
Feb 27, 2014 | Sherwood RD-6506 Audio and Video Component...
I have a sherwood RDV6095RDS and when you switch is on and select either video or audio the display comes on and then after about 2-3 seconds the unit goes back in standby mode. I can hear the relay...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Sep 19, 2011 | Sherwood RD-7500 Receiver
How do I reset the defaults on my Sherwood RD-8108 AV receiver?
I just got a tip from Sherwood tech support on resetting my Sherwood receiver, and it solved my problem perfectly. It's not the same model number but here's what I did: Put the receiver on Standby. Press and hold the Setup button for 3 seconds. When you see the model # on the display, press Enter. The word "Cleared" should show on the display. Hope it works for you also.
Feb 03, 2011 | Sherwood RD-8108 6.1 Channels Receiver
Ps3 goes to standby mode as soon as turn on
Same here. Just re-flowed it for the second time. Now when I hit the switch in the back it automatically turns on, ejected the game inside, beeped twice, then goes back to solid red. If I try to turn it on it just stays solid red.
Sep 04, 2010 | Sony Playstation 3 (PS3) Console
May 13, 2009 | Sherwood RX-4109
Sherwood 6500 reciver
check your speaker wires make sure they are not shorting against each other down the line, that will cause the reciever to go into standby.
Jan 25, 2009 | Insignia 200W Stereo Receiver
SLIMLINE FAULT PLEASE HELP
try holding the button wen its at standby for about 3 seconds..it should stay green after that..mine did that for a while too but then i held it for a while n it workd
Nov 01, 2008 | Sony PlayStation 2 (PS2) Console
My Sherwood RD6405 Switches on for about 5 seconds from standby when you choose an input source but then goes back to standby. It has only had about 12 hours use in total.
Hi hyphen
regards
Graeme
Mar 19, 2008 | Audio Players & Recorders
37 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
