I have a Toshiba SD2019U DVD player and the door won't open. When I turn it on, it makes a rumbling sound and displays "opening", then continues to rumble then changes to "closing" and shuts off. I opened the unit up but can't find what releases the door to open.
    Sergeant:
    Champion:
  • 255 Answers
I think there's a broken or loose gear.or someone put something small that stop the door from openning.
you can try to open the unit up and turn the power on
and check what hinders the door from openning.
Posted on May 08, 2009
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
I recently purchased a Toshiba laptop, model #S855-S5254 . I am unable to open the door to the DVD player. Does anyone know if there is a lock on it, or how to access the "unlock" if so.. Please help
If the eject button doesn't open the door, try going into 'My Computer', then right-clicking the DVD drive, then click 'Eject' on the menu that pops up. Maybe that will get it open for you.
Dec 14, 2012 | Toshiba Satellite S855-S5254 Laptop
Portable DVD player won't recognize door is closed.
My guess would be that the switch inside that the tray hits to tell the dvd player it's closed is broken.
Aug 23, 2012 | Philips portable dvd player phillips...
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
Dvd door won't open
Someone is going to have to open the unit to see what is happening--either a disc is jammed inside or a mechanism problem.
Sometimes with unit apart you may be able to gently probe and free the jammed area--possible also something that does not belong there got inside--look closely.
Jun 16, 2012 | Daewoo DV6T-81N DVD Player / VCR Combo
How to Unlock a Sony DVD player DVP SR320 which displays "LOCKED" when eject/open button is pressed?
Apr 22, 2012 | Televison & Video
DVD door won't open
you should get the DVD door cleaned either profesionally or just do it yourself
Feb 19, 2012 | Panasonic DMR-ES40V DVD-Video Recorder
Disc door won't open. DVD in will still play. How can we make the door open
try to re start the power first to reset the supply in which the door unable to open and then push the open/close button to open the door. if still won't open maybe their is an stuck up at mechanical part, so turn off the player then use a Phillip screw driver to loosen the screws and to remove the cover of the DVD player .you can now access the disc mechanical assembly of your DVD player, remove the CD first and then check if the plastic gear is mis aligned or the the drive belt is broken.much better if you can apply silicon grease in plastic gear for smooth operation.then make sure the open/close button is ok, good luck and good day.
May 03, 2011 | LG Televison & Video
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Electro Med Services...
