Question about Jazz DV-179 Digital Camera
Camcorder works only when charging!!
The camcorder only works when it is charging into an outlet, once unplugged, the camcorder shuts off and wont come back on! HELP lol
    Problem Solver:
  • 8 Answers
Maybe you need a new camcorder battery to test.
We have many camcorder batteries on sale. Welcome to visit:
Canada
www.buy-battery.ca/camcorder-battery.php
USA
www.all-batteries-shop.com/camcorder-battery
Posted on May 08, 2009
How do i charge this
anyone want to guess at a MAKE ,model .
Jul 28, 2016 | Video Cameras
Camcorder wont charge through the usb connector ?
It's not supposed to charge through the USB port. Connect the supplied charger to the DC IN jack and plug the other into a power outlet.
Jun 30, 2012 | Panasonic SDR-S70 Camcorder
Do you need a working battery to run camcorder off ac power adapter? I havent used camera in 2 years and just bought replaceable power adapter and wont charge battery or work off outlet at all..camera was...
You do not need a battery to run the camcorder off ac power supply. It is one or the other. The only time that both will be used is when you are charging the battery on the camcorder with the power off.
Hope this helps.
www.austintelstarservices.com
Jul 21, 2011 | Sony DCR-HC52E Mini DV Camcorder
My memorex mcc228rsblk camcorder wont charge. when i put it my computer to charge and when it charges up i unplug it from the usb but it wont come on
It is possible your battery is dead, or the camera is no longer able to charge from the battery.
Are you able to verify that the battery has a charge when unplugged?
May 06, 2011 | Memorex MCC228RSBLK Camcorder
Canon zr 200 camcorder won't turn on unless plug into electrical outlet.
Hi, Please charge your battery ( with camcoder Off) for at least 1 hour. Then unplug your charger and turn On your camcoder. If it can not turn on, it is apparently you have flat battery and need replacement.
Dec 03, 2010 | Canon ZR200 Mini DV Digital Camcorder
Camcorder problem
If it is not battery fault then its charging IC or fuse damage.You can also use external charger to charge the battery
Feb 28, 2010 | Sony DCR-SR47 Camcorder
The camcorder won't go on.
Check if the camcorder is just out of batteries. In my case, it seems you have to shut the camcorder off before you plug it in to charge it. otherwise you just run out of batteries.
Feb 10, 2010 | Aiptek HD-1 Hard Drive Camcorder
I plug in my charger and the camera shuts down, including the time. I unplug the charger and the time returns. I cannot charge the battery or run the camera with the charger plugged in. The camera and...
Disconnect the charger from the Camcorder and remove the battery.
Next, clean the metal contact of the battery and the battery compartment.
Then, insert the Battery in the Camcorder and turn it ON then press and hold the power button for 30 seconds.
After resetting the Camcorder to the default settings, connect the AC adaptor to check its operation.
If the issue persists then the DC in jack requires to be serviced.
Sep 15, 2009 | Sony Handycam CCD-TRV108 Camcorder
Sony DCR- DVD108 switches off automatically while recording
Follow this procedure to troubleshoot if the camcorder turns off by itself.
  1. Remove the battery from the camcorder.
  2. Connect the AC power adapter to the camcorder.
  3. Plug the AC power adapter into a working electrical outlet.
  4. Attempt to turn on the camcorder.
  5. Reset the camcorder back to factory settings.
  6. NOTES:
    • If the camcorder does not operate using the AC adapter, service may be required .
    • If the camcorder does operate using the AC adapter, proceed with the steps below to troubleshoot the battery.
  7. Ensure the battery has been fully charged.
  8. Ensure the battery is properly inserted into the camcorder.
  9. Remove the AC power adapter from the camcorder.
  10. Attempt to turn on the camcorder.
  11. NOTES:
    • If the camcorder does not turn on, then the battery may need to be replaced.
    • If the problem persists using a different battery, service may be required .
Aug 13, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Camcorder problem
you need a new battery
Nov 06, 2007 | JVC COMPACT VHS-C CAMCORDER
Jazz DV-179 Digital Camera Logo
188 people viewed this question
Top Jazz Cameras Experts
Pavel Pranovich
Pavel Pranovich
Corey Fields
Corey Fields
Level 1 Expert
Are you a Jazz Camera Expert? Answer questions, earn points and help others
