Question about Zebra 110Xi III Plus Thermal Printer
My zebra is always feeding the labels non stop, please help,
SOURCE: LP2824 feeds a label but wont print on it?
can you give more info? it sounds like you driver is set to thermal transfer mode but you have a direct thermal printer (LP not TLP)
Posted on Nov 09, 2007
jigeo
  • 57 Answers
SOURCE: Zebra 2844 Not printing at all
Antztech,
if the red light is coming on and staying on, it might be a sensor problem. Try pushing on the lid and see if the light goes to green. If it does, it' s the gap sensor. This is how the printer "reads" the labels gaps-the little spaces between the labels. We've solve this in the short term by covering the sensor and manually setting the gap through the programming command prompt,
Posted on Apr 19, 2008
  • 7 Answers
SOURCE: I have a zebra 2844 - it finally prints the right
It is because you do not have a factory original power supply. If you watch the printer or power light on the power supply I would bet it turns off and then back on again. Don't pay attention to the power supply specs they can be weak. Get a Hitek Plus 120 or 220 or FSP50-11 it will work. Good Luck.
Posted on May 17, 2009
Madison99
  • 18 Answers
SOURCE: zebra 2488-z
Unplug the printer, place your finger on the green button and with the other hand turn the printer back on. Let the light flash four times (flash, flash flash, flash flash flash, flash flash flash flash) then immediately release the green button. The printer will cycle and feed out a couple of labels. Press the green button one more time and you are ready to go.
Posted on Sep 20, 2009
  • 62 Answers
SOURCE: Hi can you help ? My zebra TLP 2824 printer keeps
If you are using a ribbon remove it and perform a calibration, hold down feed key for 2 seconds as you power on, release key and wait for it to complete its calibration, when it has stopped shifting labels (wait for 10 secs to be sure) HIT THE FEED KEY to exit dump mode. If it has successfully calibrated it will feed a label each time you hit feed key. Re-install ribbon, make sure ribbon is pushed formly onto drive sprockets and then re-run the calibration..
If this does not fix problem. download firmware to latest version. This will automatically reset printer to factory default condition.
Posted on Nov 20, 2009
My Zebra ZDesigner LP2844 feeds a blank label after printing a label. How do I make it stop doing that?
Define your label size correctly. Measure your LABEL exactly, do not include the backing paper or the gap. Calibrate the printer. HOW?
Power off printer. Press and hold the green feed button down and power printer on. Count one, two and release green button. The printer will calibrate and move labels and then print some stuff on the label. Wait until it has comletely stopped. wait another few seconds and the press the feed key once. The printer will print "out of dump". You should now be ready to print again.
Aug 31, 2013 | Zebra LP 2844 Thermal Printer
How to calibrate the label in QL320 plus zebra printer?How to make it only feed 1 label per print?
create a text file called Calibrate.txt and in the text file type this:
~JC
^XA
^JUS
^XZ
then send the file to the printer using label vista.
this will then print 3 - 4 labels and stop.
once u press the feed button it will only feed one label.
Dec 10, 2010 | Zebra QL 320 Thermal Printer
One label printing over two label forms
Always check to make sure the printer is advancing one label at a time by itself before printing. If it does then you know the printer has a good read on the label size. Then if it misaligns when printing then you know the problem is in the printer driver because the printer is only going to do what it's told to do.
So best is to turn printer off, power up, press feed to see if one label feeds ok. If the label feed is off at this point then the printer needs to be calibrated which is done by pressing and holding FEED while turning the printer on.
Hope that helps !
Jun 03, 2010 | Zebra TLP 2844-Z Thermal Label Printer
I am using a S4m printer to print on non zebra labels, by direct printing ( not thermal paper) I cant get what i'm printing to print in the middle of the page. I have tried every possible setting but I...
You need to make sure the printer is calibrated correctly. If you press the feed key, does one label come out and stop at the gap? Do the labels have a black mark on the back of the liner? This would tell us if the printer is set correctly. (Mark or gap). We need to make sure the labels are loaded correctly and the printer is set correctly. Then we move to driver and software settings. I have 10 years experience working for Zebra, so I will get you the resolution once we determine the current setup.
Oct 16, 2009 | Zebra S4M Thermal Label Printer
Zebra stripe s500 skips 5 labels prints 1 skips 1
He are the steps you need to calibrate your printer
Label Length Calibration
Note: This is typically the only procedure required when first installing the labels.
1. Load the printer with media and ribbon.
2. Press the printer front panel MODE key until the CALIBRATE LED is lit.
3. Press the FEED key and allow the labels to feed.
4. When the labels have stopped press the MODE key once to save the value in memory.
Jul 10, 2009 | Zebra Stripe S500 Thermal Label Printer
Label Spacing
Make sure printer is set for "non-continuous" supplies(media).
Also try calibrating printer. You can download a quick reference manual at zebra.com
Jul 06, 2009 | Zebra Z4M Printer
Blank labels keep feeding out
Disable start up calibration maybe?
May 09, 2009 | Zebra 105SL Thermal Label Printer
Zebra Z4M only feeds a small portion of the label.
You should try a factory reset. Power off the printer. Hold the "pause" and "feed" buttons down while powering up. Allthe lights will blink and when they stop blinking, release the "pause" and "feed" buttons. This will factory reset the printer.
Apr 24, 2009 | Zebra Z4M Printer
How to feed labels on zebra s4m
The issue that is causing the problem is when users tear off the label they are actually partially pulling on the next label causing it to peel away a little then when it feeds it will jam. Only reliable way to stop this is once the user prints tell them to press feed and feed 1 label through.
Mar 31, 2009 | Zebra S4M Thermal Label Printer
Zebra 110Xi III Plus Thermal Printer Logo
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
