Does the refrig sound like it is running. if it does not , your problem is more than likely the defrost timer. depending on the age , the timer is sticky.
the timer is in the refrig. normally on the ceiling under the plastic.(on some it is located below the bottom door, mounted to the front grill) on the older models it has a place for you to put a dime & turn the dial . it should turn easily. I have had them turn very hard.
after you turn it , you will hear it turn on. if it does .replace the timer
On some of the newer ones it is electronic.
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
The freezer, fridge or both is 60?
