Question about Ovens
Atlas chalet oven manual - Ovens
Need manual to program oven
Here it is.
Atlas PDF.
Sep 07, 2016 | Ovens
Simpson Neptune, atlas series electric oven isn't working.
Hi If you have Simpson Neptune 3U 602 then it may be to do with the timer function. This also happened with my oven.
There is a red section on the face of the clock. The oven seems to work if it shows the hand icon. I'm not sure what it symbolises yet, as it's a new oven for me, but it is now working. You can change the icons by turning the left nob left and right. Hope this helps.
Jul 07, 2012 | Ovens
Manual for a Westinghouse oven 667.
The manual you are looking for is over here:
http://manuals.appliancesonline.com.au/westinghouse-electric-wall-ovens/westinghouse_electric_wall_ovens_manual.pdf
The manual includes multiple ovens including yours.
Mar 28, 2012 | Ovens
Instruction manual for Atlas La Bella oven how to set time and take off auto
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
I'm Joe, and I will be more than happy to assist you with your service request.
Here is a direct link to the ONLINE USER'S MANUAL for a Simpson 63K906S model oven:
http://product.electrolux.com.au/Public/File/14880
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above. Then select OPEN THE FILE when prompted.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this utility pre-installed.
You can always download this for free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
Please COMMENT back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
If you were satisfied with the service provided, could you please take a moment to leave a 5 STAR rating. Your feedback is very important and I truly appreciate your consideration.
BEFORE leaving a rating OTHER THAN 5 STARS or a negative TESTIMONIAL, please contact me and I will immediately clear up any concerns or answer any additional questions that you might have until you are completely satisfied with the service provided. The FixYa rating system is a very important component of the Marketplace, and unfortunately once you post a rating or a testimonial to a solution, it cannot be changed at all later on.
Be sure to use the small blue ADD A COMMENT button located just below the text of this solution to leave any additional comments for me regarding this particular issue and I will respond right away.
See page 5 of the manual for detailed instructions on HOW TO SET THE TIME on that oven, which has to be completed after a power failure in order for the oven to operate normally. On some older models you need to depress and hold down 2 of the buttons at the same time, and then use the control knob or + / - buttons to adjust and set the time.
If the instructions in the above manual are not sufficient help you, then please provide the exact model number of your oven and I will send you the appropriate documetation. To find the unit's model number, check inside the oven door frame for a sticker or ID plate which should be visible when you open the door fully. Otherwise look on the very back panel of the oven for the information label.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Nov 23, 2011 | Ovens
How to remove the door on my simpson atlas oven.
Most oven doors are as follows: Open until first notch (or a little further if necessary). Grab both sides of door and pull straight up.
Jun 03, 2011 | Ovens
How do i turn on a white atlas ceramic electronic oven, the ceramic top is working,but the oven screen flashes from"0:00" to "auto" when i try and fiddle round with the oven...
Turn the oven control on. Now play with the buttons on the electronic timer/clock. Try all different combinations. Trying pressing them at the same time. This may take 5 minutes or more. If the timer is not faulty this will work, be patient. When the oven indicator light comes on the oven is on and the timer is now in manual mode.
Feb 25, 2011 | Ovens
Recently bought this oven (without instruction manual) I cannot get it to start working! When turned on digital display flashes and oven is on auto. How do I set the clock and oven to manual. the oven...
I come across this problem often, particularly with no manual. I turn the oven to ON. I then just muck around with the buttons until I find the manual setting. As soon as you find the manual setting the oven indicator will light. You can normally work it out quickly. But make sure the oven is turned to on whilst you are doing this.
Feb 05, 2011 | Ovens
Cant remove glass cover to replace bulb on Simpson La Stella Atlas series oven
I have a Simpson Atlas Mira. Was having a hard time getting the glass cover off too so looked on the net for a solution. Couldn't find one so I persevered and sorted it...
The glass cover has a screw-off thread (like a glass jar) which unscrews anti-clockwise (lefty loosey). I had to give it a good few wiggles and pulls before it would start unscrewing. I also had to use a damp towel to get a proper grip - it's a slippery little bugger - but I got it in the end!
Hope this helps someone - good luck!
JD Hamilton, NZ
Aug 23, 2010 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
