Sharp cd-dh950 will not turn on
When plugged in the unit does not power on. Have used the remote control and the power on/standby/off button, nothing makes the machine work. There have been no lightning/thunderstorms or irregularities in the power in our home.
hardrocko
  • 1476 Answers
SOURCE: 14" Tv/vid combi
If the light blinks it indicates a fault, probably in the high voltage circuit. If it is steady the problem could be anywhere. First you need to check all internal fuses. Then power supply for all necessary voltages. If this checks out each section would have to be isolated. At this point a service manual would be helpful (www.servicemanuals.net). From there it would be a matter of a process of elimination. Everything I said is contingent upon you being familiar with and capable of doing the work. These things are dangerous and best left to professioals if you are not trained. Good luck.
Posted on Jun 23, 2006
simplemitch
  • 752 Answers
SOURCE: Pioneer X MT- 2000 Stereo Bookshelf Unit - No sound!
It definitely sounds like it took a surge. yhe Power Amop IC in those things are pretty sensitive. Any decent repair shop should be able to repair it for under $125.
Posted on Sep 18, 2007
SOURCE: Unit will not power on, has the standby light on
I took your advice I unpluged the unit then held the power button in then pluged it back into power outlet the unit came on. There is one thing I might add I had to do it twice before the unit came on. Now how long will it work? Who knows
Posted on Oct 11, 2008
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
My 16" led lcd dvd combo TVs does not turn on. The standby light indication is on but when I push the standby button on the TVs unit nothing happens. As I have lost the controller and un able to switc
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 05, 2015 | Televison & Video
Tip
Digilogic DVDVCR2 Region Free Code Would you like your Digilogic DVDVCR2 to be...
Would you like your Digilogic DVDVCR2 to be region-free and play all DVDs? Here are the steps to make your Digilogic DVDVCR2 region free:
  1. Press the Standby button on your remote control to place the unit into Standby
  2. Press the Standby button on your remote control to turn on the unit
  3. Press the Open/Close button on your remote control to open the drive tray
  4. Press the Clear button on your remote control
  5. Press the 1 button on your remote control
  6. Press the 3 button on your remote control
  7. Press the 6 button on your remote control
  8. Press the 9 button on your remote control
  9. Press the 0 button on your remote control
  10. Press the Open/Close button on your remote control to close the drive tray
  11. Press the Standby button on your remote control to place the unit into Standby
  12. Press the Standby button on your remote control to turn on the unit
Your DVD / VCR combo is now region free.
__________________________
Is your Digilogic DVDVCR2 locked in SAFE mode? View my other Digilogic tip to unlock SAFE mode.
on Apr 07, 2010 | Televison & Video
Westinghouse ld-2480 powers up with red light however will not turn on to blue light
Nov 29, 2014 | Televison & Video
How do i turn off the demo mode, the radio shuts off automatically after about 10 min
try this:
If you have the remote, press the "demo" button.
If you don't have the remote, press and hold the power button for 10 seconds while the unit is on.
http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/Audio/Manuals/aud_man_CDDH950P.pdf
Oct 13, 2014 | Sharp CD-DH950 5-Disc Compact Stereo...
Sharp tv wont turn
If you have power to the standby light but no life beyond that you could be looking at a main tuner pcb: Link attached:
Search results for LC 50LE751K
Jun 06, 2014 | Televison & Video
Can't get cd to repeat
Press the 'play mode' button 3x, then press the CD play/.pause button.
Mar 19, 2014 | Sharp CD-DH950 5-Disc Compact Stereo...
How to remove timer
If the unit is controlled by a remote, the symptom you are experiencing could be cause by a function only available on the remote. I discovered this with my Yamaha 5-CD disc changer. However, my unit doesn't have an integrated Stereo. Your unit may mean that the remote handles more features. Search for a button that says MODE or AUX. If you still have the User Manual with the system, check to see what these buttons describe as controlling which features. Check back with me.
Jan 27, 2014 | Venturer Home Stereo AM/FM Cassette 5 CD...
Bose 321 series wont play region 1 dvd
To convert Bose 3-2-1 GS Series 2 DVD system to Multi-Region playback
1. Press the Right button on your remote control
2. Press the Up button on your remote control
3. Press the Shuffle button on your remote control
4. Press the Stop button on your remote control
5. Press the Mute button on your remote control
6. The disc tray should eject twice to confirm the region change
7. Press the Standby button on your remote control to power off your machine
8. After one minute, press the Standby button on your remote control to power on.
Done!
Nov 29, 2010 | Bose 3 2 1 GS Series II DVD Home...
My Emerson stereo MS9903TTC won't turn on. It was working fine last night and this morning when I push the power button nothing happens. I tried selecting different modes, (cd, tape, phono, tuner) but no...
I had the same problem the power button is pushed in. You did not mention if your unit came with a remote control if it did use that to turn your stero on and off. you will not be albe to use any of the buttons on the stereo if the controls are listed on the remote IE; Cd player, radio tape or tuner. try this please. hope this helps
Feb 10, 2010 | Emerson Audio Players & Recorders
Need DVD Hack code for Asda LEDVD0802.
The word Hack gives an impression of illegality, however the term is used in error for what is a series of remote button pressing to unlock the players potential. Sources are freely distributed by the very people who make the units. Now this model I have found is the basics of a Phillips model 610. So here is the unlock sequences..
To change the region on this player 1. Press the Standby button on the DVD player to power off the machine 2. Press the Standby button on the DVD player to power on the machine 3. Press the Blue button on the remote control 4. Press the Play button on the remote control
NB: This and the following steps may need to be carried out quickly following the previous step 5. Press the 1 button on the remote control 6. Press the 5 button on the remote control 7. Press the 9 button on the remote control 8. Press the 1 button on the remote control 9. Press the 2 button on the remote control 10. Press the 1 button on the remote control 11. Press the 2 button on the remote control 12. Press the 1 button on the remote control 13. Press the 2 button on the remote control 14. Press the 0 button on the remote control 15. Press the 0 button on the remote control 16. Press the 5 button on the remote control 17. Press the 2 button on the remote control 18. Press the 5 button on the remote control 19. Press the 5 button on the remote control 20. Press the Play button on the remote control 21. Press the Standby button on the remote control
Hope this works for you.
AndystUK
Nov 08, 2009 | Televison & Video
65 people viewed this question
 Grubhead
Grubhead
