Xerox xc1045 error u2
4 Suggested Answers
  • 2072 Answers
SOURCE: xerox 5314 copier giving error code of u2
A U2 means the machine did not see the lamp scan. The lamp did not leave the right side of the machine. May be hung up on something, may have broken a cable the scan motor may be bad, I would first of all remove the glass and see if there is anything binding the lamp and keeping it from scanning. If you think it feels tight to move, that is normal on a 5314. What I am looking for is the lamp stopping not being able to move.
Posted on Mar 14, 2009
  • 2072 Answers
SOURCE: Getting an H4 Error code on my Xerox XC1045
This will most likely clear it. If not then the heat rod in the fuser most likely went bad.
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. Program the copier as if you were going to make 14 copies.
  7. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  8. Run a test copy.
  9. repeat 1-7 more than once to be sure it has worked properly.
There was incorrect info in this I copied and pasted. I corrected it.
Posted on Feb 23, 2010
SOURCE: My sharp a163 xerox machine
U2 -40 cause when the toner cartridge crum data read error
Execute SIM 16 and checke you install a specified toner cartridge
Posted on Dec 24, 2010
Xc1045 reset
Panel
Clear Button
Auto
Clear
Auto
14
Start
Apr 17, 2014 | Xerox Office Equipment & Supplies
U2 code for xerox work center 5020
U2-1 Carriage Module Fail
Maybe you can find more information in the service manual. About error codes go to page 20
Apr 16, 2014 | Xerox Office Equipment & Supplies
My sharp a163 xerox machine is give a u2 40 error code how can i solve it
Dec 24, 2010 | Sharp AR 163 Copier
I have a xerox 423 with au3-5 error.whats up?
i have a xerox 423 with u2-3 error code whats that
Dec 07, 2010 | Xerox WorkCentre Pro 423 Copier
Xerox wc pro 423 u2-3 problem
my Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
Nov 16, 2010 | Xerox WorkCentre Pro 423 Copier
How do I get rid of the annoying fault code 07-515.00 The Bypass Tray is empty.
I HAVE A XEROX XC1045 CAN YOU SHOW ME THE SYMBOLS THAT COME UP SO I CAN ASK THE QUESTION ON THE SYMBOL IT LOOKS LIKE A CHECK THE PRINTER WONT PRINT
Apr 30, 2010 | Xerox 5665 Copier
LA FOTOCOPIADORA XEROX 1025 COPIABA BIEN DE REPENTE ME MANDA U2
U2 = Memory failure.
moz-screenshot.jpgClear U2 error
Enter diagnostic mode
To enter diagnostics:
  1. Power on
  2. Press 'Clear' > 'Exposure' > 'Clear' > 'Exposure' buttons within 4 seconds.
  3. All the lamps on the control panel will go out.
  4. Enter the service mode using the 1 button.
Enter code 16
Press Start button
Exit diagnostics, by switching machine off.
If the error returns, you will need to replace the main board.
Good Luck!
Dec 05, 2009 | Xerox Office Equipment & Supplies
Xerox 5314 copier giving error code of u2
Mar 14, 2009 | Xerox Office Equipment & Supplies
12 people viewed this question
k24674
