Question about Kenmore 88732 Top Load Stacked Washer / Dryer
Over filling I just purchased this pre-used washer/dryer. The dryer works good, but the washer keeps overfilling. Regardless of wether or now I put the water lever at small, medium, or large. When i put it on small it loads about half way, it starts to wash, but then it starts collecting MORE water for some reason, this is when it overflows. When i put it on medium or large it overfills right from the start. I dont know waht the problem is; can you help me???
  • 209 Answers
Pressure switch pipe is either blocked or damaged, the weight of the water pushes air up the pipe to activate the switch to stop the water filling, for some reason its not doing so,
this is a small thin pipe that goes from a point in the machine low down, to a little round flat object (normally) up near the top of the machine inside up near the top
drain the machine and clear out the pipe at the bottom where it joins  the drum or whatever, make sure joints are made good
if i have helped please rate me
Posted on Oct 10, 2007
SOURCE:
Washer overfills, dosen't stop filling even after I cut washer off
bad water level switch or the clear plastic hose has a hole in it or popped off the water level switch or the pressure switch same thing.the switch works by pressure,if there's a hole in it or the line feel off there's no pressure and the switch keeps calling for water,shut the water valve off
Jul 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
Wahser does not stop filling water
replace the water inlet valve
May 03, 2009 | Washing Machines
? Overfills. Doesn't seem to acknowledge water
put the washer on fill,now turn it off,if the water stills fills it is a bad inlet water valve,if it does not the water level hose might have come off or the water level switch is bad,let me know what you find-mike
Apr 04, 2009 | Kenmore Washing Machines
My Maytag Washer keeps running water and won't stop.
regardless of machine being on or not???sounds like a faulty water inlet valve youll need to replace the valve..
If the water level just overfills and floods over the top of washer but turns off when the unit is shut off, then it sounds like a bad fill switch.
May 10, 2008 | Washing Machines
Re EW1200i : drum keeps filling with water
is it overfilling? if so you have a problem with the pressure side of the system and it would need cleaning out.
May 26, 2007 | Electrolux EW1200i Front Load Washer /...
Kenmore 88732 Top Load Stacked Washer / Dryer Logo
152 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
