Question about Sherwood Audio Players & Recorders
My sherwood RX-4209 switches off after 5 seconds and goes back into standby mode
As explained above
hawkwatcher
  • 67 Answers
SOURCE: startup
Going into protect due to either blown channel or probably a 15v regulator might be down which I have seen many times also. causing unit to go into protect.
Posted on Jan 31, 2008
robotek
  • 1512 Answers
SOURCE: My Sherwood RD6405 Switches on
Hi hyphen
Try a hard reset first. switch the amp off overnight and try it in the morning. If problems persist, is it covered with warranty from where you bought it? Best to go that route if it is. If not, get back to me here.
regards
Graeme
Posted on Mar 19, 2008
jomabug76
  • 1148 Answers
SOURCE: Sherwood RV-8070R, i can t switch it on
TRY BLOWING IT OUT WITH A AIR COMPRESSER
Posted on May 15, 2009
Bulldog AV
  • 52 Answers
SOURCE: after turning ON the power/standby switch, the
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Posted on Nov 24, 2009
jdvillanueva
  • 2098 Answers
SOURCE: The problem I ran into
Hi amit2817,
Your unit gone to overload that caused the subsequent shutdown. To isolate the input and speakers from fault, disconnect all input cables and speaker wire from the unit then turn it on naked. If the symptom still there then this is a clear indication that the fault came from the unit itself. Most common caused of this problem is the sound output circuitry and the power supply. Most common affected parts in the output section is the output IC/transistor(mounted in the large heat sink). It will fail because of exposure to excessive heat due to frequent high volume and or because of aging. Bad solder joints is also to consider to this section and also to the power supply section. Because of heat build up, most of the joints dried resulting to poor flow of the supply and trigger the over current(overload) protection circuit. Leaky electrolytic filter capacitor is also one of the factor in this fault. It will produce an out-of-regulation to the power supply output. You must have a capacitor checker to determine its condition. Sometimes it has a bulged/dome at the top but not all.
If you don't have necessary tools and test instrument and can't troubleshoot the symptom, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 02, 2011
Why does it turn on sporadically, stay on briefly, then turn off?
Sounds like a defect to me return it for a working model.
Jun 01, 2015 | Sherwood RX-4105 2-CHANNEL...
I have Sherwood rd-6106 amplifier and when i turn him on it goes back to standby after few seconds. can anyone help?
bad fuse, something is sending it to sand by to keep from ruining the rest of it, have it looked at by a pro technician
Feb 02, 2015 | Sherwood Audio Players & Recorders
Why Sherwood Receiver will NOT turn off. It's stuck in VCR mode?
Unless it has some kind of "child lock" mode, in which case you should see the manual about how to reset it. It sounds to me that there is a fault on the microprocessor that controls the functions. It's not something that could be solved other than by an engineer.
Look around for a service centre for Sherwood on the net. Richer Sounds in the UK sold a lot of these, they might be able to help you.
Aug 14, 2014 | Sherwood RX-4103 Receiver
Sherwood
does a code pop up like f20 or just any code
Mar 20, 2013 | Audio Players & Recorders
When power is turned on, standby light comes on normally, but in any playing mode, the receiver switches off and the standby light flashes.
It looks like this is a common problem with a lot of the Sherwood Receivers. I've had the same problem with my R-125RDS for a while now. Finally hit on solution today by replacing a power transistor. The transistor in question is not on the power amp board but instead screwed to the chassis and wired to the mainboard. I believe it is part of the output short protection circuit. In my case the component was a 2SD2059 (silicon NPN 100V,5A) replaced by equivalent 2SD1407. The transistor seems to run pretty warm so I guess this is why they ultimately fail after a few years.
Sep 17, 2011 | Sherwood RX-5502 Receiver
Sherwood RX-4105 Receiver will not stay on
Sorry to be the bearer of bad news but your unit has either a bad power supply or bad transistors and need serviced. Under 200 for the repair however, I'm not sure what the unit sells for new but weight the costs vs replacement. Hope this helps
Jun 06, 2009 | Sherwood RX-4105 Receiver
May 13, 2009 | Sherwood RX-4109
Sherwood 6500 reciver
check your speaker wires make sure they are not shorting against each other down the line, that will cause the reciever to go into standby.
Jan 25, 2009 | Insignia 200W Stereo Receiver
My Sherwood RD6405 Switches on for about 5 seconds from standby when you choose an input source but then goes back to standby. It has only had about 12 hours use in total.
Hi hyphen
regards
Graeme
Mar 19, 2008 | Audio Players & Recorders
105 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
