Question about Philips DVR-1
I ran the coax cable from the antenna to the RF IN connection, ran another cable from RF OUT to the television and used an HDMI cable to connect the DVR to the televison. The instructions say press '2' on the television remote, then press the channel down button until the set up menu appears. I've been through the channels several times and I don't see the set up menu. I've tried channel 3, channel 4, video 1, (2,3,4,&5). I'm at my wits ends because I can't set up the DVR.
  • 696 Answers
Just a quick suggestion, many of those 2 then down type instruction actually mean hold the two then while holding it press the down button. Try that then if not reply back with the make and model # of the unit and I'll do a little digging for you.
Chris
Posted on May 08, 2009
If i connect the hdmi cable i do not need an antenna cable?
You need an antenna cable to be connected to something that is connected to your tv or you will not get a signal!
Apr 02, 2016 | Televison & Video
How do I hook up an antenna to the tv? There is no antenna in coax connection. Do I need a converter box too?
there HAS to be a coax connection,unless it is broken off,in that case you need to replace the control board you wont be able to use an antena without it,if using cable box,use hdmi input
Jul 16, 2015 | Televison & Video
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
Hooking up antena & converter box
Good: Connect the antenna to the converter box where it says antenna/in. Connect the coax cable to where it says to tv/out on the converter box. Connect this cable to the coax/rf input on the television. Plug in and turn on the converter box and the television. Make sure the television is on channel 3 and follow the setup process that pops up on the screen.
Better: Connect RCA cables to the converter box where the yellow red and white holes are. Connect them to an RCA input on your television. If you don't have a red hole on the television that's ok, just connect yellow and white and leave the red plug dangling. Connect the antenna to the converter box where it says antenna/in. Plug in everything and turn everything on. Press the video/input/source button until you have located the setup screen for the converter box and follow the directions on the screen.
Dec 02, 2012 | GE 27GT271 TV
Tv color was on and off
What is your signal source, i.e. Cable Box, Satellitre Box, DTV Converter or Over The Air Antenna? Also, how is that device connected. i.e. RF Coax, Composite AV (Tellow/Red/White), Component (Red/Green/Blue) or HDMI?
Mar 13, 2011 | Televison & Video
Where is my cable output on my Philips TV 32PF7321D/37. How do I get cable on my TV I cannot find a cable output! please help
your output cable is in the back of your t.v. there is a color designated on its hole then you have to buy a a cable in any electronic shop like components cable or hdmi cable try to read the back panel of your tv
Mar 10, 2011 | Philips 32PF7421D 32 in. LCD HDTV
I have an analog tv (coax cable) and a new dvd (av plugs) player. How do I inexpensively connect them? i saw the solution posted about the rf modulator. I have a digital to analog tv convertor. Is this...
NO. An RF modulator and your digital-to-analog (DAC) TV converter are 2 different devices. The DAC will convert over-the-air (OTA) digital television signals from your antenna to analog NTSC format so your older analog TV can receive OTA broadcasts. The RF modulator converts base-band video (composite cable/RCA connector, or S-Video cable connector) to channel 3 or 4, so you can watch video/audio on your set. To use both the RF mod. and the DAC converter to the same TV, use an A/B switch for F-connector coax, or follow the directions for the RF modulator to make the correct connections.
Jun 12, 2010 | Televison & Video
I have an LG 26LC7D and the picture from the
is the rf connector loose? if so a tech will have to open up the set and try to reattach the coax connection to the mainboard
Dec 07, 2009 | LG 26LC7D Television
Connection problem
The best hook up for this unit is to use the hdmi if your samsung box offers hdmi output. The panasonic vcr should be hooked to any one of the composit video inputs with the yellow video cable and the red and white audio cables. If the vcr does not have composite output then use a rf (coax cable) to antenna a input and put the tv on channel 3 or 4 as vcr is set for.
Jan 13, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Cable connection to Onkyo TX-SR605 7.1
You will have to connect your coax to the tv coax input.You can view cable this way.To use the hdmi input to tv,you will have to change your input settings back and forth on the tv menu from hdmi to rf input.There is no way to hook your cable to the txsr.
Oct 22, 2007 | Onkyo TX-SR604 Receiver
Philips DVR-1 Logo
106 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
