Question about LG WM2016CW Front Load Washer
On my lg front load washing machine te spin speed light blinks continously
  • 351 Answers
SOURCE: 7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Posted on Mar 04, 2008
SOURCE: LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Posted on Jan 08, 2009
SOURCE: LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Posted on Apr 11, 2009
SOURCE: Front Loading LG Washing Machine leaves smelly sludge in wash tub
This machine has a tub clean feature that you're supposed to run with bleach. I did this and it helped the smell s bit. Recently we had an error code and the repair man that came to fix it gave me some good tips. His experience has been that the smell is from too much soap causing build up in the seal and along the tub. His suggestion was to cut back on the amount of he detergent (he said a tablespoon is sufficient). His company recommends using a product called Whirlout (you can buy it at Home Depot). It was originally meant to clean scum out of hot tub jets. Apparently if you call LG they will recommend this product, but haven't bothered to suggest it in the owner's manual. I was told to put one to two capfuls directly into the tub (not the detergent bay) and run the tub clean cycle. I used it last night and it worked - no more musty, yucky smell!
Posted on Jul 09, 2009
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
https://www.youtube.com/watch?v=vKeIDM78CFI
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
https://www.youtube.com/watch?v=a-ONJ2_RQvk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
My washer will spin a little and stop. And the wash light is blinking
We were having the same problem and had a repair tech come out. We were told that we'd need a new basket bearing, but it's only sold with the basket. Also, it could e te complete pump motor assembly. He told us that it would cost over $600. I purchased the complee basket assembly w/bearing for $168.08, through SearsDirect. They sent me the wrong pump, s I'm sending it back. To order the correct one, won't be in stock unil 11/22, so I ordered it from AppliancePartsPros.com or $50.00. Husband is working on it. Level of difficulty is med. skill.
Oct 11, 2012 | LG WM-2277HW Front Load Washer
I have a Lg WM2277HW front load washer. I replaced P/N 6501KW2002 (hall sensor), unfortunately still recieving error code LE. I even ran normal wash cycle no spin and 3 rinse and spins w/ no spin to...
Make sure hall sensor is snapped in to correct location and is secure. Take a look at repair videos from repairclinic.com or appliancepartspros.com for guidance. And the error code is "LE" for sure not "tE" which is sometimes confused between the two.
Apr 29, 2017 | LG WM2277H Front Load Washer
What does LEstand for on the washer machine??
LE stands for Load Error. You may have a bad hall sensor, but more likely have an off balance or very heavy load which you were trying to spin at a high speed. For heavy / bulky items, use the low spin speed. After the cycle, you can power the machine up again and just push the spin speed button until the next higher speed shows, then push start to get a 14 minute or so pump and spin only cycle if you want to spin the load out a bit more.
Jun 14, 2010 | LG WM-2277HW Front Load Washer
LG WM-2277HW will stop at the rinse cycle and flash te code. Manual says to unplug and call tech. Is there anything else that can be done?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | LG WM-2277HW Front Load Washer
My washer is blinking upside down F and E. Manual
It is actually a TE and should be the thermistor Part#
1268202
May 08, 2010 | LG WM227HW Front Load Stackable Washing...
Washer is showing "TE" error even after replacing the thermistor
Try pressing spin speed and soild level at the same time. Is the temperature about 10 degrees C over the the selected temperature? If no, then try replacing the main board.
Also make sure the thermister isn't loose. That could cause your problem.
If the main board doesn't fix it, then you have to replace the heater assembly.
Im actually looking the the service manual your unit as we speak.
May 27, 2009 | LG WM2277H Front Load Washer
MACHINE RUNNIMG STOPPED SUDDENLY WITH THE LIGHTS BLINKING AND WE TRIED TO RESTART IT AGAIN AFTER DRAINING THE WATER THROUGH THE OUTLET PIPE &OPENED THE DOOR REMOVED THE CLOTHES AND RESTARTED IT AGAIN BUT...
turn on power switch,then press the spin speed button then push start, the water should drain then spin. if the water does not drain chech the drain pump button trap, located lower left front panel.
Dec 30, 2008 | LG WM-2277HW Front Load Washer
Spin speed
If that light is blinking, it's because the spinssense is turned on. If you look at the lighted buttons all the way on the top right of the machine, one of them says spinsense under it. While the machine is running, press and hold that button for 3 seconds. You'll hear a little chime and the light should stop blinking. It's supposed to help vibrations on wood floors.
Oct 16, 2007 | LG WM-2277HW Front Load Washer
LG WM2016CW Front Load Washer Logo
23 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
