Question about Dell OPTIPLEX 960 MT Desktop Computer (Intel Core 2 Duo E8400 250GB2GB) (BO5SC306)
My Optiplex 960 flashes amber 3 light when powering on.
Unit flashes amber 3 light and does not power up. This usually indicates Motherboard issue. Whats unusual is if I press the power supply test button the system will power up and be usable with no obvious issues, until powered off. Then the issue of power button comes back.
Hey, have you ever thought that you ANSWERED YOUR OWN question? If you press the power supply TEST button, then it powers up fully? It's NOT the button.......So...what else could it BE then Mitch?
Posted on May 01, 2014
  • 326 Answers
SOURCE: Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
Posted on Aug 11, 2008
jelacio
  • 10 Answers
SOURCE: I have a flickering amber light on the power button; replaced power supply and motherboard with no luck
FIRST IF YOU REPLACED THE POWER SUPPLY OF YOUR DELL PC,
MAKE SURE IS A RECOMMEND POWER SUPPLY FOR DELL COMPUTERS ONLY
BECAUSE DELL USE A DIFFERENT (NONSTARD) PS
AN PLEASE DON'T TURN YOUR PC ON, TILE YOU ARE SURE I'TS A DELL COMPATIBLE POWER SUPPLY
YOU CAN FRY YOUR COMPUTER
ON THE MOTHERBOARD I'T MAY BE THE BIOS (BIOS STANDS FOR INPUT /OUTPUT SYSTEM) I'T A CHIP ON YOUR MOTHERBOARD THAT CONTROLS THE SYSTEM HARDWARE AND ACTS AS AN INTERFACE BETWEEN THE OPERATING SYSTEM AND THE HARDWARE
I'T MAY BE FLASH
IF IS FLASH ,
YOU PROBABLY NEED TO REPLACE THE MOTHERBOARD
OR CALL DELL TO SEE IF THEY CAN FIX IT
Posted on Aug 20, 2008
  • 3 Answers
SOURCE: Dell Dimension 5150 will not boot. Flashes amber light
I had the same issue with my Dell Dimension 5150 and I replaced the front I/O USB Audio Panel and it booted right up.
Posted on Jul 09, 2009
chiplevel
  • 656 Answers
SOURCE: When dell optiplex 760 pc
rmove the memory from the slot and clean it with a neat cloth and insert and switch on the computer if still not working remove the processor heat sink and clean it with a cloth apply some thin layer of heatsink solvent and fix them tightly also remove the cmos battery from the motherboard and switch on the computer then shutdown the computer and replace camos battery
Posted on Dec 30, 2010
SD Tech
  • 14553 Answers
SOURCE: Vostro 230 - Solid Amber Power Light
"power supply seems to be working?" If you had before this happened a issue where had to turn it on a few times to get it up---suspect bad caps in power supply---A look inside that will tell you if this is the issue or not. If the supply can be removed (most can) it can be examined or tested by most repair shops for little or nothing.
see attached photos of what bad caps look like in case you remove the supply to look at it.
Posted on Jun 15, 2012
How to solve orange solid light on my dell GX520 when i boot it
Nana, A solid amber power button on your GX520, indicates a motherboard failure. The motherboard will need replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Solid orange power button on Optiplex GX520
My Dell Optiplex GX520 will not boot Forums
Dell Optiplex GX520 amber solid light no power
Aug 05, 2016 | Dell Computers & Internet
Optiplex 960 number 3 blinking
The #3 light is an indication of a processor problem. You may have a bad cooling fan, or a poor heatsink connection, or just a failing processor. The fact that it resets makes me think more along the lines of a fan issue. Here is a list of the codes and what they mean:
http://f5k.wikia.com/wiki/Front_Panel_Lights_-_Optiplex_755,_960,_980
Feb 15, 2016 | Computers & Internet
Flashing amber light
Hi, on most Dells a flashing amber light on the power button indicates a problem with the PSU or a short on the main power rail, if this is the case you should have 2 flashing lights as well, 1 & 3.
May 05, 2014 | Dell OptiPlex 3010 MT Desktop Computer
Why is dell optiplex 780 lights 1 & 3 ok and power button amber?
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard.
Remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 28, 2014 | Dell OptiPlex 780 MT Desktop Computer...
Del 320 optiplex orange lite blinks won't boot up
For the Optiplex 320, a flashing amber light with no sound indication can mean 3 things.
1) Your power supply has failed
2) Your motherboard failed, most likely from a bad capacitor.
3) The front panel board (where the power button is located) is faulty or not connected properly.
I've worked with 10's of 1000's of Dell Optiplex's over the past 8 years and the flashing amber light is well known as a tell-tail sign of one of those three failure. Always start your trouble shoot with a PSU tester, then inspect the motherboard for domed or split/leaking capacitors...then on to the front panel which would require another panel and ribbon from the same model.
Jan 25, 2014 | Dell Optiplex GX280 (99301) Motherboard
We have around 30 units of DELL Optiplex GX280 having mother board failure. It was more then 3 years old already. Once the turbo fan become noisy then it will gone dead.
May be serious. See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans sound like 747 taking off. Power light goes and stays amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad.
I obviously can not be 100% sure about this as the unit is not here.
You can google "gx280 solid amber light loud fan" and see the issues. Here is one such link.
http://en.community.dell.com/support-forums/desktop/f/3514/p/19253544/19414291.aspx
Feb 16, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
I have a Dell Optiplex 210L when i push the power button a solid amber light appear.. thanks any suggestion
Click here to visit dell support. The documentation provides details about the light codes and diagnostic procedure.
I think it is a power issue, which is usually indicated by amber light on dell systems. I came accross dell systems with similar indication and the issue was improper voltage either due to faulty power supply or bad connection.
Therefore, i suggest that: -
First, make sure that the connections and voltage to your system is proper.
Also, get the power sully unit checked by a professional for its proper functioning. I may require repair or replacement.
Let me know if any further clarification is required. Hope this helps!
CreativeTECH
Nov 26, 2010 | Dell OptiPlex 210L N (210LNDCELMIN) PC...
I get orange light on my power button when i power my dell optiplex 330 pc
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Flashing Amber, bad power supply
Solid Amber either a bad component connected to motherboard of the motherboard itself has failed
Jun 23, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
My optiplex 330 is not powering up.the power botton flashes orangy bright when the pc is turned on.what the problem there please
The common issue related with a Flashing Amber Power Light is a BAD POWER SUPPLY. If the Amber Light is SOLID then it may be your MOTHERBOARD.
But if it is flashing repeatedly then it is your power supply, you will need to purchase a new one. Good Luck.
Oct 08, 2009 | Dell OptiPlex 330 Desktop Desktop Computer...
Dell OPTIPLEX 960 MT Desktop Computer (Intel Core 2 Duo E8400 250GB2GB) (BO5SC306) Logo
311 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
