Question about SanDisk Sansa e250 MP3 Player
Player doesn't seem to recognize songs.
Recently when I went to create folders for 'Artists' and uploaded the songs to each folder, (About Seven Songs) The Explorer via the computer shows the folders, and mp3s on the e250.. but when the player is disconnected, It Refreshes and the songs are not showing up on it.
[They still show up if I browse the player through the pc]
Not sure why it won't recognize them.. maybe someone else does? :)
  • Mayseth Oct 14, 2007
    Alright, I've tried that and the songs show up while connected through USB, and I can play the songs that are on the player with Windows media player.. but the sansa still doesn't show them once disconnected. All the song bitrates check out.
    Scholar:
  • 155 Answers
Try transferring the songs directly to the music folder of the player and check if they would be recognized by the player. And make sure the Bitrate is in the range of 120-320kbps .
Posted on Oct 14, 2007
SOURCE:
How do I put songs in playlist on my Coby MP620 MP3 player
The Coby is weird, but I found a way to create playlists. It might not be the "real" way, but it works :)
Before I plug the mp3 in my computer I create folders containing the songs I want for each play list. For example I'd create one folder labeled "work out" for songs I want to listen to while working out, and another folder labeled "sleep" for songs to listen to while sleeping, or you could label them based on artists or genre or etc. Then I would copy the songs I want in each playlist into their respective folders.
Next, I plug my coby into my computer, and open it's folder. (should be in computers, and have a icon with a C on it). I'd copy (or click and drag into the coby folder) my play list folders (the ones I labeled work out and sleep). Then eject and remove my mp3.
If you do this, when you turn on your mp3 you should select Music. Then select Broswer (on the bottom). Select the first row, which has the symbol "\" [underneath this is all your songs] and you'll see the names of your play list folders (they'll be below ROOT, MAC OS X Coby Me, and PHOTOS) . If you select your play list name you'll see and be able to play the songs under that playlist.
Feb 19, 2013 | Coby MP620 MP3 Player
When I press
it's because the iriver doesn't reconize the artist. the artist name, album etc is set in the file's info. you can write that info yourself so the iriver can reconize it. for example I opened Winamp, imported the songs I wanted in my iriver, right clicked on the the first songin my list, selected FILE INFO and went on and completed the artist field myself. did the same to every other song....and now the iriver reconizez the artists.....it takes some time indeed...and I don't know of any other easyer method that works.....but this one surely will. good luck :)
Dec 15, 2009 | iRiver E100 Digital Media Player
How do i move my songs on my mp3 player?
I connected to my Laptop and created folders to contain different albums or songlists. If you want songs sorted by artists or name, that also can be done on a PC folder prior to selecting and copying back to the MP3 player. This worked for me.
Dec 10, 2008 | Audio Players & Recorders
Insignia sport 4 gig wont organize by artist
You will need to right click on the song file to see if the ID3 information is present.
Right-click, Properties, Summary tab.
You shoudl see a list of fields that you can populate manually, or you can try loading your audio files into a media manger program like iTunes, Media Monkey, WMP, etc and insure your song titles and album names are correct in the ID3 tag fields. Then, your files will appear correctly on your player.
Hope this helps!
Nov 01, 2008 | Insignia Sport MP3 Player
Sylvania smpk4066 mp3 player
The problem is the files.
What I'm doing right now is going through the files, cutting and pasting the individual mp3 files (Not the folders) to a temp file, deleting the artist and album folders from the player, and cutting and pasting them back into the player.
This is very labour intensive.
The player will look at how many folders (artist) sub-folders (album) then songs. When it hits 500 it stops looking. I had about 100 artists with several albums for most. It would only list 2 songs. I've deleted several artists (and sub-directories) and copied the songs onto the player (no folders) now I'm up to about 20 songs.
The "easiest" way to load the player is to copy/paste individual mp3's onto the player.
I'm looking for a firmware upgrade but I don't think I'll find one. The players seem to be made by Curtis International ( www.curtisinst.com )
link to manuals page for sylvania players:
http://www.curtisint.com/web/category-Sub.asp?category=MP3s&subCat=MP3&catName=MP3%20PLAYERS&p=2
Aug 16, 2008 | iLO MP3 Player
I can't find my songs or hear them
I came across the same problem with my Muvo V100. It appears that the unit has a folder access limit of some kind (seems to be 24 folders not sure what detrmines the ones it chooses). I synch with Windows media player and it creates a folder called Music in the root. Within that folder it places sub folders named for the band that the music is from. Within those folders it creates yet further sub folders with the name of the CD the music came from and then finally within those it places the MP3 or WMA files. It appears there may be too many sub folders for the Muvo to be able read all the music. I took all of the MP3 and WMA files and pulled them out to the main Music folder. I then deleted all of the sub folders named for the bands and the albums. When I start the Muvo now it allows access to all of the songs. There may be a way within Windows media player to configure the synch so it doesn't create all of these sub folders. I've not checked. If it is then it would eliminate the manual work of pulling the music files out to the main Music sub folder.
Jul 01, 2008 | Creative Labs Muvo V100 MP3 Player
I Need Help.
Your database is corrupt - get the firmware upgrade from the Philips website - www.usasupport.philips.com
If the upgrade does not create a pictures folder, then use the Arcsoft Media Converter that came with the player to transfer the pictures
The user's manual for that player is also on the Philips website
Jun 19, 2008 | Philips HDD1630 MP3 Player
Will not play all songs on mp3 cd
It's possible you are reaching the 99 folder limit of the deck. Count how many folders (artist folders and album folders) there are between Alkaline Trio through John Butler Trio. The manual says there is a maximum of 99 folders acceptable, but it doesn't say what happens if you have more.
I also assume the bitrate of the songs is 320kpbs or below, yes?
The manual also mentions "Folder hierarchy is allowed up to eight tiers. However, practical hierarchy of folder is less than two tiers", whatever that might mean.
Mar 07, 2008 | Pioneer DEH-P690UB CD Player
Infinite folders and inability to play music
You need to reinstall the firmware, which can be found on Sansa's site. If this is not an option, which it likely is NOT, you need to send the device out via the MFG warranty, or just send it to the MFG. If you look into the files on this device, it has a VERY VERY bad history with performance on this site. I hope this helps! problem solved!
Aug 07, 2007 | SanDisk Sansa E280 MP3 Player
Problem with Sony Walkman NW-S705
This is because the player does not recognize tracks that havent been uploaded by Sonic Stage(You might have a CD of this software along with an mp3 player)
Jun 21, 2007 | Sony Walkman NW-S705 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
80 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
