Question about Cameras
My Rebel dslr shows a small image on the lcd and says "incompatible jpeg file". When I upload the images to my computer, the images are incomplete and appear only as part of the image.
  • 1 more comment
  •  Gail A. McHenry
    Gail A. McHenry May 08, 2009
    Thanks, but I was hoping there would be a solution other than camera repair. Does anyone think there's another cause for this problem?
    Thanks again,
    Gail
  •  Gail A. McHenry
    Thanks again,
    Gail
  •  Gail A. McHenry
    Thanks so much for your response.  I can't follow it because all the little images, e.g., tab identification, appear in your message as .  Could you revise your message so I can see which buttons to push?
    Thanks again,
    Gail
  • Cameras Master
  • 6,487 Answers
What you can try first in here is to reset the unit to default settings and check if that will correct the problem...
Posted on May 08, 2009
    Genius:
  • 1,142 Answers
Please reset the camera to the factory settings follow the instructions and this will take care of the issue.
Solution: How to reset the EOS Digital Rebel to its default settings.
My Rebel dslr shows a - resetcamera1.gif 1. Select [Clear all camera settings].
  • Set the Mode Dial to one of the Creative Zone Modes.
  • Select the [setup2.gif] tab.
  • Press the <leftright.gif> keys to select [Clear all camera settings], tMy Rebel dslr shows a - set.gifss <set.gif
resetcamera2.gif 2. Clear the settings.
  • Press the <> key to select [OK], then press <set.gif>. The camera settings will then be reset to the default settings.
  • The camera's default settings will be as shown below.Shooting Settings
  • AF point selection Automatic Drive mode SingleMy Rebel dslr shows a - largefine.gifcompensation 0 (Zero) AEB Canceled Image Recording Settings Quality largefine.gif(Large/Fine) ISO speed 100 White balance awb.gif(Auto) WB-BKT Canceled Parameters Parameter 1 Auto rotate On File numbering Continuous
    • Maanita Chadha
      Maanita Chadha May 08, 2009
      How to adjust the image recording quality settings on the EOS Digital Rebel.
      The widely-used JPEG format is used for image-recording quality settings other than <>. images captured in the <> format must later be processed by a personal computer. For example, when [] is selected, the LCD panel will display <>.
      _
      1. Select [Quality].
      • Select the <> tab.
      • Press the <> keys to select [Quality], then press <>.
      2. Select the image-recording quality.
      • Press the <> keys to select the desired image-recording quality, then press <>.
      Image-recording Quality Settings
      Large
      For A4-size (297 x 210 mm) prints. Records a large image size (approx. 6.30 megapixels).
      Medium
      For A5 to A4-size prints. Records a medium-size image (approx. 2.80 megapixels).
      Small
      For A5-size (210 x 148 mm) or smaller prints. Records a small image size (approx. 1.60 megapixels).
      RAW
      For A4-size (297 x 210 mm) and larger prints. Records a large image size (approx. 6.30 megapixels) without image quality degradation.
      • This format assumes that the image will be processed by a personal computer. Special knowledge is required, but you can use the bundled software to obtain the desired effect.
      • RAW images cannot be printed directly from the camera.
      • The <> (Fine) and <> (Normal) icons indicate the images compression rate. For better image quality, select <> for low compression. To save space so you can record more images, select higher compression <>.
      • Processing is the adjustment (such as the white balance and contrast) of the image from the RAW data.
    • 3,267 Answers
    I went & searched the canon site for a suitable answer and the important I found that you can get direct help via email or by telephoning their technical rep. who will be able to inteact with. Hence I am forwarding these details to you. Hope this helps.............sodeep
    Issue:
    The LCD/Electronic Viewfinder will not display an image or the image is distorted.
    Solution: If all troubleshooting has failed, please have your EOS Digital Rebel serviced.
    If all troubleshooting steps have failed, then the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need. Links to the service options that are available for your product are listed below:
    Request a Repair Online You can conveniently pre-arrange repair service with a Canon Factory Service Center through Canon's website. Find a Service Location Search to locate a repair service center and obtain further instructions. If you still have questions about the issue you are experiencing, a Technical Support Representative will be happy to answer any question you may have. You can contact us through the email link or phone numbers listed below.
    • Obtain Support by Email
    • For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
    • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
    • Technical Support is available for Customers in Canada at 1-800-OK-CANON
    We look forward to helping you rectify the issue you are experiencing and are always available to provide any assistance you may need.
    How do I minimize jpegs in a power point file
    Right click on each image file -> open with -> Microsoft Office Picture Manager -> Picture -> Resize -> Percentage of Original Width and Height -> select an appropriate size reduction percentage -> OK -> File -> Save As -> name new resized image -> Save -> upload resized file to presentation.
    Nov 12, 2011 | Microsoft Office Professional 2007 Full...
    Raw Format Ooops
    hi there,
    you can use a memory card reader, if your camera software was faulty to use..
    Thank you
    May 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
    Why can't I upload my photos from my finepix s1500 onto my mac? It opened the files in my iphoto but they showed up as blank boxes and "Error downloading images - iPhoto cannot import your photos...
    Is this a new problem - that is, did it work in the past? Are you trying to import jpeg or raw?
    First thing is to see if it is iphoto or the camera that has a problem.
    Try uploading the images to another computer (try a PC - not that it is better, but PC is different). If the images can be seen & read there, the images are likely fine and iphoto may need an upgrade to read the format from the finepix s1500. Alternately, try copying the photos from your memory card (use a memory card reader) to your hard disk. See if another application can see the images (even use a word processor to import image), or e-mail the image to yourself and then use your web-browser to see the image.
    If the camera images can't be read by multiple computers/multiple readers, then it may be that your memory card is corrupted.
    Feb 25, 2011 | Cameras
    Recently purchased a Canon 550D and when previewing an image on the camera, it appears fine. After switching it on and off, the image appears as a small version with "Can not display preview". ...
    you maybe taking shots in raw which is fine but depending on what OS you have and computer hardware might mean your pc is struggling to open them. might want to check your photo resolution settings by pressing menu button and on the first list you should see the quality mode your using try taking shots in jpeg see if that helps.
    if its already taking photos in jpeg then i highly recommend downloading picasa as it has an excellent photo viewer which you can enable as your default photo viewer. opens raw and jpeg photos no problem.
    Jan 05, 2011 | Canon EOS 550D Rebel T2i Digital Camera
    We have inserted sd-ms card onto our laptop to upload the photos onto FB.however the card when inserted back onto the camera, about 50 over images show, incompatible jpeg?how do we solve this issue?
    The computer uses a small program to be able to upload pictures from the memory card once the pictures are safely on the computer hard drive hopefully you created a file folder for them then the memory card needs to be formatted in the camera. Formatting the memory card cleans the card and makes it compatible to the camera again. Every time you download images to the computer the memory needs formatting in the camera. Any new memory card needs formatting in the camera a card that has been formatted in the computer needs to be reformatted in the camera. Also please be aware that there is a protection lock on the side of the SD card and if placed in the incorrect orientation will actually lock the card from formatting or deleting files on the card. I'm going to include a diagram here to show you where this little switch need to be for the "unlock" position.
    Switch needs to be towards the top of the card in the direction of the gold contacts
    Jan 02, 2011 | Cameras
    Importing Images
    The CR2 suffix means that the picture was taken in the RAW file format, a proprietary format. This requires that the images be processed by a software conversion to be 'readable' by the computer. The EOS Utility software that came with the camera will work, as well as a number of third-party software packages. GOOGLE "raw file conversion Canon digital rebel" to see the options.
    The other option is to take your photos in JPEG format (not RAW). Your computer can 'read' any JPEG format image.
    Feb 28, 2010 | Canon Digital Rebel / EOS-300D Digital...
    Canon does not let me view some pictures on the LCD screen
    My guess would be that the program you are using in your computer is not a Canon product. If this is the case, it is possible the program may have automatically adjusted the image, red eye correction or ? thus changing the image and making it impossible for the camera to read the file.
    Aug 27, 2009 | Canon IXUS 80 IS Digital Camera
    No Preview image on screen, Must use Viewfinder
    yep
    sorry you bought a DSLR...its impossible...
    only with the new DSLR's its possible, (rebel XSi & rebel XS)
    this feature is called 'live view'.
    Nov 13, 2008 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
    Uploads images to camera grayed out
    Are you shooting in JPEG or RAW.
    If Jpeg then you can just go into MY COMPUTER, the camera when connected should be recognised as a removable drive, just copy the images directly from your PC to the Card. If you are shooting in RAW then the chances are your digital frame will not recognise the file, convert to JPEG then transfer the same way. There may be a problem with the transfer process via the Canon Drivers, if you have a Card reader it is much easier to transfer the files that way.
    May 13, 2008 | Canon Rebel XT / EOS 350D Digital Camera
    Canon eos digital canon rebel xti - LCD won't work when shooting
    Most DSLR cameras (like your Canon) don't have a live view - in other words, you can't "see" the image before you capture it. You must use the viewfinder.
    Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
    Cameras Logo
    61 people viewed this question
    Top Cameras Experts
    Steve
    Are you a Camera Expert? Answer questions, earn points and help others
