Question about Texas Instruments Office Equipment & Supplies
Convert decimal to sexagecimal - Texas Instruments Office Equipment & Supplies
How do I convert decimals to fractions on the TI Math Explorer (No numbers associated with it - i.e. TI - 15)?
The way it works is as follow. If a result is displayed as a fraction you can convert it to its decimal representation. If you do nothing after the conversion, you can revert the decimal representation to the fraction.
Apr 29, 2014 | Texas Instruments Office Equipment &...
Convert decimal fraction to binary
None of these solutions answer his question. When converting a fraction or any number with decimal places to Binary, the TI-89 gives "Error: Domain error." For example, entering .6875 [2ND][MATH][BASE][BIN] does not work. I haven't found a way to do it with built in functions. In order to do these types of conversions, I use the following method.
Convert: 0.6875 to Binary
- left of decimal is a 0, so write down a 0, then a decimal point: (0.)
- multiply .6875 x 2 = 1.375 left of decimal is 1, write a 1: (0.1)
- drop the 1 and multiply .375 x 2 = .75 left of decimal is 0. write a 0: (0.10)
- multiply .75 x 2 = 1.5 left of decimal is 1, write a 1: (0.101)
- drop the 1, multiple .5 x 2 = 1. left of decimal is 1, write a 1: (0.1011).
- since there is no more fraction, the final answer is (0.1011). Hope this helps.
Jan 27, 2012 | Texas Instruments TI-89 Calculator
How to program puting a pecentage?
Sad as it may be, this calculator does not have a % button/key/menu. So do not look for it. However you can still convert your decimal numbers to percent values.
1 %= 1 per cent (100) = 1/100=0.01
0.01=0.01*100/100=(0.01*100)/100=1/100=1%
To convert a decimal number to %, move the decimal mark two places to the right.
To convert a percent value to a decimal value, move the decimal mark two places to the left and drop the % symbol.
75%=0.75
135%=1.35
Aug 12, 2011 | Texas Instruments TI-84 Plus Calculator
How do I convert from decimals to fraction with my TI-30X IIS calculator? I need the step by step process
The following examples will demonstrate how to convert decimals into fractions using the TI-30Xa and TI-30Xa Solar. Please be aware that TI-30Xa Solar School Edition calculators do not have this functionality.
Example: Convert .25 to 1/4
- Input .25, press [2nd][<--] (says F<>D above it).
** F<>D means fraction to decimal, decimal to fraction.
Example: Convert 1.38 to 1_19/50
- Input 1.38, press [2nd][<--].
Example: Convert 9.75 to 9_3/4
- Input 9.75, press [2nd]{<--].
Mar 08, 2011 | Texas Instruments TI-30XA Calculator
Can you convert a decimal to a fration on the fx-300MS scientific calculator? If so how?
To convert a fraction to a decimal or a decimal to fraction you use the [a b/c] key.
While converting a fraction to a decimal number is always possible, converting a decimal to a fraction may, at times, not be possible.
Sep 10, 2010 | Casio FX-300MS Calculator
How to convert fractions to decimals
To convert fractions to decimals, and decimals to fractions use the [a b/c] key. If the total number of symbols (num, denom, fraction bar) to display a fraction exceeds 10, the fraction is automatically converted to decimal format.
Jul 19, 2010 | Casio FX-300MS Calculator
Conversion of decimals to fractions 0.1666666666666666666666666 = 1/6
You can always convert a fraction to a decimal. The reverse may not always be possible. Look at the example on the screen capture.
You may be lucky and recover a fraction you have just converted into decimal format, but you cannot just write 0.333333333333 and expect the calculator to convert it to 1/3: The true fraction 1/3 has an infinite number of 3's after the decimal mark.
May 26, 2010 | Casio FX-260 Calculator
Say for instant i wanted to do a promblem 75 divided by 100 = 3/4 i want change answer that is a fraction to a decimal i can the answer clear
75/100 [=] gives 3/4. Press [S<->D] key to convert to decimal 0.75
0.75 [=] gives 0.75 Press [S<->D] key to convert to fraction 3/4
It can convert radicals into decimal and decimals into radicals.
Hope it helps.
Sep 28, 2009 | Casio fx-300ES Calculator
I need to convert decimals to fractions
Press [MATH][1:ToFrac] to convert an aswer to fraction.
If you enter 18.52[ToFrac] [ENTER gives 463/25
[MATH][2:ToDEC] converts a fraction to a decimal number.
Hope it helps.
Sep 22, 2009 | Texas Instruments TI-84 Plus Silver...
Trigometric circular functions..
No the calculator cannot convert decimal values into excat values.
Hope it helps.
Nov 09, 2008 | Casio CFX 9850GA Plus Calculator
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
