Question about Boating
ML Magneto CK1 - Boating
To replace ignition lock of geely ck1 1.3 2008 model do I need to replace the door locks as well
Generally you can only purchase a lock set, which will include all of the locks but if you don't mind having 2 separate keys for your car you can just replace the ignition.
Feb 22, 2015 | Geely Cars & Trucks
Have a Kymco CK1 125. Slid on gravel & bent rear
Near a new rear set most likely....can't do just lever
Sep 18, 2014 | Cars & Trucks
How to change a magneto on a riding lawn mower
Remove the end cover (where a rope starter is or would be). Remove the magneto attachment nut. Acquire a magneto puller. Attach it to the magneto, crank it until the magneto pops off. Find the little rectangular key (which might have popped off the shaft when the magneto popped off), and make sure it's seated in its little groove in the shaft. Place the new magneto on the shaft, install its attachment nut, crank it down.
Apr 23, 2014 | Garden
Finding the fuse box for Geely CK1
I need fuse box to Geely c32 2009. I share photos that have been uploaded . I hope your support . Thank you.
Aug 05, 2013 | 2008 Geely CK 1.3
CK1
you will need to contact the manufacturer for this , there are some after market repar parts for nearly all phones on ebay but for something internal like this you will need to consult the manufacterer or the place you purchased the phone for any repairs
Feb 22, 2013 | Sony Ericsson CK15i X10 txt pro White
Lawnboy gold series 10400, sn 4906038, failure to fire. Possible bad magneto. Looking for replacement part and magneto settings; i.e., gap between flywheel and the magneto. Any other tips appreciated.
You should be able to get a new magneto at any local lawnmower repair shop. The proper gap can be achieved using a standard business card. When you get the new mqagneto, turn the magnets on the flywheel to the opposite side away from the magneto, replace the magneto pulling it all the way back away from the flywheel and "snug" 1 or both of the mounting screws.
Now, turn the flywheel magnet to where it is centered under the magneto, insert the business card between the flywheel and magneto and loosen the screw you tightened earlier. Magneto will pull down tight to the magnet. Tighten both screws then rotate the flywheel to remove the business card
Sep 22, 2009 | Garden
Boating Logo
44 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
