Question about Ovens
Not heating Martha Washington wall oven
The corals don't get hot
2 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: lower electric wall oven won't heat up
It is highly likely that your heating element is open so I would ( with power removed) verify the integrity of the element by detaching it and making sure it is not elecltrically OPEN, It is nothing more than a big power resistor that when current is flowing,..gets hot but if it becomes open.. you will not have any curent flow thru it ( or heat generated from it). That would be the first place I would look.. It could also be the control that feeds it..
A few ideas to check..
Regards,
Rick
Posted on Feb 16, 2009
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Frigidare double wall oven, both heating elements not getting hot.
Check the mains voltage at the socket it may be blown fuse or faulty circuit braker, If ok check the oven on off switch for voltage.
Nov 26, 2014 | Frigidare Ovens
Oven will hot heat
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 22, 2010 | Maytag Amana 30 in. Electric Double Wall...
I can't find an owners manual for my very old Frigidaire RE-94 wall oven. the oven powers on, but the heating element does not get hot-- so trying to assess if a new heating element would do the trick or...
I have the same oven. works perfectly since 1976. I have the owner's guide and the schematic which will direct you to the solution. you will need to pull the oven 1/3 out of the wall in order to access the electric controls and use a VOM to check voltages.
Let me know what you need.
Curt
Oct 14, 2009 | Frigidaire Ovens
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
No heat to the oven
if the heating element "rod" doesn't turn orange (hot) when it's on it's bad so; remove the heating element and get a new one from an appliance parts site on the web and install it don't forget to unplug the range first!
Apr 20, 2009 | Vulcan ECO2D Electric Single Oven
Lower electric wall oven won't heat up
Regards,
Rick
Feb 15, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Viking Double Electric Oven VEDO127T
Probably a faulty heater element, some ovens have more than one element in the compartment, so it is possible you only have part heat.
Dec 01, 2008 | Viking 27" Professional Select Built-in...
Ovens Logo
75 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
