Question about Samsung WF328AA Front Load Washer
DC68-02807A samsung washer debris filter cap - Samsung WF328AA Front Load Washer
3 Suggested Answers
  • 6277 Answers
SOURCE: I cannot take my debris
Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 07, 2011
SOURCE: samsung washer will spin but do not drain
It sounds like your water pump is out. We replaced ours and it fixed the problem. You can get the part for around $60.00
Posted on Dec 30, 2011
Wat area is the pump filter on my Samsung washer and dryer combo
How do I clean the debris filter in my front loading Samsung washing machine?. Open the filter cover(A) by using a coin or key.Take one end of the emergency draining tube (B) out.Open the emergency drain cap (C) by pulling it. Allow all the water to flow into a bowl. Note: hold the cap at the end of the emergency draining tube (B) and slowly pull it out. Note: you may need to drain several bowlfuls of water. . Prepare a dry cloth. Wash any dirt or other material from the debris filter. Make sure the drain pump propeller behind the debris filter is not blocked.Replace the debris filter cap tightly.Reinsert the emergency drain cap and the drain tube.ake sure to replace the debris filter and emergency drain cap after cleaning it. If they are not reinserted properly your washing machine may leak or otherwise malfunction.Close the filter cove
Sep 30, 2016 | Samsung Washing Machines
Why does it not drain?
It "should drain automatically. If yours does not, please make sure the washer is properly leveled both front to back and side to side, make sure the drain hose is not inserted too far into the drain pipe and that there are no bends or kinks in the drain hose that might cause a blockage. Samsung also recommends cleaning the debris filter on a regular basis (at least once per month). To avoid spillage when cleaning the debris filter, it's important to first empty the rubber drain tube located next to the debris filter into a container. For more information, please refer to the User Manual."
Source: http://answers.us.samsung.com/answers/7463/product/WF330ANB_XAA/samsung-4-3-cu-ft-washer-questions-answers/questions.htm
You can download the "User Manual" and "Troubleshooting Guide" from here:
http://www.samsung.com/us/support/owners/product/WA5471ABW/XAA
I hope that helps you!
Jun 21, 2014 | Samsung WA5471AB 4.7 Cu. Ft. Top Load...
Where is the debris filter in a samsung washer WF328AAW/XAA
you take the plug out
take the back off
it should be between the tub and the pump ((take the hose of and clean it))
Feb 02, 2014 | Samsung WF328AAW Front Load Washer
Samsung washing machine wf306law xaa where is debris filter?
I have a
WF306LAW/XAA Samsung, and no idea where this filter is! Any help?
Nov 13, 2013 | Washing Machines
Samsung frontload washer fashing nd code
The ND code means not draining
The older versions of this machine did not have a debre filter, but in later versions a drebe filter was added . It is on the bottom right of the front panel. Open the door. Pull the cap off the drain hose and drain water into pan. Remove filter cap. Wash filter off and don't block propeller when replacing filter cap. Insert cap back in drain tube.
Jun 04, 2011 | Samsung WF328AAW Front Load Washer
I cannot take my debris filter out from my Samsung P1053 washer. I have drained all the water. No water came out from the rubber hose. So I had to drain using filter cap. After some rotations in...
Suggestions-
John C
May 07, 2011 | Samsung 4.0 cu. ft. Washer
Kenmore Elite HE3 - Washer stopped - door locked - did not drain and spin - Getting error message F02
  1. Unplug the washer.
  2. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer.
  3. The drain/filter/pump is right in front.
  4. You can see a diagram of the pump at http://www.repairclinic.com/PartDetail/Drain-Pump/1200164.
  5. First remove as much water from the washer as you can. Place a large towel under the pump - a lot of water will come out when you remove the filter cover cap.
  6. Remove the drain filter cover cap by turning the filter cover cap counterclockwise.
  7. Remove the filter and check the housing and pump impeller vanes for debris (see if you can move the pumps impeller by hand).
  8. Clean the cover cap gasket and the gaskets mating surface.
  9. Replace the filter and close the cover cap firmly.
  10. Run a short wash cycle and check for any leaks at the filter cover cap. If the error comes back, you may need to replace your drain pump.
  11. Replace the kick panel if none are found.
Feb 27, 2011 | Kenmore Washing Machines
I have an error code of nd on my washer
If your washer is beeping, and the display is flashing "Nd", your debris filter may be clogged. To check for a clogged debris filter, goto back of machine, look for little door at bottom remove cover and remove filter and clean
Dec 19, 2010 | Samsung WF306BHW High Efficiency Front...
Error with 'Debris Filter' on Samsung WD-J1255 machine
remove pump and dismantled it,I don't think the rubber you found is off the machine,look for something caught in pump
Mar 21, 2008 | Washing Machines
Samsung WF328AA Front Load Washer Logo
186 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
