Question about Gateway NE56R10u Laptop
Needs new motherboard where do I find a replacement
The motherboard of my ELNA 9000 burned and needs to be replaced
Hi Chrissie, I'm Julie. The technician who checked your machine is likely to be the best person to suggest if the burnt out component can be replaced, or whether a new motherboard is needed. The technician should also be able to order a new motherboard. The replacement of the component or motherboard is best left to the technician or service personnel to carry out. It's not a DIYable task.
Aug 05, 2015 | Elna Sewing Machines
Need instructions for replacing and wiring Motherboard
Luckily that is pretty easy with modern motherboards.
1. Remove power and unplug all devices hooked to computer.
2. Open case.
3. Write down the location and orientation of all wires connecting to old motherboard.
4. Disconnect all wires from the case that are plugged into old motherboard.
5. Uncrew the screws holding the motherboard in the case.
6. Carefully remove old motherboard.
7. Install new motherboard and secure it to the case (probably using the same screws as the old MB)
8. Refer to diagram you made earlier to plug in all the wires to the proper places in the new motherboard.
9. Check and make sure the new motherboard works before closing the case.
10. If everything is working correctly, close up the case and you are done.
Nov 10, 2013 | Computers & Internet
MY MOTHERBOARD WON'T BOOT ERROR BIOS IS NOT FULLY ACPI COMPLIANT
Run BIOS configuration...power on...then press the DEL to run BIOS setup configuration...if you cannot access this process. Your Motherboard BIOS IC is defective and need to replace it. But most of this kind of problem...technicians replace the whole MOTHERBOARD with new one.
So, I suggest you to replace the motherboard with new. Do not intent to replace the BIOS IC because it will not work...due to different programming language depending on the brand of BIOS. Because AWARD and PHOENIX has different configuration...
Sep 16, 2011 | Computers & Internet
IN MY MOTHERBOARD RAM SLOT IS CORRUPTED WHAT IS THE SOLUTION?
If the ram/memory module is faulty then it can be easily replaced. If the ram slot is faulty the you may need to replace the whole system board.
Feb 28, 2011 | Intel Motherboard
Compac SR2011WM motherboard
replacing the mobo is much cheaper that to purchase a new computer but purchasing a new computer is much better than replacing your mobo. because in the near future, you need to upgrade your system for better use.
Mar 29, 2010 | Computers & Internet
Gateway 6750 notebook needs a new motherboard. Is replacement available
When I need something like this, I Google it.
They are usually available.
Try e-Bay, also. I've generally found replacement parts there.
Paying Gateway for a new motherboard costs BIG bucks!
Aug 04, 2009 | Gateway Computers & Internet
New motherboard
Sad news is, trying to find a celeron motherboard.
It's best if you purchase a new computer altogether.
If you go and replace the motherboard, then you need a new pcu, power supply, Ram, reinstall Windows..you get the picture.
Best to save up and buy a new computer.
Jul 15, 2009 | Computers & Internet
Replacement motherboard needed
ebay is the best and cheapest place to get a new mother board
Jan 09, 2009 | Intel Motherboard
I need replace my motherboard form my laptop
I believe this is a laptop and it would be cheaper and easier to buy a new one They range in price AU $7550 upward. As to replace motherboard could be expensive as a computer repair shop would have to do it
Aug 07, 2008 | Sony Computers & Internet
Gateway NE56R10u Laptop Logo
18 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
