Question about Lands Phones
YS105R Manual for Yellowstone ipad/iphone docking system
Manual for Yellowstone Model Number YS105R
I have a new docking stationbut am unable to connect it to my old apple ipod canyou help please
Probably your new docking station is equipped with the new Lightning connector used by iPhones and iPads instead of the 30-pin connector used by old and newer iPods. Search on Internet to see if you can find a Lightning-to-30-pin adapter. Do not get a 30-pin-to-Lightning adapter; you will waste your money.The latter adapter is more readily available, but is used to connect an iPhone or iPad to and OLDER docking station equipped with a 30-pin connector.
Dec 25, 2014 | Apple Audio Players & Recorders
Tip
How To Connect Your iPhone, iPad, or iPod To The TV
The following devices have support for TV out:
  • iPhone
  • iPad
  • iPod touch
  • iPod nano (3rd generation and later)
  • iPod classic, iPod (5th generation), and iPod photo
Note: Other iPod models may support viewing of photos or slideshows on the iPod display but do not support TV out.
The following docks support TV out when used with an iPod model or iPhone that supports TV out:
  • Apple Universal Dock (requires either the Apple Composite AV Cable or the Apple Component AV Cable-will not work with the iPod AV Cable). Search the store for part number MB125G.
  • iPod Universal Dock or iPod with color display dock (iPod photo dock)
Important: The iPhone dock does not support TV out.
iPod models that support TV out can support viewing on a television in several ways. Use the tables below to see which cables and docks can be used with each iPod model. Check the documentation that came with the cable or iPod for information on how to connect and enable TV out.
Note: If you choose to use a third-party cable, make sure it has the "Works with iPhone" or "Made for iPod" label. Learn more about iPod and iPhone accessories.
All you need to get TV out is a compatible iPhone, iPad, or iPod and the correct cable. If your device works with the component and composite cables, then the choice depends on the TV(s) you will be connecting to.
  • Apple Composite AV Cable (part number MB129LL) will connect any iPhone, iPad, or iPod to your TV using RCA Cables.
  • Apple Component AV Cable (part number MB128LL) will connect any iPhone, iPad, or iPod (except iPod with color display (iPod photo), and iPod (5th generation)) to your TV using Component Cables.
A dock can be a welcome addition if you're going to keep your cables connected to the TV. The Apple Universal Dock includes an Apple Remote so you can pause and adjust the volume from a distance. The docks and cables are sold separately.
on Feb 21, 2011 | Apple iPhone Smartphone
My Sony audio charging station will not charge my iPad ,it worked for a year but not now
method 1 ) dock your ipad and then turn on Power for sony station
Method 2 ) dock to already powered station
Either one should work. Else refer to manual trouble shooting section.
Jul 20, 2014 | Sony Rdpt50ip Ipad[r]/iphone[r]/ipod[r]...
Yellowstone radio ys105bl manual
how do I turn on a 2.1 docking system for ipod +iphone ys105bL yellowstonet that turned on then didn't
Feb 17, 2013 | Watches
How do I connect my jvc ux-vj3 to the tv
I have the same problem, thought it might have been my iPod , but hooked iPhone up to it to and same thing. If someone has a solution I'd like to here
May 19, 2012 | JVC UX-VJ3 Dual Docking Mini Audio System...
IPhone 3GS not charging
Sounds like you have a broken dock connector. Apple should give you a replacement. If you're out warranty, you can try to open it and replace dock connector. You can get the part at iPad Repair and there is a guide that shows you how to open a kindle and install parts at iPad Repair Guide.
May 14, 2010 | Kenwood KDC-MP342U Car CD Player
Lands Phones Logo
65 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
