Question about Frigidaire GLTF2940ES Front Load Washer
Error code "loc" on GLTF2940ES0 washer
Error code flasher "loc) and washer won' t start
  • 6 more comments
  • Anonymous Feb 06, 2008
    door won't lock and apear error loc
  • birdylara Mar 17, 2008
    i have the same code coming up on my front loader....i tried unplugging it and pickin a different cycle but it own't start..
  • bcheek Jul 04, 2008
    error code /LOC- have recently moved washer but worked after I moved it til today- it just beeps and shows that error message - will not start- I have checked the dispenser and the door - I presume LOC means door lock won't lock therefore won't start but can't fix.
    erro rmessage on GLTF2940ESO error/LOC - machine won't start
  • kashib Sep 18, 2008
    Model number: GLTF2940E.
    Shows error code 'LOC'. It simply beeps, doesn't start. The little LED next to 'Door Lock' doesn't lit.
  • Shanden Oct 16, 2008
    LOC error none of the suggesstions work. Tried to get to the locking mechanism from the top cover. I am afraid I will make matters worse if I try to remove the front panel to get to the lock
  • Anonymous Apr 20, 2009
    I keep getting error code LOC and the washing machine won't start.
  • goldie0267 Apr 20, 2009
    thanks soo much no money to fix the washer and two buttons and it is fixed wow i could cry you just saved me food money
Turn the selector knob so the machine comes on then press the "options" and "select" bottons at the same time for 3 seconds.
Posted on Nov 24, 2007
  • emanwheels Sep 20, 2011
    Worked beautifully! I'm my wife's favorite husband now! Thanks dcrog and Fixya!!! I'll be back!
Yes!!!! I got the machine running now, and hopefully I can get them out again!!!!! thanks Fix ya!!!!
Posted on Oct 12, 2008
Thank you Apprentice your solution worked. I can always count on FixYa to solve most of my repairs......
Posted on Oct 24, 2008
    New Friend:
It worked ! awesome!
Posted on Aug 25, 2012
This worked. Thank!
Posted on Apr 20, 2009
SOURCE:
Loc error code on Frigidaire frontloader
To avoid having someone accidentally start or stop the washer, press OPTIONS and Select at the same time and hold for about 10 seconds until the Control Lock) lights up. "LOC" will be displayed alternately with the estimated cycle time. Turning the Cycle Selector knob or pressing any button will produce flashing indicator lights and/or beeping. To unlock the controls, press and hold OPTIONS and Select for about 10 seconds. Frigidaire GLTF2940ES3 Quick Start Manual Page 3
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
LOC showing on screen
Hello Annie, thank you for allowing me to assist you!
I see you are still receiving error code "LOC" even after replacing the door lock assembly. Let's try unplugging your washer once again to determine if it is a false error code. It is important to wait roughly ten minutes and then turn your washer on. Before selecting a cycle, press OPTIONS and SELECT at the same time for 20 seconds until "LOC" is no longer displayed. If the error code does not clear, then your washer more than likely may be experiencing an issue with the control board or wiring harness. I hope this information helps to some degree.
Feb 18, 2014 | Electrolux EW1000i Front Load Washer
Washer will not start error code says "LOC"
hold the option and select buttons at the same time for several seconds and it will "unlock" the control panel hold it for a very long time keep them pressed as you turn the dial
Dec 09, 2010 | Frigidaire GLTF2940ES Front Load Washer
My washer won't start, it keeps flashing ERR and then the wash-time, and then LOC. My roommate says to fix it before, he held down three buttons, but can't remember which ones. Any idea?
Try the following two buttons: press Options and Select together for 10 seconds (or until the LOC disappears). The pair of buttons held for 10 seconds also sets this control lock.
To find out the error code, turn the Program knob to the start position, Spin Only. Press Start/Pause to start the cycle. Press Cancel to stop the cycle and turn off the LEDs. Press Cancel again and within 5 seconds press and hold the Options and Start/Pause buttons until the LEDs start chasing. Then release the buttons. Turn the Program knob seven clicks clockwise from the Start position. The control will signal the last error code. To clear the error, press and hold Options and Start/Pause for 3 seconds. Then either unplug the washer for 5-8 seconds before plugging it back in. Alternatively, press and hold Options and Start/Pause together for a few seconds until the Wash LEDs appear.
http://www.applianceblog.com/mainforums/frigidaire-electrolux/12950-frigidaire-atf6000es1-wont-drain.html has a link to the service manual for the listed washer (the link is half-way down the page).
I hope this helps.
Oct 12, 2010 | Frigidaire ATF6000ES Front Load Washer
I have error code loc the machine won't
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 27, 2009 | Kenmore Elite 45986 Front Load Washer
Error code LOC
Jun 27, 2009 | Kenmore 44932 Front Load Washer
Error code LOC on kenmore front load washer
Press/hold LOCK for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 08, 2009 | Kenmore Elite 45986 Front Load Washer
ERROR CODE SEARS 417.44082400 FRONT LOADER
Press 'options' & 'select' down together till the lock sign goes off.
Mar 08, 2008 | Frigidaire Affinity ATF7000E Front Load...
Kenmore Ecocycle Front Loading Washers ERR ??? LOC???
Try to fix it by unplugging the unit for few hours and then plug it back in. Good luck !
Jun 20, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Frigidaire GLTF2940ES Front Load Washer Logo
2,002 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
