Question about AmScope 10 Mp Microscope Camera 2000/xp/vista/7 & Mac Os Apple
Nikon d5100 adapter for amscope T120 microscope
The adapter when put on the microscope with the camera attached is very unstable, we bought both items from amscope.
Can metz 45CL-1 support Nikon D5100?
To use Metz 45CL-1 with Nikon D5100, you need use in apperture priority mode (A), adjust same ISO and apperture in Flash and Camera (Ex: ISO400 and F: 5.6) . The flash adjust light intensity to mantain correct exposition. You need use an adapter to conect Sync cable in your camera.
Nov 13, 2015 | Nikon D5100 Digital SLR Camera With...
How to resolve nikon d5100 lens not attached error?
When you connect a lens from another firm, or an old one without a chip, The camera can't work in the automatic settings. So not one scene and also you can't use the A, S, P and Auto. Really only manual is possible. And you have to dial in everything. like shutter time and you have to set focus and Aperture on the lens.
Aug 27, 2014 | Nikon D5100 Digital SLR Camera With...
My Nikon D5100 has been fell in water, did any one faced such case and what is the recommended place for repaire in Egypt?
there are special repair centres fir water damage. Not sure you can find one close to you. You could try to put the camera in a bag of rice, and contact a Nikon certified service centre immediately. First ask them if they can repair and then what it will cost. Could be expensive, so i think you should start saving for a new camera.
May 22, 2014 | Nikon D5100 Digital Camera with 1855mm...
Nikon D5100 dark screen on live view mode
Open your appuatue set your ISO to 200 or 1600 what ever it needs
Feb 20, 2014 | Nikon D5100 Digital Camera
Service fee for D5100 lens / sensor cleaning
You could ask a Nikon service centre closest to you.
You could try to clean it yourself. But only with the correct tools and enough knowledge about the camera. Cleaning kits for DSLRs can be bought in almost every camera shop. Perhaps you even can order a set with Nikon. Please if you do it yourself, inform yourself before you begin.
Jan 21, 2014 | Nikon D5100 Digital SLR Camera With...
Nikon D5100 camera flash does not pop-up. Any suggestions?
You can't pop up the flash in the Auto mode. In this mode the camera decides whether to use the flash or not.
Try switching to one of the PSAM modes. Does the flash then pop up when you push the flash button?
Jan 17, 2014 | Nikon D5100 Digital Camera
Is adding grip for nikon d5100 solve the problem of auto focus with sigma 170-500 lens
No. This lens lacks an autofocus motor, relying on the camera to have one. The D5100 lacks an autofocus motor, relying on the lens to have one. Adding a battery grip does not change this situation.
The D5100 only autofocuses with lenses having an internal autofocus motor. Nikon designates such lenses AF-S, Sigma calls it HSM. Lenses without the motor will only autofocus with the larger and heavier Nikon cameras such as the D7000.
Nov 27, 2012 | Polaroid Wireless Performance Battery Grip...
Nikon D5100 Autoexposure error when camer is first turned on
Hi I'm having the same problem!!!
My Nikon D5100 camera giving a sin of Autoexposure error after it's drooped from my tripod on the deck floor (Wooden Floor). How can I fix that? I tried few does not work, please help me, it's an emergency. Thanks!
Aug 28, 2012 | Nikon D5100 Digital SLR Camera With...
D5100 won't power on with Sigma macro lens atttached
This is not a solution but the same kind of problem.
I just bought a Nikon D5100 and found that my Sigma 105mm macro has a problem. The camera will not power up, but if I turn it on, untwist the lens and then twist it back in, the camera powers up. If I leave it for a few seconds, it powers down again. Provided I keep taking photos, it works, but this is not acceptable because it can take several seconds to get a focus on a close-up, and by time I get the focus, the camera powers down again.
I never had any problems with this lens on my Nikon D80. I also use several lenses, all of which work well with both cameras. It's only the Sigma that has the problem. And I did clean the contacts with a proper contact cleaning solution and a swab, but still no joy. My lenses are made by Tamron, Pro Optic, Nikon and Sigma, and the only problem lens is the Sigma.
Feb 29, 2012 | Nikon D5100 Digital Camera
Can I use Quantaray AF 28-90mm f/3.5-5.6 in a NIKON D5100? Thanks.
Quantaray makes lenses with a variety of mounts for a variety of cameras. A lens with a Sony mount, for example, will not fit onto a Nikon camera. Assuming the lens has a Nikon mount, it will fit on the D5100. However, the D5100 requires the lens to have an autofocus motor. If the lens does not have such a motor then it will not autofocus. It will still work fine as a manual focus lens.
Jun 19, 2011 | Quantaray AF 28-90mm f/3.5-5.6 Lens for...
AmScope 10 Mp Microscope Camera 2000/xp/vista/7 & Mac Os Apple Logo
43 people viewed this question
Top AmScope Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you an AmScope Science and Laboratory Expert? Answer questions, earn points and help others
