Question about Linksys EtherFast BEFSR41 Broadband Router 4 x 10/100Base-TX LAN 1 x 10Base-T WAN Broadband Router (BEFSR41FT)
The area connections with internet were lost
My Linksys BEFSR41 worked well for a few years. However,after my computers were left on the ?standby? for an hour, their area connections with the internet were lost. I connected and disconnected the router, modem and my computers several times, but I could not restore these connections. At the same time, I have no connection problems with the internet working without the router. I am wondering if my router is gone and should be replaced or it can be repaired. Thank you very much in advance.
    Sergeant:
  • 322 Answers
Try updating its firmware, if its not yet making any improvements, consider buying a new one.
Posted on May 08, 2009
I have a WRT54G router and want to daisy chain a Linksys BEFSR41 switch off it, but I seem to be doing it wrong...
Not sure if you just want to expand the amont of computer you can connect to it or the wireless range but I would setup the BEFSR41:
  • Disable DHCP
  • Set an address out of the DHCP scope of the WRT54G
  • Connect them LAN to LAN if not use xover to connect them
Aug 27, 2010 | Linksys Wireless-G WRT54G Router
Slow or no connectivity with linksys modem
- Changing the LAN IP Address of your Linksys will do to fix the issue.
Mar 16, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Woodenthings
Your provider probably sent you either a cable modem or adsl modem. If you connect the single port on the modem to the WAN or Internet Port on the Linksys and then connect the computers to any of the 4 ports that are grouped together, it should work.
Mac or PC, it makes no difference and drivers are not needed.
Unless this is a new router or it is one that you personally configured, I recommend resetting it back to factory default by holding down the little red button for 30 seconds, this eliminates any configuration issues that someone else may have introduced.
Jan 03, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Setup and confifuration of my linksys befsr41 ver 2 router
Since you did not include your exact model number and type of internet provider I cannot give you more specific instructions. Although you can refer to the links below on how to set it up. If you require further assistance just reply to this and give me the model number of your ISP and the model of your router. Also answer this question " When you plug your computer to your modem do you get online automatically or do you need a username and password"
DSL
Cable
Dec 17, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Cant get to internet thru linksys etherfast cable/dsl router
Reset the modem while the router is plugged into it. Do this by disconnecting the power to the modem and then reconnecting.
Nov 09, 2008 | Linksys EtherFast Cable/DSL Router
Copy an installer to my router
  • connect modem to router
  • connect router to computer
  • u will be able to go online
  • if not u can contact me back or u can start with www.linksys.com
Oct 23, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys Rouer BFR stops functioning
There's a possibility that the router is already going bad but you can try first updating the firmware of the router because sometimes this problem is related to the software of the router so you may need to update its firmware,but if still after updating and still the same a new router will be the best solution for this problem of yours..You can also call this number for technical support help and double checking if the router is bad or still can be fix 1-877-787-8749...
Don't forget to rate the solution FIXYA thank you....
Oct 18, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
2 0f 4 ports do not work
It sounds as though the ports on the cable/dsl router as bad. There really isn't anything you can do. It just happens. The typical shelf life of those routers is about 3-4 years. You could go out and buy another one or if you just need more ports go out and buy a little 5 port switch and plug it into one of the working ports and your comptuers into the 5 port switch.
MO
Jul 12, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Computers & Internet Logo
57 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
