Question about GE JKP27 Electric Double Oven
NEED A REPLACEMENT OVEN RACK FOR A GE JKS26G0J3BG
Why is there a loud noise coming from control panel when I turn on the oven?
How often does it happen? Sounds like your control board is starting to fail. The Repair Shack can fix the oven control board if it needs repaired.
Nov 29, 2015 | GE Profile PT916SRSS 30" Single Electric...
Replacement light for ""J b968s" ge oven
Remove the lamp and determine what type it is. Take it to a retail store that stocks replacement appliance lamps or an appliance parts supplier and purchase a replacement. Install the replacement lamp.
Dec 01, 2013 | Ovens
My broiler element has burnt out and i need a replacement its a GE built-in oven model number JKP15
See this link, then click on the exact model number for your appliance. Navigate to the section of the oven containing the part you require:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JKP15
Apr 02, 2011 | GE JKP15 Electric Single Oven
Need wiring diagram for part number WB27T10276 for ge oven model JRS04BW3BB
For anyone installing a replacement oven controller #WB27T10276, there is a GE publication # 31-10515 that should answer your questions. I bought a rebuilt control that did not have this info. with it. Lucky for me, a retail appliance parts store opened a box with a new control in it and copied the instructions for me.
Aug 14, 2010 | GE 24" Built-in Single Electric Wall Oven...
GE Monogram Trivection - self-clean cycle with oven racks in
Hello- First off, do not use 'self clean', or as most Techs call it: "Self- Destruct".  This 'feature' cheerfully sold by the salesman destroys more oven and range components than any other failure. Now- the racks had a thin layer of grease on them when the oven tried to turn stuff inside the oven to ash.  The grease is now a hard rubbery coating on the surface of the rack.  To solve this problem, you must determine by observation, where the rack touches the sides of the oven. These contact areas need to be cleaned thoroughly with scotchbrite and a small portion of oven cleaner. Make sure you use gloves. Sliding rack in and out to 'mark' these small spots works pretty good.  Once cleaned and wiped down, they should work fine. I recommend cleaning by removing as much 'stuff' by scraping and wiping down with moist cloth.  Turn on to 450deg for 30 min.  Much safer, less costly.                                                       Please acknowledge this posted solution if helpful.  Have more info if needed-  Thanks  -Ed
Mar 24, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
Replacement oven racks
The rack can be purchased from GE online or over the phone the part number is WB48X73 cost is $99.75
Feb 25, 2010 | GE JKP27 Electric Double Oven
Ovens Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
