Question about Car Audio & Video
How can i charge my 3sm car battery to a motorcycle
How long do i charge ever start 16b battery after filling with acid
Hi Anonymous, the "ABSOLUTE" best way is let the battery acid soak into the plates for 1 hour then connect a 1 or 2 amp trickle charger and let it charge for 24 hours for maximum battery life. Read my lips "DO NOT" use a higher rate charger for less hours it will shorten your overall battery life, trust me I was a Harley technician for over 40 years. For more information about your issue please click on the links below. Good luck and have nice a day. BU 403 Charging Lead Acid
Fill and Charge Motorcycle Battery
How to Charge Motorcycle Battery
Battery Basics Layman Guide to Batteries
May 15, 2016 | Motorcycles
Why is Abs light is flashing after reconnecting battery
Is this a new battery or did you charge the old one? How old is the battery? What did you use use to charge the battery? Car charger or jumper cables are very bad on a motorcycle charging system. Answer these and I may be able able to assist.
May 31, 2014 | 2011 Harley Davidson FLSTFB Fat Boy Lo
Kawasaki klx 250
DO NOT JUMP START MOTORCYCLES!!!
Your main fuse is blown.
Motorcycles have much lighter gauge wiring and will burn up if you try to jump start them, this is why the fuse is installed so car guys dont burn up the wiring on their bikes!
Only charge a motorcycle battery with no more than 2.5 amps of charge.
Or install a new battery.
Apr 02, 2014 | kawasaki KLX 250S Motorcycles
Just want to certain what's the problem of L200 mitsubishi pick up model 96.When i drive long trip my 3sm battery seems losses its power.So, when i turn off the engine then subsequently turn it on it...
Better bring your car to the nearest battery center to check whether the battery or the alternator got the problem.
Here's how to check if the if the alternator got problem, when the engine starts, take off the negative( - ) pole on your battery, if it still runs, that means the alternator is good and the battery will be the problem. Bring that battery to the battery center to test load it.
Hope that helps you out.
Thanks for asking FixYa!
Aug 09, 2011 | 1988 Mitsubishi Pickup
What is the best battery size for my TOYOTA TOWN ACE with an AUTOMATIC TRANSMISSION & diesel engine? I just installed 3SM in it, is this good?
thats a fine battery but when selecting a battery always get the stock or better as far as cold cranking amps goes
Jan 14, 2011 | Toyota Previa Cars & Trucks
How do i charge battery on yamaha 2008 royal star venture
First, I should explain the difference between most motorcycle batteries and the car batteries that people are more familiar with.
A car battery is usually a "lead-acid" battery, a design largely unchanged, except for the composition of the lead plates, since the turn of the century. The battery is composed of alternating plates of lead and lead dioxide in an acid bath. Adding plates increases the electrical capacity, dividing groups of plates into "cells" increases the voltage available. It's a very basic battery that has worked in stationary and vehicular applications for centuries.
A motorcycle battery is usually an Absorbed Glass Mat (AGM) battery, differing from the car battery in only one respect; the space between the plates is filled by a porous, fiberglass-like material that has been saturated by acid. The advantage of the AGM battery is that it is less susceptible to damage from the increased vibration experienced in a motorcycle or high-performance car.
New motorcycle owners are frequently tempted to use the same battery charger they're accustomed to hooking up to the family sedan, but this can, and usually does, cause premature failure of the battery. Because the motorcycle battery is smaller, it requires less current to charge it, and the excess current generates heat. Because the acid does not circulate between the plates of the battery and distribute the heat and gas generated during charging, the battery heats much more rapidly than the car battery. Heat interferes with the chemical processes the battery performs during the charging cycle, and may cause plates to bend, buckle or crack.
Now, you've probably seen "battery tenders" advertised in motorcycle magazines, at Radio Shack, in Walmart and Sears. This is what you should be using - look for a MAXIMUM charge rate of 2 amperes/hour (it's typically described as "amps"), and a reduced "trickle" charge rate (usually automatic) of 1/4 to 1/2 "amp".
To get to the battery, look under the operator's seat (either side) 1"-2" behind the back of the fuel tank; you'll see a nut holding a threaded shaft into tabs protruding from the frame. Loosen and remove the nuts on both sides, lift the seat up until the threaded shafts are completely free of the tabs, then move the seat straight forward. That will free a catch, molded into the underside of the seat, from a loop in the frame that holds the back of the seat down and keeps the seat from moving side-to-side. The seat may then moved out of the way.
Now you will see the battery in the frame; hook the red lead of the battery tender to the battery terminal with a red insulated boot over it, and hook the black lead of the tender to the opposite battery terminal. The battery tender may be left connected for days, weeks or months at a time, but unless the bike is well protected from the weather, it should probably be disconnected after 16-24 hours and the seat reinstalled.
Reinstallation of the seat is the in reverse order of its' removal (above): there is a specification for the nuts - 5 ft.-lbs. (7 nm) - but it's usually sufficient to tighten the nuts snugly on both sides.
May 12, 2010 | 2008 Yamaha Royal Star Venture
How do i charge the battery on my 2008 honda shadow areo 750
best way is to remove the seat and open the battery compartment then use a MOTORCYCLE charger (usually 1 amp or so) clamp the black cable to either an exposed engine mount or to the black wire on the battery clearly marked with a negative (-) then clamp the red to the positive terminal(+) then turn on your charger - if this is for long term storage a special trickle charger or smart charger for a lawn mower or motorcycle is best - never use a car charger they charge too fast and will create a heat buildup that will kill your battery prematurely.
Nov 18, 2009 | 1998 Honda VT 1100 C3 Shadow Aero
Battery died...How to charge
for motorcycles, 2 amp 12 volts max is recomended, usally the slow charge of a car charger
Jul 11, 2009 | 2005 Hyosung GT 250
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
